:o HELP arduino + Ultrasonic+ Shield Ethernet
Hey all i have problem i found code source and look good but when i try used to display data of ultrasonic using ethernet shield arduino on web page…Doesn’t Work
THIS IS CODE
how i can fix that ?? :o
#include <SPI.h>
#include <Ethernet.h>
#define trigPin 5
#define echoPin 6
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 178 };
byte gateway[] = { 192, 168, 1, 1 };
byte subnet[] = { 255, 255, 255, 0 };
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
Serial.begin (9600);
  Ethernet.begin(mac, ip, gateway, subnet);
  delay(2000);
  Serial.println("connecting...");
  String s;
  s=misura();
  Serial.println(s);
  delay(2000);
String misura()
   int duration, distance;
  String risultato;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
   risultato="cm: ";
    risultato.concat(distance);
There is nothing in your code to make the Arduino act as either a client (making requests) or server (responding to requests). Therefore, it is not surprising that the data sent to the serial port is not visible on a web page.
so how i make it ?? how i can make my data display on web page ??
The Arduino has to act as a server. Start with the Ethernet server example.
you mean start with that example ??
#include <SPI.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
IPAddress ip(192, 168, 1, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
Yes.. Instead of reading all the analog pins, and returning useless data, read your ultrasonic sensor and return useful data.
ok bro i'll try do it if icant i'll ask your help
