OBD2-HUB 9Pin T Cable for Mini ELM327 OBD SCAN with Bluetooth
Recently, we customer service received a super product combination, Mini ELM327 OBD SCAN Tool with OBD2-HUB 9Pin T Cable, which was successfully tested by our customers. They said the Mini ELM327 Bluetooth version could work very well with OBD2 9 Pin T Cablefor extending when they wanted to add GPS function to ELM327, and this bundle is in a good condition.
About New Super Mini ELM327 Bluetooth OBD-II OBD Can with Power Switch:
This new high-quality wireless scan tool super mini ELM327 with a turn on/ off switch can support phones with Android, Symbian system and Windows XP and WIN7 32bite computers to test OBD2 compliant vehicles for reading diagnostic trouble codes, both generic & manufacturer-specific, and displaying their meaning (over 3000 generic code definitions in the database). This new ELM327 OBD2 bluetooth is exquisite and convenient to use.
About Cableobd2 OBD to HUB 9Pin T Cable for ELM327:
OBD2-HUB 9Pin T cable is a splitter and can be used on any OBD II 16pin plug and drive devices,GPS, Navigation devices,adblue OBD2,nitroOBD2,ecoOBD2,etc.
-OBD2-HUB 9 Pin T Hub Cable can be used on any cars with 16pin OBD2 connectors -Matches all the vehicle communication standard -Cables used:3C/20AWG+13C/24AWG+AL -Working temperature:-40/+105oC -Cable length:40cm
9 PIN OUTS: 1. Vendor Option 9. Vendor Option 2. J1850 Bus + 10.J1850 BUS 3. Vendor Option 11.Vendor Option 4. Chassis Ground 12.Vendor Option 5. Signal Ground 13.Vendor Option 6. CAN (J-2234)High 14. CAN (J-2234)Low 7. ISO 9141-2K-Line 15. ISO-8141-2Low 8. Vendor Option 16. Battery Power
from:OBD2-HUB 9Pin T Cable for Mini ELM327 OBD SCAN with Bluetooth
