Hello everyone,
How can we measure length, breadth and height of the object with ultrasonic sensor ?
Hello everyone,
Suppose that the sensor is in a fixed position facing a flat surface
You could take all 3 measurements at the same time if the object were placed in a corner instead of against a flat surface but you will need 3 sensors
I have 3 different sensors. Do I need to use any formula ?
If I told you that the distance to the wall was 30cm and with the object in place against the wall the distance to the object was 10cm could you calculate the object dimension in that direction
When you say 3 different sensors do you mean 3 sensors of the same type or something else ?
Yes it’s same type of sensors
That makes it easier
Can you measure the distance from the sensor to an object using one of them ?
How about the calculation I asked about in post #4 ?
Yes I can measure the distance
Post your code that does one measurement
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code
They typical ultrasonic sensor output cone is 15 degrees. The granularity of such measurements would not give a near accurate rendering of the object. Use LIDAR, I use a TFMiniP as a visual scanner for my hexapod, with a 2 degree beam width, I am able to discern a 2 inch pipe at 10feet. Better LIDAR's give better results.
This is code for distance
const int trigPin =9;
const int echoPin =10;
long duration;
int distance;
pinMode (trigPin, OUTPUT);
pinMode (echoPin, INPUT);
digitalWrite (trigPin, LOW);
delayMicroseconds (2);
digitalWrite (trigPin, HIGH);
delayMicroseconds (50);
duration = pulseIn (echoPin, HIGH);
distance = duration*0.034/2;
Serial.print ("Distance: ");
Serial.println (distance);
}[quote="zeel_749, post:1, topic:856435, full:true"]
Hello everyone,
[/quote]
Have you read the suggestions earlier in the topic ?
If you can measure from the sensor to a surface then you can measure to the face of an object placed on that surface and calculate the dimension of the object in that direction
Either place the object in each of the 3 orientations and measure each dimension one after the other, or set up the 3 sensors pointing to the 3 surfaces of a corner, place the object in the corner and measure all 3 dimensions at once.
Where are you stuck ?
