Occasionnal incorrect values out of MPU6050
Hello,
Since some days, I'm stucked with my MPU6050 laying flat and still on my desk. For minutes or even for hours, it outputs correct 0° values. But at some point, it ouputs either -180° or +180°. Is this an issue with my own code or with my MPU chip?
I've used standard library, then an update, which seems to be here, plus now code lines from this example:
Whatever I use for code or library (the standard one or the update), I sometime get out either -180° or +180° instead of 0°. At some point, my output even gets stucked at -180° or +180° with my chip still at 0°. I've found a partial workaround, by resetting the FIFO after each packet I'm getting:
  while (!mpuInterrupt && fifoCount < packetSize) {
    if (mpuInterrupt && fifoCount < packetSize) {
      fifoCount = mpu.getFIFOCount();
    yield(); // Running threaded
  mpuInterrupt = false;
  mpuIntStatus = mpu.getIntStatus();
  if (mpuIntStatus & _BV(MPU6050_INTERRUPT_DMP_INT_BIT)) {
    mpu.getFIFOBytes(fifoBuffer, packetSize);
    mpu.resetFIFO();
    yield();
    // Keep 1/4 which is a rate of 25Hz
    if (!(sample++ % 4)) {
      mpu.dmpGetQuaternion(&q, fifoBuffer);
      mpu.dmpGetGravity(&gravity, &q);
      mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
      yield();
      max_roll[max_roll_recent_pointer++] = abs(ypr[1]);
      if (max_roll_recent_pointer == DATA_SAMPLES_ROLL)
        max_roll_recent_pointer = 0;
      if (ypr[1] > 0 )
        max_roll_trip_right = max(ypr[1], max_roll_trip_right);
      if (ypr[1] < 0)
        max_roll_trip_left = max(abs(ypr[1]), max_roll_trip_left);
I do not check for FIFO overflows. My CPU (Teensy 3.2 at 72MHz) is fast enough to handle the 100Hz interrupt and packet rate. Moreover, I do now resetFIFO(); after every packet I get.
If I remove that mpu.resetFIFO(); line, my MPU output works for a while, then suddenlly ends stucked at -180° or +180° for 0°, my MPU chip laying still and flat on my desk... With that line added, I still occasionnally get out -180° or +180° with my chip at 0°.
Any hints would be welcome.
Moreover, I've some additionnal questions regarding the MPU6050 and those same libraries and codes.
If my chip isn't at 0° on power up/start up, that current roll/picth angle is used as the 0° reference. Is an option available to force 0° roll/picth angle to be aligned with the chip at power up?
If my chip is laying on angle for a long period (half an hour or maybe more), my 0° drifts suddenly to that angle. Is an option available to keep the initial 0° reference?
Best regards
Short update. Seems to be my code, or the libraries I'm using together, not my MPU6050 chip. Still not knowing how to fix that, neither if I'll be able to fix it decently.
I've now used Arduino Scheduler, then tried TaskScheduler. Updates for my display also (SSD1327 128x128 OLED). Issue is the same.
If I place a resetFIFO(), occasionnally only some values get corrupeted. Without it and with the below code, I get outputs which quickly seem fully random out of the MPU6050 (laying still and flat on my desk):
MPU6050 connection successfulChecking hardware revision...
Revision @ user[16][6] = A5
Resetting memory bank selection to 0...
//           X Accel  Y Accel  Z Accel   X Gyro   Y Gyro   Z Gyro
//OFFSETS    -3138,     647,    1559,     100,      -7,      82
-0.01, roll max 0.01 0.01/0.00
0.00, roll max 0.01 0.01/0.01
-146.12, roll max 178.93 178.93/178.46
-176.90, roll max 178.93 178.93/178.46
-147.69, roll max 178.93 178.93/178.46
0.00, roll max 179.99 179.93/179.99
119.07, roll max 179.99 179.93/179.99
-137.14, roll max 179.99 179.93/179.99
Here only -0.01, roll max 0.01 0.01/0.00 is acceptable. From all my tests, the 0.00 lines seem to me also corrupted.
With the extra resetFIFO() line after every mpu.getFIFOBytes(fifoBuffer, packetSize);, it almost works. But the MPU6050 plus corresponding library and codes seem to work like expected only if I do disable the SSD1327 display updates (commenting out u8g2.sendBuffer();, which pushes an 8k RAM buffer to the OLED). 8K shall not the issue, the Teensy 3.2 has 64k RAM.
resetFIFO() only sends a message to the MPU...
void MPU6050::resetFIFO() {
    I2Cdev::writeBit(devAddr, MPU6050_RA_USER_CTRL, MPU6050_USERCTRL_FIFO_RESET_BIT, true);
So I may have a SSD1327 driver issue, maybe RAM allocation or RAM corruption issue in my tasked or threaded environment. The confusing part is that my issue causes the MPU collected data to vary fastly between -180/+180°:
So far, I believe my own code is almost clean. This is with TaskScheduler, but I have the same behaviour with Arduino Scheduler (for threads and yields), it seems that what is correctly gathered from MPU6050 gets corrupted on display/OLED updates:
// Debug and Test options
#define _DEBUG_
//#define _TEST_
#ifdef _DEBUG_
#define _PP(a) Serial.print(a);
#define _PL(a) Serial.println(a);
#else
#define _PP(a)
#define _PL(a)
#endif
#include <TaskScheduler.h>
#define INTERVAL_DISPLAY  (333L)
Scheduler runner;
#include <SPI.h>
#define __U8G2LIB_
#define CS_SSD1327          10
#define DC_SSD1327          6
#define RST_SSD1327         8
#ifdef __U8G2LIB_
#include <U8g2lib.h>
U8G2_SSD1327_WS_128X128_F_4W_HW_SPI u8g2(U8G2_R0,  CS_SSD1327, DC_SSD1327, RST_SSD1327);
#else
#include "SSD1327.h"
SSD1327 disp(CS_SSD1327, DC_SSD1327, RST_SSD1327);
#endif
#include <Wire.h>
#include "MPU6050_6Axis_MotionApps20.h"
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
MPU6050 mpu;
#define INTERRUPT_PIN       15
#define DATA_SAMPLES_ROLL 500
volatile float max_roll[DATA_SAMPLES_ROLL];
volatile int   max_roll_recent_pointer;
volatile float max_roll_trip_left, max_roll_trip_right;
// Callback methods prototypes
void tDisplayCallback();
void tMPUSetupCallback();
void tMPUInterruptCallback();
unsigned long tDisplay_interval = INTERVAL_DISPLAY;
// Tasks
Task tDisplay(tDisplay_interval, TASK_FOREVER, &tDisplayCallback, &runner, true);
Task tMPUSetup(TASK_IMMEDIATE, TASK_ONCE, &tMPUSetupCallback, &runner, true);
Task tMPUInterrupt(TASK_IMMEDIATE, TASK_ONCE, &tMPUInterruptCallback, &runner, false);
void dmpDataReady() {
  tMPUInterrupt.restart();
void tMPUInterruptCallback() {
  uint16_t              fifoCount = 0;     // count of all bytes currently in FIFO
  uint8_t               fifoBuffer[64]; // FIFO storage buffer
  static int            sample = 0;
  uint8_t mpuIntStatus;
  while (fifoCount < packetSize)
 //mpu.resetFIFO();
float ypr[3];           // [yaw, roll, roll]   yaw/roll/roll container and gravity vector
      // orientation/motion vars
      Quaternion q;           // [w, x, y, z]         quaternion container
      VectorInt16 aa;         // [x, y, z]            accel sensor measurements
      VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
      VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
      VectorFloat gravity;    // [x, y, z]            gravity vector
      if (ypr[1] > 0 )
      if (ypr[1] < 0)
    if (!(sample % 100)) {
      float roll = 0;
      for (int i = 0; i < DATA_SAMPLES_ROLL; i++)
        roll = max(roll, max_roll[i]);
      _PP(ypr[1] * 180/M_PI);
      _PP(", roll max ");
      _PP(roll * 180/M_PI);
      _PP(" ");
      _PP(max_roll_trip_left * 180/M_PI);
      _PP("/");
      _PL(max_roll_trip_right * 180/M_PI);
int displayBlink;
void tDisplayCallback() {
  if (tDisplay.isFirstIteration()) {
#ifdef __U8G2LIB_
    u8g2.begin();
#else
#endif
#ifdef __U8G2LIB_
  u8g2.clearBuffer();
  u8g2.setFont(u8g2_font_logisoso16_tf);
  if (displayBlink++ % 2)
    u8g2.drawStr((128 - u8g2.getStrWidth("Active...")) / 2, (128 - u8g2.getMaxCharHeight() + u8g2.getMaxCharHeight()) / 2,
      "Active...");
  u8g2.sendBuffer();
#else
  disp.clearBuffer();
  if (displayBlink++ % 2) {
    disp.drawString(16, 16, "Hello", 0xF, 32);
    disp.drawString(16, 48, "World!", 0xF, 32);
  disp.writeFullBuffer();
#endif
void tMPUSetupCallback() {
  uint8_t devStatus;
  mpu.initialize();
  pinMode(INTERRUPT_PIN, INPUT);
  _PP(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
  devStatus = mpu.dmpInitialize();
  // supply your own gyro offsets here, scaled for min sensitivity
  mpu.setXGyroOffset(61);
  mpu.setYGyroOffset(-28);
  mpu.setZGyroOffset(-6);
  mpu.setZAccelOffset(1471);
  if (devStatus == 0) {
        // Calibration Time: generate offsets and calibrate our MPU6050
        mpu.CalibrateAccel(6);
        mpu.CalibrateGyro(6);
        mpu.PrintActiveOffsets();
    mpu.setDMPEnabled(true);
    packetSize = mpu.dmpGetFIFOPacketSize();
    max_roll_trip_left = 0;
    max_roll_trip_right = 0;
      max_roll[i] = 0;
    attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
void setup () {
  SPI.setSCK(14);
  SPI.begin();
  Wire.begin();
  Wire.setClock(400000L);
#if defined(_DEBUG_) || defined(_TEST_)
  while(!Serial);
#endif
  runner.startNow();
void loop () {
  runner.execute();
Now a last update. I've disconnected my OLED display and I do also see my issue.
To reproduce or test this, one shall only need a Teensy or a CPU with enough RAM plus a MPU6050.
I've moved the global vars to my MPU functions. Issue is the same. And commented my two workarounds:
 // Partial workaround, only some MPU data get corrupted (outputs 0.00):
 // mpu.resetFIFO();
  // Real workaround, comment out u8g2.sendBuffer(); but no more OLED updates:
  u8g2.sendBuffer();
Full code now being:
#define _DEBUG_
//#define _TEST_
#ifdef _DEBUG_
#else
#define _PP(a)
#define _PL(a)
#endif
Scheduler runner;
#include <SPI.h>
#define __U8G2LIB_
#ifdef __U8G2LIB_
#else
#endif
#include <Wire.h>
MPU6050 mpu;
// Tasks
static float max_roll[DATA_SAMPLES_ROLL];
static int   max_roll_recent_pointer;
static float max_roll_trip_left, max_roll_trip_right;
 // mpu.resetFIFO();
float ypr[3];           // [yaw, pitch, roll]   yaw/roll/roll container and gravity vector
      if (ypr[1] > 0 )
      if (ypr[1] < 0)
       float roll = 0;
      _PP(", roll max ");
      _PP(" ");
      _PP("/");
int displayBlink;
#ifdef __U8G2LIB_
    u8g2.begin();
#else
#endif
#ifdef __U8G2LIB_
  u8g2.clearBuffer();
      "Active...");
  u8g2.sendBuffer();
#else
  disp.clearBuffer();
#endif
  uint8_t devStatus;
  mpu.initialize();
/*    max_roll_trip_left = 0;
      max_roll[i] = 0;
void setup () {
  SPI.setSCK(14);
  SPI.begin();
  Wire.begin();
  while(!Serial);
#endif
  runner.startNow();
void loop () {
  runner.execute();
I finally changed my code, which is now polling the MPU. Works much better.
u8g2.sendBuffer(); takes some 25ms to execute. That seemed somehow blocking with MPU interrupt every 10ms and MPU data gathering in my threaded code. Why I then saw +/-180° outputs remains unclear to me...
Now I still occasionnaly get weird data out of my MPU. I'm filtering that out:
15:46:03.787 -> Roll oops, was 0.00
15:46:53.791 -> Roll oops, was 47.86
15:50:22.823 -> Roll oops, was -147.74
15:51:03.802 -> Roll oops, was 171.34
15:52:04.777 -> Roll oops, was 158.80
15:52:37.839 -> Roll oops, was -156.34
15:55:32.803 -> Roll oops, was -153.75
15:56:38.766 -> Roll oops, was 0.03
15:58:10.796 -> Roll oops, was -0.00
15:59:37.787 -> Roll oops, was 0.06
16:00:40.833 -> Roll oops, was -0.24
16:00:59.795 -> Roll oops, was -151.81
16:01:09.789 -> Roll oops, was -173.81
16:03:27.795 -> Roll oops, was -0.00
16:04:31.761 -> Roll oops, was -0.03
