OBD code problems
Hi
I am new to writing code for Arduino and I have a few problems with the code I am using for a school project.
  1. The code works but when I choose to see RPMs, then the value is correct until revs go over 1000. Then it only shows correct values but without thousand in front of it. For example, instead of 1250, I get 250.
  2. I basically need to create a shift light but instead of an LED, it has to show text, something like change up. I tried to do something but failed at UpDownMenu==0.
If anyone has recommendations or can help me write the code, then I’m thankful.
Sorry for my English.
Code is split into 2 in responses below.
Many people here will not go to a web site to download code. I am one of them. Someone with 5 posts should know the proper way to post code.
To post code and/or error messages:
  1. Use CTRL-T in the Arduino IDE to autoformat your complete code.
  2. Paste the complete autoformatted code between code tags (the </> button)
    so that we can easily see and deal with your code.
  3. Paste the complete error message between code tags (the </> button)
    so that we can easily see and deal with your messages.
  4. If you already posted without code tags, you may add the code tags by
    editing your post. Do not change your existing posts in any other way.
    You may make additional posts as needed.
  5. Please provide links to any libraries that are used
    (look for statements in your code that look like #include ). Many libraries
    are named the same but have different contents.
Before posting again, you should read the three locked topics at the top of the Programming Questions forum, and any links to which these posts point.
If your project involves wiring, please provide a schematic and/or a wiring diagram and/or a clear photograph of the wiring.
Good Luck!
#include <LiquidCrystal.h>
//Declare Serial Read variables
int CmdCount = 1;
byte inData;
char inChar;
String BuildINString = "";
String DisplayString = "";
long DisplayValue;
String SentMessage = "";
int ByteCount = 0;
long A;
int B;
int C;
int WorkingVal;
String WorkingString = "";
int RefreshCounter = 0; // when the reading should refresh
int RefreshCounterMax = 50; //Adjust this refreshrate
int RESETMenuName = 0;
//MenuAnalogVal
int x;
//Declare Buttons
int MenuID = 0;
int UpDownMenu = 0;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.setCursor(0, 0);
  Bootup(); //Simulate Bootup process doesnt have to be here this only makes it look cool
Retry:
  lcd.print("Connecting......    ");
  lcd.setCursor(0, 1);
  lcd.print("                    ");
  Serial.begin(38400);
  //Send a test message to see if the ELM327 Chip is responding
  SentMessage = "ATI";
  Serial.println("ATI"); delay(500); ReadData();
  if (BuildINString.substring(1, 7) == "ELM327")
    lcd.print("Welcome...            ");
    lcd.print("Connection OK         ");
    delay(1500);
    DisplayString = "Reading Data...........";
    lcd.print("Error             ");
    lcd.print("No Connection!         ");
    delay(1500);
    goto Retry;
  SentMessage = "ATSP A3";
  Serial.println("ATSP A3");
  delay(1500);
  RefreshCounter++;
  x = analogRead (0);
  //Serial.println(x);
  lcd.setCursor(10, 1);
  if (x > 450 and x < 600) {
    if (MenuID > 0) {
      MenuID--; //Left
    } DisplayString = "Reading Data...........";
    delay(250);
  if (x > 300 and x < 400) {
    if (UpDownMenu < 3) {
      UpDownMenu++; //DOWN
    } delay(250);
    RESETMenuName = 0;
  if (x > 20 and x < 240) {
    if (UpDownMenu > 0) {
      UpDownMenu--; //UP
    } delay(250);
    RESETMenuName = 0;
  if (x > -10 and x < 10) {
    if (MenuID < 13) {
      MenuID++; //Right
    delay(250);
  if (UpDownMenu == 0)
    if (RESETMenuName == 0) {
      lcd.print("Economy          ");
      lcd.print("                      ");
      delay(2000);
      RESETMenuName = 1;
    lcd.print(DisplayString);
    if (RefreshCounter == RefreshCounterMax)
      SentMessage == "01 0C";
      Serial.println("01 0C");
      delay(50);
      ReadData();
      if (C >= 900)
        lcd.print("Change up a gear");
        lcd.print(" ");
  if (UpDownMenu == 1)
      lcd.print("Engine Readings  ");
      lcd.print("                      ");
      delay(2000);
      RESETMenuName = 1;
    if (MenuID == 0) {
      lcd.print("01 RPM             ");
      if (RefreshCounter == RefreshCounterMax) {
        SentMessage = "01 0C";
        delay(50);
        ReadData();
    if (MenuID == 1) {
      lcd.print("02 IAT Temp        ");
        SentMessage = "01 0F";
        Serial.println("01 0F");
        delay(50);
        ReadData();
    if (MenuID == 2) {
      lcd.print("03 Ambient Temp    ");
        SentMessage = "01 46";
        Serial.println("01 46");
        delay(50);
        ReadData();
    if (MenuID == 3) {
      lcd.print("04 Throttle %      ");
        SentMessage = "01 11";
        Serial.println("01 11");
        delay(50);
        ReadData();
    if (MenuID == 4) {
      lcd.print("05 CAT 1 Temp      ");
        SentMessage = "01 3C";
        Serial.println("01 3C");
        delay(50);
        ReadData();
    if (MenuID == 5) {
      lcd.print("06 CAT 2 Temp      ");
        SentMessage = "01 3D";
        Serial.println("01 3D");
        delay(50);
        ReadData();
    if (MenuID == 6) {
      lcd.print("07 CAT 3 Temp      ");
        SentMessage = "01 3E";
        Serial.println("01 3E");
        delay(50);
        ReadData();
    if (MenuID == 7) {
      lcd.print("08 CAT 4 Temp      ");
        SentMessage = "01 3F";
        Serial.println("01 3F");
        delay(50);
        ReadData();
    if (MenuID == 8) {
      lcd.print("09 Coolant Temp    ");
        SentMessage = "01 05";
        Serial.println("01 05");
        delay(50);
        ReadData();
    if (MenuID == 9) {
      lcd.print("10 Vehicle Speed   ");
        SentMessage = "01 0D";
        Serial.println("01 0D");
        delay(50);
        ReadData();
    if (MenuID == 10) {
      lcd.print("11 Air Flow Rate  ");
        SentMessage = "01 10";
        Serial.println("01 10");
        delay(50);
        ReadData();
    if (MenuID == 11) {
      lcd.print("12 Barometric     ");
        SentMessage = "01 33";
        Serial.println("01 33");
        delay(50);
        ReadData();
    if (MenuID == 12) {
      lcd.print("13 EGT            ");
        SentMessage = "01 78";
        Serial.println("01 78");
        delay(50);
        ReadData();
    if (MenuID == 13) {
      lcd.print("14 Oil Temp       ");
        SentMessage = "01 5C";
        Serial.println("01 5C");
        delay(50);
        ReadData();
  if (UpDownMenu == 2)
      lcd.print("About By MV");
      lcd.print("\Chip V1.00 ");
      delay(2000);
      RESETMenuName = 1;
    lcd.setCursor(0, 0); lcd.print("System Version  ");
  //Restart RefreshCounter
  if (RefreshCounter >= RefreshCounterMax) {
    RefreshCounter = 0;
  delay(1);
//Read Data and act accordingly
void ReadData()
  BuildINString = "";
  while (Serial.available() > 0)
    inData = 0;
    inChar = 0;
    inData = Serial.read();
    inChar = char(inData);
    BuildINString = BuildINString + inChar;
  //if(BuildINString!=""){Serial.print(BuildINString);}
  BuildINString.replace(SentMessage, "");
  BuildINString.replace(">", "");
  BuildINString.replace("OK", "");
  BuildINString.replace("STOPPED", "");
  BuildINString.replace("SEARCHING", "");
  BuildINString.replace("NO DATA", "");
  BuildINString.replace("?", "");
  BuildINString.replace(",", "");
  //Serial.print(BuildINString);
  //Check which OBD Command was sent and calculate VALUE
  //Calculate RPM I.E Returned bytes wil be 41 0C 1B E0
  //RPM
  if (SentMessage == "01 0C")
    WorkingString = BuildINString.substring(7, 9);
    A = strtoul(WorkingString.c_str(), NULL, 16);
    WorkingString = BuildINString.substring(10, 12);
    B = strtoul(WorkingString.c_str(), NULL, 16);
    DisplayValue = ((A * 256) + B) / 4;
    DisplayString = String(DisplayValue) + " rpm               ";
    C = DisplayString.toInt();
  //Calculate Vehicle speed I.E Returned bytes wil be 41 0C 1B E0
  if (SentMessage == "01 0D")
    DisplayValue = A;
    DisplayString = String(DisplayValue) + " km/h              ";
  //Coolant Temp
  if (SentMessage == "01 05")
    DisplayValue = A - 40;
    DisplayString = String(DisplayValue) + " C                ";
  //IAT Temp
  if (SentMessage == "01 0F")
  //Air flow Rate
  if (SentMessage == "01 10")
    WorkingString = BuildINString.substring(11, 13);
    DisplayValue = ((A * 256) + B) / 100;
    DisplayString = String(DisplayValue) + " g/s            ";
  //Ambient Temp
  if (SentMessage == "01 46")
  //ENGINE OIL TEMP
  if (SentMessage == "01 5C")
  //Throttle position
  if (SentMessage == "01 11")
    DisplayValue = A * 100 / 255;
    DisplayString = String(DisplayValue) + " %              ";
  //Barometric pressure
  if (SentMessage == "01 33")
    DisplayValue = A;
    DisplayString = String(DisplayValue) + " kpa              ";
  //CAT 1 Temp //((A*256)+B)/10 - 40
  if (SentMessage == "01 3C")
    DisplayValue = ((A * 256) + B) / 10 - 40;
  //CAT 2 Temp //((A*256)+B)/10 - 40
  if (SentMessage == "01 3D")
  //CAT 3 Temp //((A*256)+B)/10 - 40
  if (SentMessage == "01 3E")
  //CAT 4 Temp //((A*256)+B)/10 - 40
  if (SentMessage == "01 3F")
void Bootup()
  lcd.print("Chip V1.00 ");
  for (int i = 0; i <= 1; i++)
    for (int j = 1; j <= 4; j++) // -/|\-
      if (j == 1) {
        lcd.print ("-");
        delay(200);
      if (j == 2) {
        lcd.print ("/");
        delay(200);
      if (j == 3) {
        lcd.print ("|");
        delay(200);
      if (j == 4) {
        lcd.print ("\\");
        delay(200);
  lcd.setCursor(2, 1);
  lcd.print("MV");
  delay(2000);
