Obstacle avoidance
Ok, so I found this code and learned what it does, but unfortunately, I still can’t figure out how to change code so I only have to rely on one ping sensor. I really need help, and I’ve tried everything. I even learned Python so I could simplify and understand my code better. (I say my, it’s not mine, I borrowed the majority of it. ) I’d prefer if some of you guys could keep it pretty humane with your comments.Here is the code. Not my comments. Please be nice, I’m a noob.
//Sketch written by ImM//rRoboto to convert an RC truck into a robot using 3 PING sensors,
//an Arduino UNO and a //SEEED Studio Motor Shield. It is built upon PING example code by
//Tom Igoe and a motor //shield tutorial sketch by SEEED Studio.
int pinI1=8;//define I1 interface
int pinI2=11;//define I2 interface
int speedpinA=9;//enable motor A
int pinI3=12;//define I3 interface
int pinI4=13;//define I4 interface
int steerpinB=10;//enable motor B
int speed_drive =420;//define the speed of drive motor
int speed_steer =1524;//define the speed of steering motor
const int pingPin_R = 7;//sets the pin for the PING sensor on the right side of the car
const int pingPin_C = 6;//sets the pin for the PING sensor in the center side of the car
const int pingPin_L = 5;//sets the pin for the PING sensor on the left side of the car
long duration_C, inches_C,duration_R, inches_R,duration_L, inches_L;
pinMode(pinI1,OUTPUT);
pinMode(pinI2,OUTPUT);
pinMode(speedpinA,OUTPUT);
pinMode(pinI3,OUTPUT);
pinMode(pinI4,OUTPUT);
pinMode(steerpinB,OUTPUT);
int i;
int j = 1;
delay(5000);
for(i=0; i<1; i*1){
j++;
getping_all();
//all clear, no obstacles within 30" in any direction
if(inches_C >= 30 && inches_R >= 30 && inches_L >= 30)
forward();
//obstacle(s) within 0-6" range
else if (inches_L < 6 || inches_C < 6 || inches_R < 6)
stop();
backward();
delay(1500);
stop();
if(j%3 == 0){ //This if/else statement is designed to build a little “randomness”
back_right(); //into the robot’s movements, so it is less likely to become stuck
back_right(); //in a loop, performing the same actions over and over which only.
left();
j=1;
else{
back_left();
back_left();
right();
//obstacle(s) within 6"-12" range
//obstacle on left and center and right
else if (inches_R < 12 && inches_C < 12 && inches_L < 12)
stop();
backward();
delay(1500);
back_left();
stop();
right();
forward();
Character limit :slight_smile:
Next half
//obstacle on center OR left and right
else if (inches_L >= 12 && inches_R >= 12 && inches_C < 12 ||
inches_C >= 12 && inches_R < 12 && inches_L < 12)
stop();
backward();
delay(1500);
back_left();
stop();
right();
forward();
else if (inches_R >= 12 && inches_C < 12 && inches_L < 12)
stop();
backward();
delay(1500);
back_left();
//obstacle on right and center
else if (inches_L >= 12 && inches_C < 12 && inches_R < 12)
stop();
backward();
delay(1500);
back_right();
//obstacle on right
else if (inches_L >= 12 && inches_C >= 12 && inches_R < 12)
left();
left();
//obstacle on left
else if (inches_R >= 12 && inches_C >= 12 && inches_L < 12)
right();
right();
//obstacle(s) within 12"-30" range
else if (inches_R >= 30 && inches_C < 30 && inches_L < 30)
right();
right();
else if (inches_L >= 30 && inches_C < 30 && inches_R < 30)
left();
left();
//obstacle on right and left
else if (inches_C >= 30 && inches_L < 30 && inches_R < 30)
forward();
//obstacle on right
else if (inches_L >= 30 && inches_C >= 30 && inches_R < 30)
left();
//obstacle on left
else if (inches_R >= 30 && inches_C >= 30 && inches_L < 30)
right();
else if (inches_L >= 30 && inches_R >= 30 && inches_C < 30)
if(j % 2 == 0){
left();
j=1;
else{
right();
void forward()
{// turns on drive motor in forward and leaves it on
analogWrite(speedpinA,speed_drive);//inputs speed_drive value to set the speed
digitalWrite(pinI2,LOW);//turn DC Motor A move anticlockwise
digitalWrite(pinI1,HIGH);
void backward()//
{// turns on drive motor in reverse and leaves it on
digitalWrite(pinI2,HIGH);//turn DC Motor A move clockwise
digitalWrite(pinI1,LOW);
void right()//
analogWrite(steerpinB,speed_steer);
digitalWrite(pinI4,HIGH);//turn DC Motor B move clockwise
digitalWrite(pinI3,LOW);
forward();
delay(300);
analogWrite(steerpinB,LOW);
void back_left()//
delay(250);
backward();
stop();
delay(250);
void left()//
digitalWrite(pinI4,LOW);//turn DC Motor B move anticlockwise
digitalWrite(pinI3,HIGH);
forward();
delay(300);
void back_right()//
delay(250);
backward();
stop();
delay(250);
void stop()//stop both motors
digitalWrite(speedpinA,LOW);// Unenble the pin, to stop the motor.
digitalWrite(steerpinB,LOW);// Unenble the pin, to stop the motor.
void getping_C()//get distance from center PING
pinMode(pingPin_C, OUTPUT);
digitalWrite(pingPin_C, LOW);
delayMicroseconds(2);
digitalWrite(pingPin_C, HIGH);
delayMicroseconds(5);
pinMode(pingPin_C, INPUT);
duration_C = pulseIn(pingPin_C, HIGH);
inches_C = microsecondsToInches(duration_C);
void getping_R()//get distance from right PING
pinMode(pingPin_R, OUTPUT);
digitalWrite(pingPin_R, LOW);
digitalWrite(pingPin_R, HIGH);
pinMode(pingPin_R, INPUT);
duration_R = pulseIn(pingPin_R, HIGH);
inches_R = microsecondsToInches(duration_R);
void getping_L()//get distance from left PING
pinMode(pingPin_L, OUTPUT);
digitalWrite(pingPin_L, LOW);
digitalWrite(pingPin_L, HIGH);
pinMode(pingPin_L, INPUT);
duration_L = pulseIn(pingPin_L, HIGH);
inches_L = microsecondsToInches(duration_L);
void getping_all()
getping_C();
delay(2);
getping_R();
delay(2);
getping_L();
delay(2);
long microsecondsToInches(long microseconds){
return microseconds / 74 / 2;}
/* The above converts the time of the return to inches as explained here: http://learn.parallax.com/kickstart/28015
[/quote]
WHy does no one ever respond?
