O2/pH/TDS sensors softserial multi port problem
I'm trying to read three sensors using softserial. If I try to listen to more than one port It doesn't read any of the sensors. If I only try to read one it works fine.
#include <SoftwareSerial.h>      //we have to include the SoftwareSerial library, or else we can't use it.
SoftwareSerial myserial1(2, 3); //define how the soft serial port is going to work.
SoftwareSerial myserial2(4, 5); //define how the soft serial port is going to work.
SoftwareSerial myserial3(6, 7); //define how the soft serial port is going to work.
char tds_data[20];                  //we make a 20 byte character array to hold incoming data from the tds.
char o2_data[20];                  //we make a 20 byte character array to hold incoming data from the o2.
char ph_data[20];                  //we make a 20 byte character array to hold incoming data from the pH.
byte received_from_sensor=0;       //we need to know how many characters have been received.
float o2=0;                        //used to hold a floating point number that is the o2.
float ph=0;                        //used to hold a floating point number that is the pH.
float tds=0;                        //used to hold a floating point number that is the tds.
byte string_received=0;            //used to identify when we have received a string from the pH circuit.
int Data1,Data2,Data3,Data4,Data5,Data6,Data7;
unsigned long startMillis = 0;
String parseIt = 0;
int curPos = 3;
boolean isComma = false;
String tmpWholeStr = 0;
String tmpStr = 0;
void setup(){
     Serial.begin(9600);         //enable the hardware serial port
     myserial1.begin(38400);       //enable the software serial port
     myserial2.begin(38400);       //enable the software serial port
     myserial3.begin(38400);       //enable the software serial port
void loop(){
    Serial.println("Looping...");
  myserial1.listen();
  if(myserial1.available() > 0){        //if we see that the o2 Circuit has sent a character.
     received_from_sensor=myserial1.readBytesUntil(13,o2_data,20); //we read the data sent from o2 Circuit until we see a <CR>. We also count how many character have been received.
     o2_data[received_from_sensor]=0;  //we add a 0 to the spot in the array just after the last character we received. This will stop us from transmitting incorrect data that may have been left in the buffer.
     string_received=1;                //a flag used when the Arduino is controlling the o2 Circuit to let us know that a complete string has been received.
   myserial1.print("R\r");             //send it the command to take a single reading.
   if(string_received==1){            //did we get data back from the o2 Circuit?
     o2=atof(o2_data);                //many people ask us "how do I convert a sting into a float?" This is how...
  int o21 = (int)o2; //Read Altitude digits on the left of the decimal place
  int o22 = (int)((o2 - o21) * 100.0); //Read Altitude digits on the right of the decimal place
    Serial.print("O2 ");
    Serial.print(o21);
    Serial.print(".");
    Serial.println(o22);
    string_received=0;}             //reset the string received flag.
 //    myserial2.listen();
  if(myserial2.available() > 0){        //if we see that the pH Circuit has sent a character.
     received_from_sensor=myserial2.readBytesUntil(13,ph_data,20); //we read the data sent from pH Circuit until we see a <CR>. We also count how many character have been received.
     ph_data[received_from_sensor]=0;  //we add a 0 to the spot in the array just after the last character we received. This will stop us from transmitting incorrect data that may have been left in the buffer.
     string_received=1;                //a flag used when the Arduino is controlling the pH Circuit to let us know that a complete string has been received.
   myserial2.print("R\r");             //send it the command to take a single reading.
   if(string_received==1){            //did we get data back from the ph Circuit?
     ph=atof(ph_data);                //many people ask us "how do I convert a sting into a float?" This is how...
  int ph1 = (int)ph; //Read Altitude digits on the left of the decimal place
  int ph2 = (int)((ph - ph1) * 100.0); //Read Altitude digits on the right of the decimal place
    Serial.print("PH ");
    Serial.print(ph1);
    Serial.print(".");
    Serial.println(ph2);
//     myserial3.listen();
  if(myserial3.available() > 0){        //if we see that the tds Circuit has sent a character.
     received_from_sensor=myserial3.readBytesUntil(13,tds_data,20); //we read the data sent from tds Circuit until we see a <CR>. We also count how many character have been received.
     tds_data[received_from_sensor]=0;  //we add a 0 to the spot in the array just after the last character we received. This will stop us from transmitting incorrect data that may have been left in the buffer.
     string_received=1;                //a flag used when the Arduino is controlling the tds Circuit to let us know that a complete string has been received.
   myserial3.print("R\r");             //send it the command to take a single reading.
   if(string_received==1){            //did we get data back from the tds Circuit?
     tds=atof(tds_data);                //many people ask us "how do I convert a sting into a float?" This is how...
    Serial.print("TDS ");
    Serial.println(tds_data);
          parseIt = tds_data;
          curPos = 0;
          isComma = false;
          tmpStr = 0;
          //Sensor01
          while(!isComma) {
            tmpStr = String(parseIt.charAt(curPos));
            if (tmpStr == String(',')) {
              Data1 = tmpWholeStr.toInt();
              curPos++;
              isComma = true;
              continue;
            tmpWholeStr += tmpStr;
            curPos++;
//    break;
          //Serial.println("Sensor03: " + tmpWholeStr);
          isComma = false;
          tmpWholeStr = 0;
          tmpStr = 0;
          //Sensor03 First Value
          //Sensor03 Second Value
          while(!isComma) {
              Data2 = tmpWholeStr.toInt();
              curPos++;
              isComma = true;
              continue;
            curPos++;
//    break;
          isComma = false;
          tmpWholeStr = 0;
          tmpStr = 0;
          while(!isComma) {
              Data3 = tmpWholeStr.toInt();
              curPos++;
              isComma = true;
              continue;
            curPos++;
          isComma = false;
          tmpWholeStr = 0;
          tmpStr = 0;
  Serial.println("TDS: " + String(Data1 + String(',') + Data2 + String(',')+ Data3));
 delay(800);                         //we will take a reading ever 800ms. You can make this much longer or shorter if you like.
I Fixed the comments, added spacing, and finished the string I'm trying to print at the end. It still has the same problem tho... :frowning:
byte received_from_o2sensor=0;       //we need to know how many characters have been received.
byte received_from_phsensor=0;       //we need to know how many characters have been received.
byte received_from_tdssensor=0;       //we need to know how many characters have been received.
String parseIt = 0;
int curPos = 3;
String tmpStr = 0;
void setup(){
void loop(){
  myserial1.listen();
     received_from_o2sensor=myserial1.readBytesUntil(13,o2_data,20); //we read the data sent from o2 Circuit until we see a <CR>. We also count how many character have been received.
     o2_data[received_from_o2sensor]=0;  //we add a 0 to the spot in the array just after the last character we received. This will stop us from transmitting incorrect data that may have been left in the buffer.
  int o21 = (int)o2;                 //Read o2 digits on the left of the decimal place
  int o22 = (int)((o2 - o21) * 100.0); //Read o2 digits on the right of the decimal place
    Data1=o21;
    Data2=o22;
    Serial.print(o21);
    Serial.print(".");
     received_from_phsensor=myserial2.readBytesUntil(13,ph_data,20); //we read the data sent from pH Circuit until we see a <CR>. We also count how many character have been received.
     ph_data[received_from_phsensor]=0;  //we add a 0 to the spot in the array just after the last character we received. This will stop us from transmitting incorrect data that may have been left in the buffer.
  int ph1 = (int)ph;                    //Read pH digits on the left of the decimal place
  int ph2 = (int)((ph - ph1) * 100.0); //Read pH digits on the right of the decimal place
    Data3=ph1;
    Data4=ph2;
    Serial.print(ph1);
    Serial.print(".");
     received_from_tdssensor=myserial3.readBytesUntil(13,tds_data,20); //we read the data sent from tds Circuit until we see a <CR>. We also count how many character have been received.
     tds_data[received_from_tdssensor]=0;  //we add a 0 to the spot in the array just after the last character we received. This will stop us from transmitting incorrect data that may have been left in the buffer.
          parseIt = tds_data;
          curPos = 0;
          isComma = false;
          tmpStr = 0;
          while(!isComma) {
              Data5 = tmpWholeStr.toInt();
              curPos++;
              isComma = true;
              continue;
            curPos++;
          isComma = false;
          tmpWholeStr = 0;
          tmpStr = 0;
          while(!isComma) {
              Data6 = tmpWholeStr.toInt();
              curPos++;
              isComma = true;
              continue;
            curPos++;
          isComma = false;
          tmpWholeStr = 0;
          tmpStr = 0;
          while(!isComma) {
              Data7 = tmpWholeStr.toInt();
              curPos++;
              isComma = true;
              continue;
            curPos++;
          isComma = false;
          tmpWholeStr = 0;
          tmpStr = 0;
 Serial.println("O2/pH/TDS: " + String(Data1 + String(',') + Data2 + String(',')+ Data3 + String(',') + Data4 + String(',')+ Data5 + String(',') + Data6 + String(',')+ Data7));
SoftSerial can only do one thing at a time. It can't even send and receive at the same time.
Can you organize things so that devices can be read one at a time?
If not, one solution would be to use an Arduino Mega which has 4 hardware serial ports.
...R
Basically if I do this.....
  myserial1.listen();
This...
//  myserial1.listen();
  myserial2.listen();
or this...
  myserial3.listen();
It works fine. But if I do this..
  myserial1.listen();
  myserial2.listen();
or this...
  myserial1.listen();
  myserial2.listen();
  myserial3.listen();
It only prints the "looping" and the string at the end with all zeros
I started with this example from here
This is the most complicated sketch ive attempted so far btw. Thanks for any help.
  Software serial multple serial test
 Receives from the two software serial ports,
 sends to the hardware serial port.
 In order to listen on a software port, you call port.listen().
 When using two software serial ports, you have to switch ports
 by listen()ing on each one in turn. Pick a logical time to switch
 ports, like the end of an expected transmission, or when the
 buffer is empty. This example switches ports when there is nothing
 more to read from a port
 The circuit:
 Two devices which communicate serially are needed.
 * First serial device's TX attached to digital pin 2, RX to pin 3
 * Second serial device's TX attached to digital pin 4, RX to pin 5
 Note:
 Not all pins on the Mega and Mega 2560 support change interrupts,
 so only the following can be used for RX:
 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
 Not all pins on the Leonardo support change interrupts,
 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
 created 18 Apr. 2011
 modified 25 May 2012
 by Tom Igoe
 based on Mikal Hart's twoPortRXExample
 This example code is in the public domain.
// software serial #1: TX = digital pin 10, RX = digital pin 11
SoftwareSerial portOne(10,11);
// software serial #2: TX = digital pin 8, RX = digital pin 9
// on the Mega, use other pins instead, since 8 and 9 don't work on the Mega
SoftwareSerial portTwo(8,9);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // Start each software serial port
  portOne.begin(9600);
  portTwo.begin(9600);
  // By default, the last intialized port is listening.
  // when you want to listen on a port, explicitly select it:
  portOne.listen();
  Serial.println("Data from port one:");
  // while there is data coming in, read it
  // and send to the hardware serial port:
  while (portOne.available() > 0) {
    char inByte = portOne.read();
    Serial.write(inByte);
  // blank line to separate data from the two ports:
  // Now listen on the second port
  portTwo.listen();
  Serial.println("Data from port two:");
  while (portTwo.available() > 0) {
    char inByte = portTwo.read();
Is it because im trying to write to the port to get a read but im only able to read?
Robin2:
...R
I actually Started with a mega which worked great but I now need it for another project.
There has to be a way to make this work. I tried using a counter with a switch/case but ran into the same problem.
I tried adding this to setup
void setup(){
  myserial1.print ("\r");
  delay(1);
  myserial1.print ("C\r");
  myserial2.print ("\r");
  delay(1);
  myserial2.print ("C\r");
  myserial3.print ("\r");
  delay(1);
  myserial3.print ("C\r");
And commented out these lines
But it does the exact same thing.....
Well I got it to work by moving some stuff around and commenting out a few things :slight_smile:
String parseIt = 0;
int curPos = 3;
String tmpStr = 0;
uint8_t counter=0;
void setup(){
void loop(){
  switch (counter){
  case 0:
    myserial1.listen();
    //  if(myserial1.available() > 0){        //if we see that the o2 Circuit has sent a character.
//    myserial1.print("R\r");             //send it the command to take a single reading.
      Serial.print(o21);
      Serial.print(".");
      Data1 = o21;
      Data2 = o22;
      string_received=0;       //reset the string received flag.
  case 1:
    myserial2.listen();
    //  if(myserial2.available() > 0){        //if we see that the pH Circuit has sent a character.
//    myserial2.print("R\r");             //send it the command to take a single reading.
      int ph1 = (int)ph;                   //Read ph digits on the left of the decimal place
      int ph2 = (int)((ph - ph1) * 100.0); //Read ph digits on the right of the decimal place
      Serial.print(ph1);
      Serial.print(".");
      Data3 = ph1;
      Data4 = ph2;
      string_received=0;
  case 2:
    myserial3.listen();
    //  if(myserial3.available() > 0){        //if we see that the tds Circuit has sent a character.
    //   myserial3.print("R\r");             //send it the command to take a single reading.
        parseIt = tds_data;
        curPos = 0;
        isComma = false;
        tmpStr = 0;
        while(!isComma) {
            curPos++;
            isComma = true;
            continue;
          curPos++;
        isComma = false;
        tmpWholeStr = 0;
        tmpStr = 0;
        while(!isComma) {
            curPos++;
            isComma = true;
            continue;
          curPos++;
        isComma = false;
        tmpWholeStr = 0;
        tmpStr = 0;
        while(!isComma) {
            curPos++;
            isComma = true;
            continue;
          curPos++;
        isComma = false;
        tmpWholeStr = 0;
        tmpStr = 0;
//  Serial.println(counter);
//  Serial.println(millis());
  if ((unsigned long)(millis() - startMillis >= 10000)) {
    Serial.println("O2/pH/Cond/TDS/Sal: " + String(Data1 + String(',') + Data2 + String(',')+ Data3 + String(',') + Data4 + String(',')+ Data5 + String(',') + Data6 + String(',')+ Data7));
    startMillis = millis();
  counter++;
  if ( counter > 2 ) counter = 0;
  delay(1200);                         //we will take a reading ever 1200ms. You can make this much longer or shorter if you like.
Added a water temp sensor and used it for temp compensation on sensors. :slight_smile:
#include <OneWire.h>
#include <DallasTemperature.h>
int Data1,Data2,Data3,Data4,Data5,Data6,Data7,Data8,Data9;
int wtemp1 = 0;
String parseIt = 0;
int curPos = 3;
String tmpStr = 0;
uint8_t counter=0;
#define ONE_WIRE_BUS A1
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress Thermometer1 = {0x28, 0x50, 0x6B, 0xB3, 0x05, 0x00, 0x00, 0x7D };
void setup(){
  sensors.begin();
  sensors.setResolution(Thermometer1, 10);
void loop(){
  Data8=(sensors.getTempC(Thermometer1));
  switch (counter)
//  Serial.print("\n\r\n\r");
    case 0:
    myserial1.listen();
    myserial1.print(Data8);             //send it the command to take a single reading.
    myserial1.print("\r");             //send it the command to take a single reading.
      Serial.print(o21);
      Serial.print(".");
      Data1 = o21;
      Data2 = o22;
  case 1:
    myserial2.listen();
    myserial2.print(Data8);             //send it the command to take a single reading.
    myserial2.print("\r");             //send it the command to take a single reading.
      Serial.print(ph1);
      Serial.print(".");
      Data3 = ph1;
      Data4 = ph2;
      string_received=0;
  case 2:
    myserial3.listen();
    myserial3.print(Data8);             //send it the command to take a single reading.
    myserial3.print("\r");             //send it the command to take a single reading.
        parseIt = tds_data;
        curPos = 0;
        isComma = false;
        tmpStr = 0;
        while(!isComma) {
            curPos++;
            isComma = true;
            continue;
          curPos++;
        isComma = false;
        tmpWholeStr = 0;
        tmpStr = 0;
        while(!isComma) {
            curPos++;
            isComma = true;
            continue;
          curPos++;
        isComma = false;
        tmpWholeStr = 0;
        tmpStr = 0;
        while(!isComma) {
            curPos++;
            isComma = true;
            continue;
          curPos++;
        isComma = false;
        tmpWholeStr = 0;
        tmpStr = 0;
    case 3:
    sensors.requestTemperatures();
    Data9 = (DallasTemperature::toFahrenheit(Data8));
  Serial.print("WTmp ");
  Serial.print(Data9);
//  Serial.println(sensors.getTempCByIndex(0));
  Serial.println(" F");
    Serial.println("O2/pH/Cond/TDS/Sal/WtmpC/WtmpF: " + String(Data1 + String(',') + Data2 + String(',')+ Data3 + String(',') + Data4 + String(',')+ Data5 + String(',') + Data6 + String(',')+ Data7 + String(',')+ Data8 + String(',')+ Data9));
  counter++;
  if ( counter > 3 ) counter = 0;
larold01:
  myserial1.listen();
You have been writing a lot. But the post I have quoted suggests that you have not read my earlier Post.
Lets us know when you have.
...R
Seriously, what is a mySerial? You have some REAL device connected to those pins. The instance name should reflect what that real device is, whether it's a GPS, a modem, a pH sensor, or your Uncle Bob.
I predict that you will finding programming a lot easier when you use names that make sense.
Hi larold,
Please send me wiring of your project.
