[object Object] error message
Hi, so I am using the example code "Temp and Humidity" from the example section, and It verifies just fine, but when I upload it just says [object Object] in the red bar above the compiler. I've read some other forums but none of them really give a straight answer. I'm currently using a chromebook, and an Arduino Uno. I've tried changing the code, defining a pin, but still the same output. I even re-wired my project, and still the same answer. Is there any reason to this? Help would be greatly appreciated, thanks!
I found multiple old reports of this error, and I concur.
The only one that was informative to me is here:
It is not clear to me whether [object Object] is a generic error that might have several completely unrelated changes. If so, the solution reported there might not be relevant at all. But at least it is worth a read to see if it provides the solution for you.
If not, I would recommend you to contact Arduino support via this form:
https://www.arduino.cc/en/contact-us
For the sake of cross-referencing all the related reports, I'll add the rest of the list:
