OBD1 datalogging
Hay guys i working on project for datalogging from car ECU (Honda Civic 92 Chipped P28 Ecu)
Now my problem is when i plug in and my car don’t want to start seems like arduino sending some packets to ecu unless just reciving it :confused:
int Display_Rpm           = 0;
int Display_Vss           = 0;
float Display_BATT        = 0;
float Display_TPS         = 0;
float Display_IGN         = 0;
float Display_CONSUM       = 0;
#include <EEPROM.h>
#include <avr/pgmspace.h>
#include "Wire.h"
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
   Serial.begin(38400);
   Screen();
   GetData();
    GetData();
    Refresh_data();
Script no2 by Boulet Marc:
//Set Your Injector Size. Default : 240cc
int injsize = 240;
//Set the Datalogging Addresse to the correct one for your ECU (these addresse are for Crome >= 1.4, Work with P30 bin)
byte ADDR_RPMLOW  = 0x10;
byte ADDR_RPMHIGH = 0x11;
byte ADDR_TPS     = 0x15;
byte ADDR_INJLOW  = 0x17;
byte ADDR_INJHIGH = 0x18;
byte ADDR_IGN     = 0x19;
byte ADDR_VSS     = 0x1C;
byte ADDR_BATT    = 0x1F;
unsigned int ecuTimeout = 5000;
void GetData()
  //Get RPM&Speed Raw Values
  float speedRaw=ecuRead(ADDR_VSS);
  unsigned int rpmLowRaw=ecuRead(ADDR_RPMLOW);
  unsigned int rpmHighRaw=ecuRead(ADDR_RPMHIGH);
  int RPM = 1851562/((rpmHighRaw * 256) + rpmLowRaw);
  //Reset Rpm Display
  if (RPM < 0) {
    RPM = 0;
  } else if (RPM > 9999) {
    RPM = 9999;
  //Set RPM & Speed Display
  Display_Rpm     = RPM;
  Display_Vss     = speedRaw;         //KMH
  //Get&Set All Others Displays
    float tpsRaw=ecuRead(ADDR_TPS);
    unsigned int lowInjRaw=ecuRead(ADDR_INJLOW);
    unsigned int highInjRaw=ecuRead(ADDR_INJHIGH);
    unsigned int ignRaw=ecuRead(ADDR_IGN);
    float batteryRaw = ecuRead(ADDR_BATT);
    Display_BATT    = (26.0 * batteryRaw) / 270.0;
    Display_TPS     = constrain(tpsRaw, 0, 100);
    Display_IGN     = (0.25 * ignRaw) - 6;
    Display_CONSO   = constrain(calcConso(), 0.0001, 50.0);
    if(Display_Rpm<30)
      Display_Rpm = 0;
byte ecuRead(byte ecuAddress)
  Serial.write(ecuAddress);
  unsigned int time=0;
  while(Serial.available() == 0 && time < ecuTimeout) time+=1;
  if (time >= ecuTimeout) return 0x00;
  else return Serial.read();
float calcConso()
  float injValue = ((highInjRaw * 256) + lowInjRaw)  / 352;
  float dutyCycle = (Display_Rpm * injValue) / 1200;
  float hundredkm = ((60 / Display_Vss) * 100) / 60;     //minutes needed to travel 100km
  return (hundredkm * ((injsize / 100) * dutyCycle)) / 1000;
Screen Script:
void Screen()
  lcd.begin(20, 4);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("hY IM WORKING!");
  delay(1500);
  lcd.clear();
void Refresh_data()
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("R:");
    lcd.setCursor(2,0);
    lcd.print(Display_Rpm);
What is connected to the Serial port? If it IS the ecu, then, yes you are writing to the ecu.
