Obstacle-avoiding robot
Can some one please tell me what is wrong with my code. I am trying to make an Arduino robot that avoids obstacles using a ping sensor and two dc motors attached to the motor shield.
Here is the code: Ps: I combined two codes and edited it a little bit
#include <Streaming.h>
#define cout Serial
#define endl '\n'
#define pingPin 4 // Seeed ultrasonic sensor on pin D4.
#define BOUNDARY 30 // (cm) Avoid objects closer than 30cm.
#define INTERVAL 25 // (ms) Interval between distance readings.
// at 250 cm/s that's 6 cm
volatile unsigned long notstalled; // last time we know the robot was moving
const int
PWM_A = 3,
DIR_A = 12,
BRAKE_A = 9,
SNS_A = A0;
// Configure the A output
pinMode(BRAKE_A, OUTPUT); // Brake pin on channel A
pinMode(DIR_A, OUTPUT); // Direction pin on channel A
// Open Serial communication
Serial.println("Motor shield DC motor Test:\n");
// Set the outputs to run the motor forward
digitalWrite(BRAKE_A, LOW); // setting brake LOW disable motor brake
digitalWrite(DIR_A, HIGH); // setting direction to HIGH the motor will spin forward
analogWrite(PWM_A, 255); // Set the speed of the motor, 255 is the maximum value
delay(5000); // hold the motor at full speed for 5 seconds
Serial.print("current consumption at full speed: ");
Serial.println(analogRead(SNS_A));}
delay(INTERVAL); // Delay between readings.
distance = readDistance(); // Take a distance reading.
cout <<" f"<<distance;
Serial.println(distance); // Print it out.
while((distance >= BOUNDARY)&& //loop til an object is sensed
((millis()-notstalled)<1000)); //or the wheels stop moving
if ((millis()-notstalled)<=1000){ //if it's just an object
cout <<endl<<"bkp "<<endl;
backward(); // Move backward 750ms.
delay(750);
leftTurn(300);} // Turn left 300ms.
else{ //robot has stalled
cout<< '\n' <<"stalled" << '\n';
backward(); delay(1000); //longer backup
leftTurn(500); // bigger turn
}// end Main program
Moderator edit: Topic split from hijacked thread, title changed. Please use CODE TAGS when posting code. AWOL.
No, why don't you tell us what you (or the compiler) think is wrong with it?
Well, this part looks a bit dodgy since you aren't re-reading the distance inside the while loop:
Of course, it would be a lot easier to guess what's causing the problem if you told us what the problem was.
That "}" is problematical, I think.
Clever, the way it was hidden on the end of a non-blank line, where it shouldn't have been.
