O I hate C.. why: conflicting declaration 'unsigned char pulses [100][2]
As per title.
I am trying to compile an Infra Red sensor read sketch from: https://learn.adafruit.com/ir-sensor/using-an-ir-sensor
When it gets to line 33: uint16_t pulses[100][2]; // pair is high and low pulse
It fails with:
rawirdecodestruct:34: error: conflicting declaration 'unsigned char pulses [100][2]'
 unsigned char pulses[100][2];  // pair is high and low pulse
rawirdecode:32: error: 'pulses' has a previous declaration as 'uint16_t pulses [100][2]'
No wonder I hate C, but any help in learning the beast will be much appreciated. I have plenty of coding experience ranging from machine code to BASIC, via FORTRAN, COBOL and others, but never had and success with anything more than trivial C programs.
Thanks in advance Mike
No wonder I hate C
You are doing something stupid, like trying to use the same name for two different arrays, and somehow that is C's fault? Get over it.
I tried and the sketch compiled without errors.
Damn. It must be something to do with my development environment then. I'll set up a clean Arduino install and give it another go.
Why do you have rawirdecodestruct and rawirdecode ? They are separate sketches. They should not be in the same directory.
Pete
Code in two tabs in the IDE I suspect, both using the same name for the pulses array
