Occupancy grid mapping
Hi!
I’m trying to understand occupancy grid mapping and its algorithm, however, I have a hard time understanding the notation and the concepts used here, so I could use some help.
Here is a link containing a few pictures where the algorithm is described.
  1. In the third picture at the bottom, the robot pose xt is described by a transpose of a matrix containing the x,y coordinates and the yaw angle of the robot. Why is the transpose of the matrix given here instead of a simple matrix?
  2. What exactly is the beam index k, mentioned in the same page?
  3. The variable alpha, mentioned in the last page, is said to be the width of the region, which, as I understand, is the width of the cone of the sensor as it considers an ultrasonic sensor. It is then said that “In line 7, it returns the prior for occupancy in log-odds form whenever the cell is outside the measurement range of this sensor beam, or if it lies more than alpha/2 behind the detected range zkt .” Is the variable zkt just a simple scalar value representing the distance in the case of a range sensor? Furthermore, in a situation where the sensor is perpendicular to some object to which the distance is measured, alpha is said to be the horizontal width of the measurement beam (if I understand correctly). But then, in the quoted text, alpha/2 is used in context of a ‘vertical’ distance or y coordinate by saying “if it lies more than alpha/2 behind the detected range zkt”. Does this mean that the alpha variable is used in both the considerations of width of the beam (x coordinate) and the variance of the distance to the object (y coordinate)?
  4. What does the index ‘j’ mean? It’s found in the last page in the pseudo-code line 5. Does the theta j,sens correspond to the angle to which the sensor is to the object? If so, why is the function argmin used, since the argument is a scalar value, but the function argmin is used to find a minimum of a function where one variable is unknown?
I have some more questions, but I think that if I receive answers for these then I might be able to figure out the rest. If something that I have asked is unclear, I kindly ask you to mention it and I’ll try to be clearer.
Thank you!
