Obstacle avoiding robot code (tsi electron)
#include <AFMotor.h>
#include <Servo.h>
#define TRIGGER_PIN 2  // Ultrasonic sensor trigger pin
#define ECHO_PIN 3     // Ultrasonic sensor echo pin
AF_DCMotor motor1(1);  // Motor 1 initialization
AF_DCMotor motor2(2);  // Motor 2 initialization
AF_DCMotor motor3(3);  // Motor 3 initialization
AF_DCMotor motor4(4);  // Motor 4 initialization
Servo servoMotor;      // Servo motor initialization
  // Initialize serial communication
  // Initialize ultrasonic sensor pins
  pinMode(TRIGGER_PIN, OUTPUT);
  pinMode(ECHO_PIN, INPUT);
  // Set motor speed
  motor1.setSpeed(200);
  motor2.setSpeed(200);
  motor3.setSpeed(200);
  motor4.setSpeed(200);
  // Attach servo motor to pin 9
  servoMotor.attach(9);
  // Read ultrasonic sensor distance
  long duration, distance;
  digitalWrite(TRIGGER_PIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGGER_PIN, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(ECHO_PIN, HIGH);
  distance = (duration / 2) / 29.1;
  // Print ultrasonic sensor distance
  Serial.print("Distance: ");
  Serial.println(distance);
  // Check if an obstacle is detected within 20 cm
  if (distance < 20) {
    // Obstacle detected, stop and turn
    motor1.run(RELEASE);
    motor2.run(RELEASE);
    motor3.run(RELEASE);
    motor4.run(RELEASE);
    // Rotate servo motor to 90 degrees
    servoMotor.write(90);
    // Move backward for 1 second
    motor1.run(BACKWARD);
    motor2.run(BACKWARD);
    motor3.run(BACKWARD);
    motor4.run(BACKWARD);
    // Rotate servo motor to -90 degrees
    servoMotor.write(-90);
    // No obstacle detected, move forward
    motor1.run(FORWARD);
    motor2.run(FORWARD);
    motor3.run(FORWARD);
    motor4.run(FORWARD);
Have you got a question ?
Motor shield is in use... Defines these pins...
// Arduino pin names for interface to 74HCT595 latch
#define MOTORLATCH 12
#define MOTORCLK 4
#define MOTORENABLE 7
#define MOTORDATA 8
[quote="arduinouser20007, post:1, topic:1222531"]
[/quote]
ChatGPT does not know you are using Uno/Nano.
O didn't understand :confused:
Okay the thing is that i am still a beginner in this field :flushed:
So thanks for letting me know that :smiling_face:
Thanks please is there any adjustment that is still needed for the code
The AF motor shield is using pins 12, 4, 7, and 8... you should have received instructions and possibly example sketches with your motor shield... maybe on paper, maybe online.
Oh I forgot to tell you i am using an adafruit motor driver shield so that is why the motor pins were defined that way. If it was a "shift register" you were right defining the pin connections as you did
Do you have a question?
Not really
