I’m trying to make an obstacle void robot using an IR sensor, stepper motors, and micros. I’m at a loss in trying to get the robot to reverse direction after tripping the sensor. This program uses case structure with the first case being the robot moving forward and the second case of the robot reversing direction for a set period of time. However, it just quickly jumps between forward and reverse, it isn’t reversing for a set period of time. I’m using a ShieldBuddy that has three cores, but is programable using the Arduino IDE. The IR sensor resides in the second core (Core 1). The main program is in the first core and uses the sensor value. Void straight() and void turn() both function properly. Any help would be appreciated, including a different approach.
Chuck
//trying to establish program to avoid obstacles without using delay.
//Go forward until IR sensor hits threshold, then turn for two seconds
//Both the straight and turn programs work separately
const int motor1 = 5; // the number of the step pin
const int motor2 = 8; // the number of the step pin
int motor1State = LOW; // Set the initial state
int motor2State = LOW;
// constants won't change:
const long interval = 400; // Sets the speed of the stepper motors
const long turnSpeed = 500;
unsigned long currentPrevious = 0;
unsigned long previousMicros = 0;
unsigned long previousCycle = 0;
//unsigned long pause = 0;
const long TimeForward = 5000;
int forward = 2000;
int rotate = 5000;
int sensorpin = 2; // analog pin used to connect the sharp sensor
int val = 0; // variable to store the values from sensor(initially zero)
SerialASC.begin(9600);
//Motor 1
pinMode(6, OUTPUT); // Enable
pinMode(5, OUTPUT); // Step
pinMode(12, OUTPUT); // Dir (pin 4 was damaged - switched to 12)
digitalWrite(6, LOW); // Set Enable low
digitalWrite(12, HIGH); // Dir Motor 1
//Motor 2
pinMode(10, OUTPUT); // Enable
pinMode(8, OUTPUT); // Step Motor 2
pinMode(9, OUTPUT); // Dir Motor 2
digitalWrite(10, LOW); // Set Enable low
digitalWrite(9, HIGH); // Dir Motor 2
pinMode(13, OUTPUT);
{ int y;
unsigned long currentCycle = millis();
if (val <= 350) //val comes from the process running in Core 1
y = 0;
y = 1;
switch (y)
case 0: //On
straight();
case 1: //Off
if (currentCycle - previousCycle <= forward)
turn();
{ previousCycle = currentCycle;
void straight() {
unsigned long currentMicros = micros();
if (currentMicros - previousMicros >= interval)
previousMicros = currentMicros; // save the last time
if (motor1State == LOW && motor2State == LOW)
motor1State = HIGH;
motor2State = HIGH;
motor1State = LOW;
motor2State = LOW;
digitalWrite(motor1, motor1State);
digitalWrite(motor2, motor2State);
void turn() {
digitalWrite(9, LOW); // Dir Motor 2
if (currentMicros - previousMicros >= turnSpeed)
previousMicros = currentMicros; // save the last time you blinked the LED
if (motor1State == LOW && motor2State == LOW) // if the LED is off turn it on and vice-versa:
motor1State = HIGH;
motor2State = HIGH;
motor1State = LOW;
motor2State = LOW;
//*** Core 1 ***/
void setup1()
void loop1()
{ val = analogRead(sensorpin); // reads the value of the sharp sensor
// SerialASC.println(val); // prints the value of the sensor to the serial monitor
// delay(100); // wait for this much time before printing next value
/*** Core 2 ***/
/* CPU2 Uninitialised Data */
StartOfUninitialised_CPU2_Variables
/* Put your CPU2 fast access variables that have no initial values here e.g. uint32 CPU2_var; */
EndOfUninitialised_CPU2_Variables
/* CPU2 Initialised Data */
StartOfInitialised_CPU2_Variables
/* Put your CPU2 fast access variables that have an initial value here e.g. uint32 CPU2_var_init = 1; */
EndOfInitialised_CPU2_Variables
void setup2() {
// put your setup code for core 2 here, to run once:
void loop2() {
// put your main code for core 2 here, to run repeatedly:
