Hey guys,
I'm interested in trying to make this car gauge (actually it could be simpler, I just want fuel consumption info - instant and average):
https://www.justindepewdesign.com/single-post/2016/1/12/DIY-Aduino-Car-Gauge
However, I wonder if it is possible to adapt and use a bluetooth module instead of hardwiring. I ask that because I have an OBD2 ELM327 bluetooth connector already. So I could connect trough bluetooth with my arduino and make it read and display the information.
Would it be possible?? Anyone willing to help me??
Many thanks!!!
Marcos
I'm currently working on a very similar project with an ELM327. So far I've been able to create a Heads Up Display that shows the current speed (mph) and rpm "realtime".
Car HUD Build Log
Initial HUD Testing Vid
In order to do all of this, I designed a new library to interface with ELM327 scanners, called ELMduino .
Although I'm querying the car for different PIDs than what you want, you can still use the library to get those specific PIDs. In fact, I might just add the functionality in to directly query fuel consumption rates. Here is a list of PIDs queryable (directly from the ELMduino library):
const uint8_t SUPPORTED_PIDS_1_20 = 0; // 0x00 - bit encoded
const uint8_t MONITOR_STATUS_SINCE_DTC_CLEARED = 1; // 0x01 - bit encoded
const uint8_t FREEZE_DTC = 2; // 0x02 -
const uint8_t FUEL_SYSTEM_STATUS = 3; // 0x03 - bit encoded
const uint8_t ENGINE_LOAD = 4; // 0x04 - %
const uint8_t ENGINE_COOLANT_TEMP = 5; // 0x05 - °C
const uint8_t SHORT_TERM_FUEL_TRIM_BANK_1 = 6; // 0x06 - %
const uint8_t LONG_TERM_FUEL_TRIM_BANK_1 = 7; // 0x07 - %
const uint8_t SHORT_TERM_FUEL_TRIM_BANK_2 = 8; // 0x08 - %
const uint8_t LONG_TERM_FUEL_TRIM_BANK_2 = 9; // 0x09 - %
const uint8_t FUEL_PRESSURE = 10; // 0x0A - kPa
const uint8_t INTAKE_MANIFOLD_ABS_PRESSURE = 11; // 0x0B - kPa
const uint8_t ENGINE_RPM = 12; // 0x0C - rpm
const uint8_t VEHICLE_SPEED = 13; // 0x0D - km/h
const uint8_t TIMING_ADVANCE = 14; // 0x0E - ° before TDC
const uint8_t INTAKE_AIR_TEMP = 15; // 0x0F - °C
const uint8_t MAF_FLOW_RATE = 16; // 0x10 - g/s
const uint8_t THROTTLE_POSITION = 17; // 0x11 - %
const uint8_t COMMANDED_SECONDARY_AIR_STATUS = 18; // 0x12 - bit encoded
const uint8_t OXYGEN_SENSORS_PRESENT_2_BANKS = 19; // 0x13 - bit encoded
const uint8_t OXYGEN_SENSOR_1_A = 20; // 0x14 - V %
const uint8_t OXYGEN_SENSOR_2_A = 21; // 0x15 - V %
const uint8_t OXYGEN_SENSOR_3_A = 22; // 0x16 - V %
const uint8_t OXYGEN_SENSOR_4_A = 23; // 0x17 - V %
const uint8_t OXYGEN_SENSOR_5_A = 24; // 0x18 - V %
const uint8_t OXYGEN_SENSOR_6_A = 25; // 0x19 - V %
const uint8_t OXYGEN_SENSOR_7_A = 26; // 0x1A - V %
const uint8_t OXYGEN_SENSOR_8_A = 27; // 0x1B - V %
const uint8_t OBD_STANDARDS = 28; // 0x1C - bit encoded
const uint8_t OXYGEN_SENSORS_PRESENT_4_BANKS = 29; // 0x1D - bit encoded
const uint8_t AUX_INPUT_STATUS = 30; // 0x1E - bit encoded
const uint8_t RUN_TIME_SINCE_ENGINE_START = 31; // 0x1F - sec
const uint8_t SUPPORTED_PIDS_21_40 = 32; // 0x20 - bit encoded
const uint8_t DISTANCE_TRAVELED_WITH_MIL_ON = 33; // 0x21 - km
const uint8_t FUEL_RAIL_PRESSURE = 34; // 0x22 - kPa
const uint8_t FUEL_RAIL_GUAGE_PRESSURE = 35; // 0x23 - kPa
const uint8_t OXYGEN_SENSOR_1_B = 36; // 0x24 - ratio V
const uint8_t OXYGEN_SENSOR_2_B = 37; // 0x25 - ratio V
const uint8_t OXYGEN_SENSOR_3_B = 38; // 0x26 - ratio V
const uint8_t OXYGEN_SENSOR_4_B = 39; // 0x27 - ratio V
const uint8_t OXYGEN_SENSOR_5_B = 40; // 0x28 - ratio V
const uint8_t OXYGEN_SENSOR_6_B = 41; // 0x29 - ratio V
const uint8_t OXYGEN_SENSOR_7_B = 42; // 0x2A - ratio V
const uint8_t OXYGEN_SENSOR_8_B = 43; // 0x2B - ratio V
const uint8_t COMMANDED_EGR = 44; // 0x2C - %
const uint8_t EGR_ERROR = 45; // 0x2D - %
const uint8_t COMMANDED_EVAPORATIVE_PURGE = 46; // 0x2E - %
const uint8_t FUEL_TANK_LEVEL_INPUT = 47; // 0x2F - %
const uint8_t WARM_UPS_SINCE_CODES_CLEARED = 48; // 0x30 - count
const uint8_t DIST_TRAV_SINCE_CODES_CLEARED = 49; // 0x31 - km
const uint8_t EVAP_SYSTEM_VAPOR_PRESSURE = 50; // 0x32 - Pa
const uint8_t ABS_BAROMETRIC_PRESSURE = 51; // 0x33 - kPa
const uint8_t OXYGEN_SENSOR_1_C = 52; // 0x34 - ratio mA
const uint8_t OXYGEN_SENSOR_2_C = 53; // 0x35 - ratio mA
const uint8_t OXYGEN_SENSOR_3_C = 54; // 0x36 - ratio mA
const uint8_t OXYGEN_SENSOR_4_C = 55; // 0x37 - ratio mA
const uint8_t OXYGEN_SENSOR_5_C = 56; // 0x38 - ratio mA
const uint8_t OXYGEN_SENSOR_6_C = 57; // 0x39 - ratio mA
const uint8_t OXYGEN_SENSOR_7_C = 58; // 0x3A - ratio mA
const uint8_t OXYGEN_SENSOR_8_C = 59; // 0x3B - ratio mA
const uint8_t CATALYST_TEMP_BANK_1_SENSOR_1 = 60; // 0x3C - °C
const uint8_t CATALYST_TEMP_BANK_2_SENSOR_1 = 61; // 0x3D - °C
const uint8_t CATALYST_TEMP_BANK_1_SENSOR_2 = 62; // 0x3E - °C
const uint8_t CATALYST_TEMP_BANK_2_SENSOR_2 = 63; // 0x3F - °C
const uint8_t SUPPORTED_PIDS_41_60 = 64; // 0x40 - bit encoded
const uint8_t MONITOR_STATUS_THIS_DRIVE_CYCLE = 65; // 0x41 - bit encoded
const uint8_t CONTROL_MODULE_VOLTAGE = 66; // 0x42 - V
const uint8_t ABS_LOAD_VALUE = 67; // 0x43 - %
const uint8_t FUEL_AIR_COMMANDED_EQUIV_RATIO = 68; // 0x44 - ratio
const uint8_t RELATIVE_THROTTLE_POSITION = 69; // 0x45 - %
const uint8_t AMBIENT_AIR_TEMP = 70; // 0x46 - °C
const uint8_t ABS_THROTTLE_POSITION_B = 71; // 0x47 - %
const uint8_t ABS_THROTTLE_POSITION_C = 72; // 0x48 - %
const uint8_t ACCELERATOR_PEDAL_POSITION_D = 73; // 0x49 - %
const uint8_t ACCELERATOR_PEDAL_POSITION_E = 74; // 0x4A - %
const uint8_t ACCELERATOR_PEDAL_POSITION_F = 75; // 0x4B - %
const uint8_t COMMANDED_THROTTLE_ACTUATOR = 76; // 0x4C - %
const uint8_t TIME_RUN_WITH_MIL_ON = 77; // 0x4D - min
const uint8_t TIME_SINCE_CODES_CLEARED = 78; // 0x4E - min
const uint8_t MAX_VALUES_EQUIV_V_I_PRESSURE = 79; // 0x4F - ratio V mA kPa
const uint8_t MAX_MAF_RATE = 80; // 0x50 - g/s
const uint8_t FUEL_TYPE = 81; // 0x51 - ref table
const uint8_t ETHONOL_FUEL_PERCENT = 82; // 0x52 - %
const uint8_t ABS_EVAP_SYS_VAPOR_PRESSURE = 83; // 0x53 - kPa
const uint8_t EVAP_SYS_VAPOR_PRESSURE = 84; // 0x54 - Pa
const uint8_t SHORT_TERM_SEC_OXY_SENS_TRIM_1_3 = 85; // 0x55 - %
const uint8_t LONG_TERM_SEC_OXY_SENS_TRIM_1_3 = 86; // 0x56 - %
const uint8_t SHORT_TERM_SEC_OXY_SENS_TRIM_2_4 = 87; // 0x57 - %
const uint8_t LONG_TERM_SEC_OXY_SENS_TRIM_2_4 = 88; // 0x58 - %
const uint8_t FUEL_RAIL_ABS_PRESSURE = 89; // 0x59 - kPa
const uint8_t RELATIVE_ACCELERATOR_PEDAL_POS = 90; // 0x5A - %
const uint8_t HYBRID_BATTERY_REMAINING_LIFE = 91; // 0x5B - %
const uint8_t ENGINE_OIL_TEMP = 92; // 0x5C - °C
const uint8_t FUEL_INJECTION_TIMING = 93; // 0x5D - °
const uint8_t ENGINE_FUEL_RATE = 94; // 0x5E - L/h
const uint8_t EMISSION_REQUIREMENTS = 95; // 0x5F - bit encoded
const uint8_t SUPPORTED_PIDS_61_80 = 96; // 0x60 - bit encoded
const uint8_t DEMANDED_ENGINE_PERCENT_TORQUE = 97; // 0x61 - %
const uint8_t ACTUAL_ENGINE_TORQUE = 98; // 0x62 - %
const uint8_t ENGINE_REFERENCE_TORQUE = 99; // 0x63 - Nm
const uint8_t ENGINE_PERCENT_TORQUE_DATA = 100; // 0x64 - %
const uint8_t AUX_INPUT_OUTPUT_SUPPORTED = 101; // 0x65 - bit encoded
I hope this helps and if you have any questions, please let me know.
czu001
July 17, 2019, 1:36pm
3
Just curious, why not program your phone to read and display an OBDII? Unless you just need a very simple display, Android/iOS is probably better suited for a “fancy” UI. I’ve written a few apps that read OBDii. I’m guessing you’ll need an open stream (UART maybe?) that uses the BLE connection to parse/read PID info.
system
July 18, 2019, 10:22am
4
There are a few Android apps that read the OBD output via bluetooth. I tried out three.
John.
marcos_s_p:
Hey guys,
GitHub - Magister54/opengauge: Automatically exported from code.google.com/p/opengauge
Many thanks!!!
Marcos
It is Possible, by using a hc05 bluetooth module.Since you have posted it a while ago, i am hoping you are suucesful at it. if you are please share the codes pls? I am also trying to do it.
