Obstacle Avoidance Using IR Sensor and Ultrasonic
I am doing a small project about Obstacle Avoidance using both IR Sensor and Ultrasonic . I want to use both buzzer and vibrator motor to alarm and my problems are:
  1. I don't know how to code for the vibrator motor, the speed increases when the sensors come nearly to the obstacle.
  2. I dont know how to code for both IR and Ultrasonic work together with the same time, the same distance and then alarm.
  3. I saw on google that we use capacitor to reduce noise for IR sensor. Is it really worked?
Here is components:
IR sensor: Analog SHARP GP2Y0A21YK0F
Ultrasonic US-015
buzzer
Vibrating Motor 1027
Here is my code for the buzzer alarms:
#define trigPin 7
#define echoPin 6
#define buzzer 4
int val= 0;
int ir =0;
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(buzzer, OUTPUT);
  pinMode(ir, INPUT);
  long duration, distance;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
  int ir = analogRead(A0);  //read the sensor value
  int val= pow(3027.4/ir, 1.2134); //convert readings to distance(cm)
 if (val < 50 )
 tone(4,100);
  for (int i=val; i>10; i--)
    delay(10);
  noTone(4);
    delay(10);
    Serial.print(distance);
    Serial.println(" cm");
    Serial.print(val);
    Serial.println(" cm ir");
  delay(200);
int ir =0;
  pinMode(ir, INPUT);
You should NOT set Pin 0 (Serial RX) as an INPUT when you are using Serial. Same for Pin 1 (Serial TX).
You do not need to set Pin A0 to INPUT when you are using it for analog input.
Note: Unless you are using analogRead(), '0' and 'A0' mean different things.
You need to decide which digital pin will have the vibrator motor attached.
A good way to assign names to pin numbers is:
const byte NameOfPin = 2;
For example, in your sketch it would be:
const byte TriggerPin = 7;
const byte EchoPin = 6;
const byte BuzzerPin = 4;
const byte IRPin = A0;
Thank you so much for correcting me ! And I still wonder about question 2: how to code for both IR and Ultrasonic work together with the same time, the same distance and then alarm"
ktodaone:
Measure the distance with both.
If the distances are similar enough and close enough to cause alarm, sound the alarm.
Have you got the distance measurements working? Have you written a sketch that shows the two distances on Serial Monitor (or Serial Plotter)? The Ultrasonic reading is slower than the IR measurement so I would do that one first. With the two measuring systems showing values you can adjust your constants until they give the same distance.
johnwasser:
Hi sir,
I see , thank you so much! This is my update code for Ultrasonic , and for IR i just replace "distance" by "val" on "if" part . Each sensor still work well with their value "val" and "distance" . So i just can measure for each sensor not both, not in the same time they work together. I dont know how to combine sensors code working with the same code.
#define trigPin 7
#define echoPin 6
#define buzzer 4
int val= 0;
int ir =0;
  pinMode(ir, INPUT);
 if (distance < 50 )
 tone(3,500);
  for (int i=distance; i>0; i--)
    delay(10);
  noTone(3);
    delay(10);
    Serial.print(val);
  delay(100);
You could use the average of the two:
#define trigPin 7
#define echoPin 6
#define buzzer 4
int val = 0;
int ir = 0;
  pinMode(ir, INPUT);
  unsigned long duration;
  unsigned ultrasonic_distance;
  ultrasonic_distance = (duration / 2) / 29.1;
  unsigned ir_distance = pow(3027.4 / analogRead(A0), 1.2134); //convert readings to distance(cm)
  unsigned average_distance = (ultrasonic_distance + ir_distance) / 2;
  if (average_distance < 50)
    tone(3, 500);
    delay(10 * average_distance);
    noTone(3);
  Serial.print("ultrasonic_distance == ");
  Serial.print(ultrasonic_distance);
  Serial.print("ir_distance == ");
  Serial.print(ir_distance);
  Serial.print("average_distance == ");
  Serial.print(average_distance);
  delay(100);
