Object counter « counting box »
Here is the full error message :
C:\Users\xxx\Documents\Arduino\libraries\LedControl\src\LedControl.cpp: In function 'setDigit.constprop':
C:\Users\xxx\Documents\Arduino\libraries\LedControl\src\LedControl.cpp:169:1: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/program files/windowsapps/arduinollc.arduinoide_1.8.21.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Erreur de compilation pour la carte Arduino Nano
Hope it will help more :slight_smile:
"internal compiler error"
That's about the last I expected to see! Exit status 1 is most commonly an undeclared variable, or closing } missing, something like that. Tbh no idea how to handle this one. Nasty. You just ran into a compiler bug.
Nagaro:
See http://gcc.gnu.org/bugs.html for instructions.
I would: not alter this code at all. Save a copy of the code which produced this error and supply the information requested as above.
I actually found on a forum on arduino a workaround for this bug (which is a compiler bug, you’re right. I changed the Arduino AVR Boards from version 1.6.23 to 1.6.21 in the preferences, and the issue doesn’t appear anymore. I’ll anyway submit the issue via the link as dougp proposed, and continue to write the code. And let’s see if the support team will solve the issue, that i can come back to the newer version of the Arduino AVR Board.
The bug itself is in gcc, not Arduino, but it's a very specific interaction between your code, the Arduino IDE and the compiler itself that triggers it.
So when submitting the bug add as much detail of your system as possible, especially the IDE version, so they have a chance of reproducing it, and hopefully fixing the problem.
Below the code i just finished. The “verify” buttons says it’s correct, but i don’t have yet all components to test it in real.
Can you already check it and tell me if you see any weird/useless/wrong thing inside ? Or any comment on how to make it better already ?
I put sometimes some comments when i was not sure about something. You’ll see :slight_smile:
Thank you very much for your support,
#include "LedControl.h"
LedControl lc = LedControl(4,5,6,4);
// ----- Code for Change State for FC-51
// this constant won't change:
const int  PinFC51 = 2;    // the pin that the pushbutton is attached to
const int  PinButtonPlus1 = 3;    // the pin that the pushbutton is attached to
const int  PinButtonMinus1 = 4;    // the pin that the pushbutton is attached to
const int  PinButtonReset = 5;    // the pin that the pushbutton is attached to
const int PinLED = 13;       // the pin that the LED is attached to
// Variables will change:
int buttonStateFC51 = 0;         // current state of the FC51
int lastButtonStateFC51 = 0;     // previous state of the FC51
int buttonStatePlus1 = 0;         // current state of the button
int lastButtonStatePlus1 = 0;     // previous state of the button
int buttonStateMinus1 = 0;         // current state of the button
int lastButtonStateMinus1 = 0;     // previous state of the button
int buttonStateReset = 0;         // current state of the button
int FC51 = 0;
int ButtonPlus1 = 0;
int ButtonMinus1 = 0;
int ButtonReset = 0;
// ----- Code for Max7219 + LEDs
int count = 0;
  // initialize the button pin as an input:
  pinMode(PinFC51, INPUT);
  pinMode(PinButtonPlus1, INPUT);
  pinMode(PinButtonMinus1, INPUT);
  pinMode(PinButtonReset, INPUT);
  // initialize the LED as an output:
  pinMode(PinLED, OUTPUT);
  // initialize serial communication:
    lc.shutdown(0,false); //to activate the led's
    lc.setIntensity(0,5); //to define the brightness of the led's
    lc.clearDisplay(0); //to cancel all info on the led's
    lc.setDigit(0,0,0,false); //to show 0 as initial number
    lc.setChar(0,1," ",false); //to show 0 as initial number
    lc.setChar(0,2," ",false); //to show 0 as initial number
    lc.setChar(0,3," ",false); //to show 0 as initial number
// if FC51 changes the state, it does +1
ChangeStateFC51();
if (FC51 == 1) {
  Plus1();
  Update7segment(count);
  FC51=0;
// if PushButtonPlus1 is active, it does +1
PushButtonPlus1();
if (ButtonPlus1 == 1) {
  Plus1();
  ButtonPlus1=0;
// if PushButtonMinus1 is active, it does -1
PushButtonMinus1();
if (ButtonMinus1 == 1) {
  Minus1();
  ButtonMinus1=0;
// if PushButtonReset is active, it resets to 0
PushButtonReset();
if (ButtonReset == 1) {
  Reset();
  ButtonReset=0;
void ChangeStateFC51() {
  // read the FC51 input pin:
  buttonStateFC51 = digitalRead(PinFC51);
  // compare the buttonState to its previous state
  if (buttonStateFC51 != lastButtonStateFC51) {
    // if the state has changed from low to high, increment the counter otherwise don't
    if (buttonStateFC51 == HIGH) {
      FC51=1;
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastButtonStateFC51 = buttonStateFC51;
void PushButtonPlus1() {
  // read the pushbutton input pin:
  buttonStatePlus1 = digitalRead(PinButtonPlus1);
  if (buttonStatePlus1 != lastButtonStatePlus1) {
    if (buttonStatePlus1 == HIGH) {
      ButtonPlus1=1;
    delay(50);
  lastButtonStatePlus1 = buttonStatePlus1;
void PushButtonMinus1() {
  buttonStateMinus1 = digitalRead(PinButtonMinus1);
  if (buttonStateMinus1 != lastButtonStateMinus1) {
    if (buttonStateMinus1 == HIGH) {
      ButtonMinus1=1;
    delay(50);
  lastButtonStateMinus1 = buttonStateMinus1;
void PushButtonReset() {
  buttonStateReset = digitalRead(PinButtonReset);
  if (buttonStateReset = 1) {
      ButtonReset=1;
    delay(50);
void Plus1()
  if (count=999) {
    count = 0;
    count = count + 1;
void Minus1()
  if (count<=0) {
    count = 0;
    count = count - 1;
void Reset()
  count = 0;
void Update7segment(int v) {
    int ones;
    int tens;
    int hundreds;
    //set the different numbers
    ones=v%10;
    v=v/10;
    tens=v%10;
    v=v/10;
    hundreds=v;
    //print the numbers digit by digit
    lc.shutdown(0,true); //to deactivate the calculation of the led's : usefull ??
    lc.setDigit(0,2,(byte)hundreds,false);
    lc.setDigit(0,1,(byte)tens,false);
    lc.setDigit(0,0,(byte)ones,false);
    lc.shutdown(0,false); //to activate all led's at once : usefull ??
All your variables are declared as (2-byte) integers. Pin numbers and such can't go higher than 255, or be negative, and so can be byte size, uint8_t or unsigned char.
Same for the boolean variables, they can be declared as type bool and only occupy one byte. This also aids comprehension - if you know something is a bool then you know it can only be in one of two states, true or false.
This is why you might see something like [color=blue]if(lastButtonStateFC51)[/color] instead of [color=blue]if(lastButtonStateFC51 == true)[/color]. They function alike it's just a bit of programming shorthand.
Quick message to tell you that i’ll be on holiday until end of this week. So nothing will happen on that project :-)
Thank you,
I’m proud to announced that the project seems to work pretty good ! See picture attached.
I corrected some pieces of code (still not changed it with the boolean variables).
I have 1 mini-issue : when i start the arduino, the variable FC51 always goes to 1 by itself, so the counter starts at 1. When i press reset, it goes to 0 and everything becomes normal.
Do you know why the FC51 reacts like that ? Is there a workaround that it doesn’t, or at least that the counter really starts at 0 and not 1 ? Maybe something to change in the code ?
Below the current code :
const int  PinFC51 = 12;    // the pin that the pushbutton is attached to
const int  PinButtonPlus1 = 8;    // the pin that the pushbutton is attached to
const int  PinButtonMinus1 = 9;    // the pin that the pushbutton is attached to
const int  PinButtonReset = 10;    // the pin that the pushbutton is attached to
const int PinLED = 4;       // the pin that the LED is attached to
int lastButtonStateReset = 0;     // previous state of the button
int FC51 = 0;
int count = 0;
    lc.setDigit(0,0,0,false); //to show 0 as initial number - hundreds
    lc.setChar(0,1,0,false); //to show 0 as initial number - tens
    lc.setChar(0,2,0,false); //to show 0 as initial number - units
    lc.setChar(0,3,0,false); //to show 0 as initial number - doesn't exist as 3-digit
ChangeStateFC51();
if (FC51 == 1) {
  Plus1();
  Serial.print("FC51=");
  Serial.println(FC51);
  FC51=0;
PushButtonPlus1();
  Plus1();
  Serial.print("ButtonPlus1=");
  Serial.println(ButtonPlus1);
  ButtonPlus1=0;
PushButtonMinus1();
  Minus1();
  Serial.print("ButtonMinus1=");
  Serial.println(ButtonMinus1);
  ButtonMinus1=0;
PushButtonReset();
  Reset();
  Serial.print("ButtonReset=");
  Serial.println(ButtonReset);
  ButtonReset=0;
      FC51=1;
    delay(50);
      ButtonPlus1=1;
    delay(50);
      ButtonMinus1=1;
    delay(50);
    if (buttonStateReset != lastButtonStateReset) {
  if (buttonStateReset == HIGH) {
      ButtonReset=1;
    delay(50);
  lastButtonStateReset = buttonStateReset;
void Plus1()
  if (count>=999) {
    count = 0;
    count = count + 1;
void Minus1()
  if (count<=0) {
    count = 0;
    count = count - 1;
void Reset()
  count = 0;
    int ones;
    int tens;
    int hundreds;
    ones=v%10;
    v=v/10;
    tens=v%10;
    v=v/10;
    hundreds=v;
    lc.setDigit(0,0,(byte)hundreds,false);
    lc.setDigit(0,2,(byte)ones,false);
  Serial.print("count : ");
  Serial.println(count);
  Serial.print("v : ");
  Serial.println(v);
  Serial.print("ByteHun : ");
  Serial.println((byte)hundreds);
  Serial.print("ByteTen : ");
  Serial.println((byte)tens);
  Serial.print("ByteOne : ");
  Serial.println((byte)ones);
I now need to build the real protoype, and see if 1 IR sensor works with the plastic bags, or if need to put more, or change to the piezoelectric one.
Thanks again for your help,
Nagaro: I have 1 mini-issue : when i start the arduino, the variable FC51 always goes to 1 by itself, so the counter starts at 1.
Which is button FC51 in the photo? What is the voltage on the PinFC51 when the switch is not actuated?
FC51 is actually the IR sensor (on the left on the picture). It receives the voltage from the computer, so 5V i believe. It’s not a big issue, but it would be better to have a clean code.
Thx
My guess: the Arduino starts up faster than the sensor, and upon starting up the sensor's output changes which is (correctly!) sensed by the Arduino.
Simple and often effective solution: add a delay() in setup(). Something like 100-1000 ms probably.
Good analysis, that’s probably the case. I’ll do so and see what happens :-) Thank you
I found the issue : the IR sensor is by default set as High. When an object is in front, it goes to Low. As i’m stating the « LastButtonStatus » as false by default, but the ir sensor itself is by default as high, the change status function runs directly when the arduino starts, and increments the count. To solve this, i just needed to change the « LastButtonStatus » from false to true, and here we go ;-)
I built a prototype of the box, and as expected, 1 sensor is good for normal stuff, but not enough to detect the bags falling. I’ll try to put directly 4 sensors as a cross, modify the code and see what’s the outcome. Otherwise i move to a piezoelectric sensor. The good thing is that the code won’t change that much :-)
I’ll keep you updated, like always.
Ah, well done. That doesn't explain, though, why it worked fine after a reset as you mentioned in #48.
Thanks. Actually it does : what i called « reset » was my reset button i’ve implemented, not the reset button directly on the arduino. Pressing this reset on the arduino was doing the issue too :-) Sorry, maybe i should have called my button different :-)
So now everything is fine, it only needs to work with this plastic bags with jewelry inside.
I made a first protoype of the box (in carton paper), having both ir sensors as i wanted first. It is working, but not accurate enough.
So i built a second protoype (see picture attached), using the idea of the ramp.
I figured out that both ir sensors is front of each other is actually working as a beam break (2 beam breaks, as there are 2 sensors). So i only need to hide 1 sensor (the small piece of carton on the left), and it’s working really accurate.
Now the problem is that the ramp makes the piece falling slowlier, which is not good for the productivity of counting. So i’ll not consider the ramp anymore, meaning noto considering using a piezoelectric sensor anymore.
So i’ll come back to the 1st idea, but putting the 2 sensors in front of each other.
I’ll also try to had 2 more sesnors, to have a bigger surface to cover.
Let’s see how it will work :slight_smile:
Little by little we are getting to the final solution.
A ramp does't preclude an impact sensor, as it's the hit of arrival you're measuring, not presence on the ramp.
You’re right, i didn’t consider this :slight_smile:
So piezo might be back again. Probably for the next gen :slight_smile:
I improved again the prototype, now using the duplo from my sons (see picture).
As i need a quite big whole for the bags, 4 IR sensors are not enough. I’ll need to put 6.
But the good thing is that only 3 sensors need to be connected to the arduino (the ones placed on the left). The 3 on the right are only there to create the break beam, and don’t need to be connected (so i don’t need the small carton to hide anymore).
I also put a delay of 150 ms for each sensor, so that the 3 sensors are not processed at the same time. I’ll need to test in real conditions to see if i need to extend this delay or not.
As i’m missing 2 IR sensors, i ordered new ones. So next post in a few days :slight_smile:
See you,
Get a second set that goes perpendicular, the gaps between the sensors are big enough for a small bag to slip through when aligned just right (this sooner or later will happen).
And why the delay? Only gives more opportunity for bags to slip through. I'd read the sensors as often as possible, but after detecting and counting a bag wait some time (300-500 ms maybe) or for the sensors to not detect the bag any more before counting a new one.
