The function that deduces the maximum element from the array is never called hence I am unable to obtain the maximum element. What is happening?
Below is the code.
int Array [] = {};
int i;
int maximum (int Array[], int n) {
int max = 0;
Serial.print("in the maximum function");
for (int i = 0; i < n; i++ ) {
if ( Array[i] > max) {
max = Array[i];
Serial.print("The max value is: ");
Serial.println(max);
// int Array[] = {};
for (int i = 0; i < 10; i++) {
Array [i];
int num = random (0,9);
Array [i] = {num};
Serial.print(Array[i]);
Serial.print(",");
delay(1500);
int maximum (Array[i], 10);
Serial.println("Full Array");
delay(3000);
hi!
this won't make wha tyou want.
do you know what will be the "i" you transfer to the function?
maybe something like this :
maximum(Array[],10); without the int (you are declaring a diiferent function with same name with the "int" before)
EDIT: a cleaner solution should be to pass the first element (Array[0]) and the size of this array (with sizeof() ) as arguments for your function "maximum".
You could start with a function that accepts an array (or pointer to its first element) and its size separately.
int maximum_(int const arr[], size_t const n) {
// Note that `arr` needs to have at least one element.
int max_ {arr[0]};
for (size_t i {1}; i < n; ++i) {
if (arr[i] > max_) {
max_ = arr[i];
return max_;
If, additionally, you want to be able to deduce the size of the array automatically, you can add the following function.
Your code has a number of small and not-so-small errors. But the intent is clear, and the logic is sound.
You have already received some various advices. Food for thought no doubt, if not now then someday.
But today, here's your sketch, as close as I could leave it as I found it, with the errors changed into not-errors using only things it seems you know or are trying to learn about.
I will make you read through it, see anything marked "//...", a comment I put in where I had to make those adjustments.
// https://wokwi.com/projects/359387026908041217
// https://forum.arduino.cc/t/obtaining-the-maximum-element-from-an-array/1102930
int Array [10]; //... you need to, at some point, make room for N elements
int i;
//... the arguments can have any names you'd like
int maximum (int anArray[], int n) {
int max = 0;
Serial.println("in the maximum function:");
if ( anArray[i] > max) {
max = anArray[i];
Serial.print(" The (new) max value is: ");
//... you promised to return ann int, but failed to
return max;
//... statement does... absolutely nothing
// Array [i];
//... check random - the upper limit is not returned!
int num = random (0,10); //... random number 0..9 inclusive
Array [i] = {num};
Serial.print(",");
delay(150); //... life to short!
//... I moved this print statement. Sue me.
Serial.println(" Full Array ");
//... this is a declaration. it does not execute any code
// int maximum (Array, 10);
// you want to actually call the function you wrote, and assign the returned value value.
int theMaximum = maximum(Array, 10);
Serial.print(" maximum from function call ");
Serial.println(theMaximum);
delay(300); //... life too short!
It's fun to watch as it usually ends up finding a '9' to report out as the maximum. What are the odds? If you know about probability, you can calculate it. If not, you are very close to being able to run this for several thousands of times and count how often every 0..9 shows up...
the posted code doesn't compile, so can't be tested
the following is a more like declaration of a function, but still a invalid statement
it should be invoked with reference to the array, not a single element of the array
and with maximum() corrected to return the maximum value, that return value is ignored. so maybe
Serial.println (maximum (Array, 10));
the size of Array [] is zero. possibly int Array [10];
consider
int Array [10] = {};
int i;
int max = Array [0];
if ( Array[i] > max){
max = Array[i];
return max;
Array [i] = {num};
Serial.print(" ");
Serial.println ();
Serial.print ("max ");
@oqibidipo Thanks for that, I see a few constants I wasn't aware of, or had forgotten, that should replace constants I've created in my code. Useful, indeed.
Note that FLT_MIN is the smallest possible positive floatvalue. That means it's the smallest float greater than zero ... so like 2^(-126) or something.
I guess if you want the smallest negative float value it would be -FLT_MAX.
thank you all guys..... I solved it now. All your comments were handy.
A few things I should have done better in posting this question;
Explain precisely what I wanted to do even if the code seemed fairly straightforward.
Add enough comments within my code to explain it further.
I think my problem was how I was passing the arguments into the maximum function. I wasn't passing the arguments rightly. Also, I wasn't returning anything after the maximum function ran.
Worked very well. You did a very good job understanding my code. After reading the code again, I realized as straightforward as it was, I needed to add comments and explain what I was doing.
But your code really makes sense and does precisely what I was looking to do. My problem, I figured, was that I wasn't passing the right arguments to the Maximum function and I wasn't returning anything from the function.
Thank you for the help and thanks to the community.
Is there a way to add timestamps to these elements? Say, you want to ascertain when an element gets added to the array.
So the thing is, I have a sensor suit that spits data periodically. I put the data into an array with timestamps to show at what time the data was stored in the array. The maximum function then tells me what the maximum reading from the sensor was after the array gets full.
If this issue has already been delt with, I would like to see it if not, I would please need some help.
