Object Following Robot
Hello there all of you…I have built a robot using arduino uno, a pixy2 cam, a L298N motor controller and 2 DC motors in order to track objects of different colors in real time…The robot is working but not perfectly…I will appreciate if you have any recommendations for improvement of the code I have attached… Thank you
senior.ino (3.77 KB)
Welcome to the forums. It is much better to post your code using code tags so people can more easily see it
#include <PIDLoop.h> //###############################################
#include <Pixy2.h>   //IMPORTING LIBRARIES
Pixy2 pixy;          //###############################################
// ENA IN1 IN2 IN3 IN4 ENB
int myPins[6] = {5, 6, 7, 8, 9, 10};     //VARIABLES DECLARATION. MOTOR CONTROLLER CONNECTED TO PINS 5,6,7,8,9,10. eACH OF THEM REPRESENT THER PARTICULAR ORDER WHOCH IS  ENABLE INPUT 1,2,3,4 AND ENABLE
float deadZone = 0.15;                   //dead zone tha defines where the object will not move at all equals to 15%
int baseSpeed = 250;                   // base speed that the robot will run
int cont = 0;
int signature, x, y, width, height;
float cx, cy, area;
  Serial.print("Starting...\n");
  pixy.init();
  for (int i = 0; i < 6; i++) {
    pinMode(myPins[i], OUTPUT); //declaring all pins as output using a for loop
  float turn = pixyCheck(); //checking the value of the turn. how much deviation we have from the center using the pixy check function
  if (turn > -deadZone && turn < deadZone) { //applying deadzone
    turn = 0;
  if (turn < 0) {
    moveRobot(170, -80); //deciding how much to move the robot
  else if (turn > 0) {   //looking if the turn is positive or negative and moving, otherwise keep going forward
    moveRobot(-80, 170);
  else {
    moveRobot(70, 70); //takes the value of the left speed and the right speed
  delay(1);
float pixyCheck() {
  static int i = 0;
  int j;
  uint16_t blocks;
  char buf[32];
  // grab blocks!
  blocks = pixy.ccc.getBlocks();
  // If there are detect blocks, print them!
  if (blocks)
    signature = pixy.ccc.blocks[0].m_signature;
    height = pixy.ccc.blocks[0].m_height; //height of the object
    width = pixy.ccc.blocks[0].m_width; //width of the object
    x = pixy.ccc.blocks[0].m_x;//x value of the object
    y = pixy.ccc.blocks[0].m_y;//y value of the object
    cx = (x + (width / 2)); //center x position
    cy = (y + (height / 2)); //center y position
    cx = mapfloat(cx, 0, 320, -1, 1); // aplying normalization. If value is from 0-320 change from -1 to 1. This helps in the computation
    cy = mapfloat(cy, 0, 200, 1, -1);
    area = width * height;
    //Serial.print("sig: ");
    //Serial.print(signature);
    //Serial.print(" x:");
    //Serial.print(x);
    //Serial.print(" y:");
    //Serial.print(y);
    //Serial.print(" width: ");
    //Serial.print(width);
    //Serial.print(" height: ");
    //Serial.print(height);
    //Serial.print(" cx: ");
    //Serial.print(cx);
    //Serial.print(" cy: ");
    //Serial.println(cy);
  else {
    cont += 1;
    if (cont == 100) {
      cont = 0;
      cx = 0;
  return cx; //sending back the x location to tell our robot to turn in a particular direction whether is positive or negative
float mapfloat(long x, long in_min, long in_max, long out_min, long out_max)
  return (float)(x - in_min) * (out_max - out_min) / (float)(in_max - in_min) + out_min;
void moveRobot(int leftSpeed, int rightSpeed)
  if (leftSpeed >= 0) {
    digitalWrite(myPins[1], 0);
    digitalWrite(myPins[2], 1);
  else {
    digitalWrite(myPins[1], 1);
    digitalWrite(myPins[2], 0);
  if (rightSpeed >= 0) {
    digitalWrite(myPins[3], 0);
    digitalWrite(myPins[4], 1);
  else {
    digitalWrite(myPins[3], 1);
    digitalWrite(myPins[4], 0);
  analogWrite(myPins[0], abs(leftSpeed));
  analogWrite(myPins[5], abs(rightSpeed));
Describe what is not working perfectly.
Sorry, I am new to the forum..the problem is that the robot is very slow and also looses the object quite many times
I would suspect that it has to do with how the "pixy" library is working. I don't have any knowledge of that, but image recognition is not a trivial problem and doing any sort of image processing usually results in the recommendation to use a rPI.
Well the robot is already built and has to do with my senior project. If anyone knows how the code can be changed to improve performance I will appreciate it.
