Objects in an array
I have a project with 6 buttons and 6 servo's and was wondering if it was possible to define the buttons in an array somethings like buttons[5] and servo[5]
Any help would be appreciated,
Yes, it is. But it would be buttons[6] and servo[6].
Ok so would it be something like
#define buttons[6] = {A0,A1,A2,A3,A4,A5}
No. You can not use the preprocessor for that.
pinType buttons[] = {A0,A1,A2,A3,A4,A5};
int numberOfButtons = sizeof buttons[] / sizeof buttons[0];
and… if they’re related to each other they could be in an array of structs…
(the general idea…)
struct thingtype {
  int buttonPin;
  Servo servo;
thingtype MyThing[6];
  MyThing[0].buttonPin = 2;
  MyThing[0].write(180);
… and so on…
These two statements confuse me, how can one distinguish between the button and the servo
MyThing[0].buttonPin = 2; MyThing[0].write(180)
Sorry, my typo…
MyThing[0].servo.write(180):
example of syntax only.
Looks like this thread got twisted in the wind.
Take a look at how GolamMostafa solved the display matrix here:
https://forum.arduino.cc/t/4-digit-7-segment-display-stopwatch/618192/5
Input is very similar methodology.
it depends on how you set up your array.
if you have just a array of servo[5] than it is a simple
servo[0].write(180);
if you create your own structure or class combining the button with the servo and call it for example "myThing" than you would introduce somthing like
myThing[0].write(180);
currentButtonState=myThing[0].read();
it depends on how you create the functionality of your "myThing".
if you show your code - help might get clearer for you.
   Model Railway Junction Robin/Ann
   Servo    5v
   Nano     ATMega328P (old bootloader) 5V (5V & gnd)
   Switch   3.3v
   Junction     Servo Pin     Switch pin
    1             D9            A0
    2             D8            A1
    3             D7            A2
    4             D5            A3
    5             D4            A4
    6             D3            A5
a
   Version 1.A
         REVIEWED:   Dec 12 2021
#include <VarSpeedServo.h>
//BUTTONS
#define button1   A0
#define button2   A1
//SERVO OBJECTS
VarSpeedServo myServo1;
VarSpeedServo myServo2;
//BUTTON STATES
int prevbuttonState1;
int prevbuttonState2;
int currbuttonState1;
int currbuttonState2;
//SERVO SPEED
int Speed = 10;
  //switches
  pinMode(button1, OUTPUT);
  pinMode(button2, OUTPUT);
  //servo
  setServo();// set according to the position of the buttons when we start up
}//end of setup-----------------------------------------------------------------------------
  // button states
  currbuttonState1 = digitalRead(button1);
  currbuttonState2 = digitalRead(button2);
  // which junction
  if (currbuttonState1 == HIGH && currbuttonState1 != prevbuttonState1) doJunction1(1);
  if (currbuttonState1 == LOW  && currbuttonState1 != prevbuttonState1) doJunction1(2);
  if (currbuttonState2 == HIGH && currbuttonState2 != prevbuttonState2) doJunction2(1);
  if (currbuttonState2 == LOW  && currbuttonState2 != prevbuttonState2) doJunction2(2);
}//end of loop----------------------------------------------------------------
//FUNCTIONS
void doJunction1(int Direction) {
  switch (Direction) {
    case 1:
      //STRAIGHT
      myServo1.write(0, Speed, true); myServo1.stop();
      prevbuttonState1 = currbuttonState1;
    case 2:
      //TURN LEFT
      myServo1.write(10, Speed, true); myServo1.stop();
    default:
}//end of doJunction1----------------------------------------------------------------
void doJunction2(int Direction) {
    case 1:
      //STRAIGHT
      myServo2.write(0, Speed, true); myServo2.stop();
      prevbuttonState2 = currbuttonState2;
    case 2:
      //TURN LEFT
      myServo2.write(10, Speed, true); myServo2.stop();
    default:
}//end of doJunction2----------------------------------------------------------------
void setServo() { // set the servo according to the
  if (currbuttonState1 == HIGH ) {
    myServo1.write(0);
    myServo1.attach(9);
  if (currbuttonState1 == LOW  ) {
    myServo1.write(10);
    myServo1.attach(9);
  if (currbuttonState2 == HIGH ) {
    myServo2.write(0);
    myServo2.attach(8);
  if (currbuttonState2 == LOW  ) {
    myServo2.write(10);
    myServo2.attach(8);
//attach(pin )  - Attaches a servo motor to an i/o pin.
//attach(pin, min, max  ) - Attaches to a pin setting min and max values in microseconds
//default min is 544, max is 2400
//write(value)     - Sets the servo angle in degrees.  (invalid angle that is valid as pulse in microseconds is treated as microseconds)
//write(value, speed) - speed varies the speed of the move to new position 0=full speed, 1-255 slower to faster
//write(value, speed, wait) - wait is a boolean that, if true, causes the function call to block until move is complete
//writeMicroseconds() - Sets the servo pulse width in microseconds
//read()      - Gets the last written servo pulse width as an angle between 0 and 180.
//readMicroseconds()  - Gets the last written servo pulse width in microseconds. (was read_us() in first release)
//attached()  - Returns true if there is a servo attached.
//detach()    - Stops an attached servos from pulsing its i/o pin.
//slowmove(value, speed) - The same as write(value, speed), retained for compatibility with Korman's version
//stop() - stops the servo at the current position
//sequencePlay(sequence, sequencePositions); // play a looping sequence starting at position 0
//sequencePlay(sequence, sequencePositions, loop, startPosition); // play sequence with number of positions, loop if true, start at position
//sequenceStop(); // stop sequence at current position
//wait(); // wait for movement to finish
//isMoving()  // return true if servo is still moving.
This is the code i think it should be simpler but still easy to maintain - a lot could be in arrays and for next loops. Just not sure on how to define the buttons, servo's in an array.
I have only coded the first two buttons as yet
Thank you for showing code - it helps.
Nevertheless I don't like to reverse engineer sketches.
Can you please describe what your software should do.
Please use as short sentences as possible.
and further on: please describe where
does come from. If it is an external library, give as an description where we can download it.
When a switch button is HIGH it turns a servo to the zero position, when LOW it turns the servo to set position in this case 10.
I can put most of the code in a for next loop with an array but am not sure how to do the button and servo objects.
https://forum.arduino.cc/t/varspeedservo-a-modified-servo-library-with-speed-control/61404
This is the link I used to obtain VARSPEEDSERVO
Thank you for your help.
I hope you understand, that I will not download a 10 year old library.
Anyway, for a short PoC the Servo lib provided in the IDE should do its job also.
This is a short procedural demo:
// When a switch button is HIGH it turns a servo to the one position, when LOW it turns the servo to set position in another position
// the sketch should be able to use several buttons/switches
// https://forum.arduino.cc/t/objects-in-an-array/935241/10
// by noiasca
#include <Servo.h>
constexpr byte left = 0;
constexpr byte right = 10;
struct Group {
  const byte buttonPin;
  const byte servoPin;
  int previousButtonState = LOW;
  Servo servo;
// constructor because of "missing" initialized variable servo
  Group(const byte buttonPin, const byte servoPin) :
    buttonPin(buttonPin), servoPin(servoPin)
Group group[] {
  {A0, 9},
  {A1, 8},
  {A2, 2},
  {A3, 3}
void readAndWrite()
  for (auto & i : group)
    int currentButtonState = digitalRead(i.buttonPin);
    if (i.previousButtonState != currentButtonState)
      i.previousButtonState = currentButtonState;
      Serial.print(F("set servo pin "));
      Serial.print(i.servoPin);
      if (currentButtonState == LOW)
        Serial.println(F(" to left"));
        i.servo.write(left);
        Serial.println(F(" to right"));
        i.servo.write(right);
  Serial.println(F("lot of servos"));
    i.servo.attach(i.servoPin);
    pinMode(i.buttonPin, INPUT_PULLUP);
  //group[0].servo.write(left);   // you could set the servos
  //group[1].servo.write(right);
  readAndWrite();
some comments:
  • you define a structure Group with all member variables you need for each instance of your button-servo combination
  • the structure needs a constructor also, - you will see why in the next step,
  • the group[ ] is an array of type Group. You initialize it with all your pins. previousButtonState gets initialized to LOW. But for "servo" you will need the constructor also, otherwise you will get a compiler warning.
  • readAndWrite() reads the switch/button and writes to the servo if there was a state change.
  • you do that for all instances - in my example for all four switch/servo in group.
  • please notice that I'm using the INPUT_PULLUP for the buttons/switches. You can change that according to your hardware/wiring to INPUT also.
  • you see: with arrays one more button/servo is only ONE line to add ...
  • finally, if you see that the first time
google for "auto range based for c++" ( I call it poor mans foreach ... but get serious explanations with your research).
I have learned from this posting and thank you for it. I was quite blown away when i saw this :
I did google it - would it be possible for you to interpret it into a standard for/next loop to help in understanding..
Thanks again for all your help .
Standard (whatever that means) for loop implementation
Then change all the 'i' references in the loop to "group[i]"
great now I get it - thanks
