OAR - Analog write on pin 10 won't work
Hi, I’ve built a classic Obstacle Avoidance Robot with the Elegoo kit and I’m having trouble getting it to work properly. Everything seems to work with a simple sketch from the disc that correctly operates all wheels. I then load the obstacle avoidance sketch and notice the wheels on the right side do not operate. (It’s as if my bot has a stroke.) I re-examined all of my connections and verified everything is properly connected. After all the AUTO_GO sketch works without issue. I started to debug by comparing the sketch to another working sketch from the disc which correctly operates all wheels. That’s when I realized the code from the disc included in my kit had an error. It was sending analogWrite(ENA,ABS); and ENA was set to pin 11 instead of pin 10 which is the pin connected to my L298 motor driver board.
Here’s where it is weird. When I use digitalWrite to the same pin 10, it works fine. It just doesn’t seem to respect the analogWrite. I thought there may be a voltage shortage or weak batteries so I tried disabling everything in the sketch except for the analogWrite to pin 10 and I still have the same behavior. I don’t understand why changing from digital to analog does not work. I would like to use analog as in the example for speed control. I’m including my sketch below as well as pages from the assembly guide which I followed completely.
I am brand new to robotics and this is my first bot. My kit is brand new purchased 1 week ago. Please advise how to diagnose these issues and/or what could be wrong in my case.
#include <Servo.h> //servo library
Servo myservo; // create servo object to control servo
int Echo = A4;
int Trig = A5;
/*define logic control output pin*/
int in1=9;
int in2=8;
int in3=7;
int in4=6;
/*define channel enable output pins*/
int ENA=10;
int ENB=5;
int ABS = 130;
int rightDistance = 0,leftDistance = 0,middleDistance = 0 ;
void enableMotors()
//  digitalWrite(ENA,HIGH);
//  digitalWrite(ENB,HIGH);
  analogWrite(ENB,ABS);
void _mForward()
 enableMotors();
// digitalWrite(in3,LOW);
// digitalWrite(in4,HIGH);
 digitalWrite(in1,LOW);
 digitalWrite(in2,HIGH);
 Serial.println("go forward!");
void _mBack()
 enableMotors();
 digitalWrite(in1,HIGH);
 digitalWrite(in2,LOW);
 digitalWrite(in3,HIGH);
 digitalWrite(in4,LOW);
 Serial.println("go back!");
void _mleft()
 enableMotors();
 Serial.println("go left!");
void _mright()
 enableMotors();
 Serial.println("go right!");
void _mStop()
  digitalWrite(ENA,LOW);
  digitalWrite(ENB,LOW);
  Serial.println("Stop!");
 /*Ultrasonic distance measurement Sub function*/
int Distance_test()
  digitalWrite(Trig, LOW);
  delayMicroseconds(2);
  digitalWrite(Trig, HIGH);
  delayMicroseconds(20);
  float Fdistance = pulseIn(Echo, HIGH);
  Fdistance= Fdistance/58;
  return (int)Fdistance;
  myservo.attach(3);// attach servo on pin 3 to servo object
  pinMode(Echo, INPUT);
  pinMode(Trig, OUTPUT);
  pinMode(in1,OUTPUT);
  pinMode(in2,OUTPUT);
  pinMode(in3,OUTPUT);
  pinMode(in4,OUTPUT);
  pinMode(ENA,OUTPUT);
  pinMode(ENB,OUTPUT);
  _mStop();
    myservo.write(90);//setservo position according to scaled value
    middleDistance = Distance_test();
    #ifdef send
    Serial.print("middleDistance=");
    Serial.println(middleDistance);
    #endif
    if(middleDistance<=20)
      _mStop();
      myservo.write(5);
      rightDistance = Distance_test();
      #ifdef send
      Serial.print("rightDistance=");
      Serial.println(rightDistance);
      #endif
       myservo.write(90);
      myservo.write(180);
      leftDistance = Distance_test();
      #ifdef send
      Serial.print("leftDistance=");
      Serial.println(leftDistance);
      #endif
      myservo.write(90);
      if(rightDistance>leftDistance)
        _mright();
        delay(180);
       else if(rightDistance<leftDistance)
        _mleft();
        delay(180);
       else if((rightDistance<=20)||(leftDistance<=20))
        _mBack();
        delay(180);
        _mForward();
        _mForward();
On boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10, whether or not there is a Servo on those pins.
Thank you sooo much! That was it! It also explains why the original code was modified to work with pin 11!! I was confused because the instructions clearly detail using pin 11 for the line tracers on the bottom of the bot. Thanks tremendously!!!
Glad to hear it's working now. Enjoy! Per
