object variables not storing or returning values
Hello,
I've been having some difficulties with a class I made and I'm stumped... My variables don't seem to be storing their respective data. here is my class:
#ifndef WaterSensor_h
#define WaterSensor_h
#include "Arduino.h"
class WaterSensor {
  public:
  WaterSensor();
  String helloworld();
  void set(int pin, bool muxBool,int muxPin);//if either muxPin or pin doesn't apply enter arbitrary number, will not effect readings
  double getVWC();
  double getMilliVolts();
  void changeMilliVoltDenominator(double arg);
  void changeReferenceMilliVolt(double arg);
  void setPin();
  double sensorReadingFunction();
  void setSystemNumber(int x);
  void changeMuxArduinoPin(int pin);
  int getSystemNumber();
  void changeMuxSelectorPins(int select0, int select1, int select2, int select3);
 protected:
  private:
  double vwc;
  double _milliVolts;
  double populateMilliVolts();
  double populateVWC();
  double milliVoltDenominator;
  double referenceMilliVolt;
  int _pin;
  void readMux();
  double _sensorReading;
  bool _muxBool;
  int _muxPin;
  int muxArduinoPin;
  int systemNumber;
  int S0;
  int S1;
  int S2;
  int S3;
#endif
  WaterSensor.cpp - Library for communicating with analog Decagon soil Sensor.
  Created by Matt Hart, April 2, 2017.
  Released as Private.
#include "WaterSensor.h"
WaterSensor::WaterSensor(){
  double milliVoltDenominator=4095.0;
  double referenceMilliVolt=1.65;
  double vwc;
  double _milliVolts;
  int muxArduinoPin=A6;
  int S0=2;
  int S1=3;
  int S2=4;
  int S3=5;
String WaterSensor::helloworld(){
  return "hello world";
void WaterSensor::set(int pin, bool muxBool,int muxPin){
  _muxBool= muxBool;
  _muxPin=muxPin;
  pinMode(pin, INPUT_PULLUP);
  int _pin=pin;
  if (_muxBool==true && muxPin<5) {
    systemNumber=2;
  else if (_muxBool==true && muxPin>=5&&muxPin<10){
    systemNumber=3;
  else if (_muxBool==true&&muxPin>=10&&muxPin<15){
    systemNumber=4;
  else {
    systemNumber=1;
void WaterSensor::readMux(){
  int controlPin[] = {S0, S1, S2, S3};
  int muxChannel[16][4]={
    {0,0,0,0}, //channel 0
    {1,0,0,0}, //channel 1
    {0,1,0,0}, //channel 2
    {1,1,0,0}, //channel 3
    {0,0,1,0}, //channel 4
    {1,0,1,0}, //channel 5
    {0,1,1,0}, //channel 6
    {1,1,1,0}, //channel 7
    {0,0,0,1}, //channel 8
    {1,0,0,1}, //channel 9
    {0,1,0,1}, //channel 10
    {1,1,0,1}, //channel 11
    {0,0,1,1}, //channel 12
    {1,0,1,1}, //channel 13
    {0,1,1,1}, //channel 14
    {1,1,1,1}  //channel 15
  //loop through the 4 sig
  for(int i = 0; i < 4; i ++){
    digitalWrite(controlPin[i], muxChannel[_muxPin][i]);
  //read the value at the SIG pin
  double _sensorReading = analogRead(muxArduinoPin);
void WaterSensor::changeMuxSelectorPins(int select0, int select1, int select2, int select3){
  S0=select0;
  S1=select1;
  S2=select2;
  S3=select3;
void WaterSensor::setSystemNumber(int x){
  systemNumber=x;
int WaterSensor::getSystemNumber(){
  return systemNumber;
void WaterSensor::changeMuxArduinoPin(int pin){
     muxArduinoPin=pin;
double WaterSensor::sensorReadingFunction(){
     if (_muxBool==true){
     readMux();
     else{
      _sensorReading= analogRead(_pin);
    return _sensorReading;
double WaterSensor::populateMilliVolts(){
   double _milliVolts=_sensorReading * 1000.0 * (1.65 / 4095.0);
   return _milliVolts;
double WaterSensor::populateVWC(){
    double vwc=0.000992 * _milliVolts  - 0.45;
    return vwc;
double WaterSensor::getVWC(){
    populateVWC();
    return vwc;
  double WaterSensor::getMilliVolts(){
    return _milliVolts;
  void WaterSensor::changeMilliVoltDenominator(double arg){
    milliVoltDenominator=arg;
  void WaterSensor::changeReferenceMilliVolt(double arg){
    referenceMilliVolt=arg;
Here is my test arduino sketch
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
#include <WaterSensor.h>
WaterSensor sensor1;
WaterSensor sensor2;
// outputs
//multiplexer pins
const int S0=1;
const int S1=2;
const int S2=3;
const int S3=4;
sensor1.set(A0, false, 0);
sensor2.set(A1, false, 0);
Wire.begin();
  delay(3000);
  analogReadResolution(12);
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(S0, OUTPUT);
  pinMode(S1, OUTPUT);
  pinMode(S2, OUTPUT);
  pinMode(S3, OUTPUT);
  analogReference(AR_INTERNAL1V65);
  Serial.println((double) sensor2.populateMilliVolts());
  delay(10);
  Serial.println((double)sensor2.getMilliVolts());
 Serial.println((double)sensor2.sensorReadingFunction());
 Serial.println((String)sensor2.helloworld());
 Serial.println((double)sensor2.populateVWC());
  Serial.println((double)sensor2.getVWC());
and here is a little snippet of my serial monitor
hello world
-0.45
0.00
1650.00
0.00
3303.00
hello world
-0.45
0.00
1399.38
0.00
3631.00
hello world
-0.45
0.00
1190.66
Basically it seems like my milliVolts variable and my vwc variable are not storing any values. And I realize there are a few weird things in the class as I've been trying to figure it out and have messed with a few things...
Thanks for any help
  double vwc;
  double _milliVolts;
  int S0=2;
  int S1=3;
  int S2=4;
  int S3=5;
By re-declaring these you made them all local. So no values got saved in the class.
-jim lee
Oh man thank you so much, that was stupid.
