object detect
I am trying to configure this circuit to give an object a three dimensional co ordinates. I need a hand with sensing side ways movement applied to the tip of the probe.
I think you need to tell us a helluvalot more as I have no clue of what you're talking about. Sensor? Object? Coordinates? Circuit with unspecified inputs? Why 2 inputs for 3 dimensions? What movement? Probe? Tip?
@gates. do you know what that thing actually is and how it is used?
Not possible.
The circuit is an instrumentation amp with ~700Hz low-pass action, gain of 45 and with a buffered reference input (top section). The two resistors in series on the reference input are mysterious. Such a circuit could
be used to present a +/-50mV differential signal to an Arduino analog input, for instance.
I was thinking of a circuit like this for a 3D digital probe for CNC.
IF your object is electrically conductive, then you only need to know when you touch the object. IF the object is non-conductive, then use a microswitch to detect contact with the object.
ALL the rest is software in your CNC machine.
Paul
@Gates: I was asking you, if you knew what that circuit was all about. I take your anser as "NO". I also Think that you do not know anything about CNC. Am I correct?
I do know what it does. Its in a book named "Practial Arduino" as a water tank senor.
Here is the next way I am looking at.
@zwieblum Well I have no problem building a CNC. I have a problem with getting accurate positioning. BTW what experience do you have with any type of Computer Numeric Control systems?
I equip schools with CNC machines and LinuxCNC :slight_smile:
Gates:
I do know what it does. Its in a book named “Practial Arduino” as a water tank senor.
What makes you think a “water tank sensor” (you didn’t even specify what exactly it senses - the presence of the tank or so?) has any relationship with getting 3D coordinates for a CNC machine?
relativity to pressure applied to the sensors tip when it touches the surface.
Gates:
These remarks start to make less and less sense.
Are you trying to get help with something or just trolling? I more and more have the feeling it's the second.
If you have ever played around with a CNC, you would know that it can be possible to go past your work area. The task that I am trying to achieve is to locate all objects with some precision within a calibration library.
So say your all objects aren't the material you set your probe for...wouldn't you what to test the surface that a probe is currently above.
Let's assume your touchprobe does work (which it does not - it's not a probe at all). Have you any idea how long that scan would take with a decent accuracy?
This is a classic "solution looking for problem" aproach.
Well you know the size of the object I intend on measuring? I never gave a height/ length/ cubic measurements/ total area size...etc
STOP trolling.
(This is a classic “solution looking for problem” aproach.)
I don’t know about that, approx input / output value.
? ? ? The "usual" aproach for inaccurate measurement is a linecamera + laser. You can get it off the shelf for "some" money. Or you use ans abitrary camer - just look at linuxcnc site and browse aroud. But nobody with his wits togather places a random number of workpeaces on random locations of the CNC workarea. That's just so outerworldisch that I cannot express the strangeness of such an idea with polite words.
Gates:
Don't you think it matters whether the object is the size of a cube of sugar or the size of a complete building?
(and yes, both can be 3D scanned just fine, but require a vastly different approach to it).
