The is a pro mini (5V, 16Mhz). It's running the following sketch:
pinMode(A1, INPUT);
pinMode(2, OUTPUT); pinMode(3, OUTPUT); pinMode(4, OUTPUT); pinMode(5, OUTPUT);
pinMode(6, OUTPUT); pinMode(7, OUTPUT); pinMode(8, OUTPUT); pinMode(9, OUTPUT);
pinMode(10, OUTPUT); pinMode(11, OUTPUT); pinMode(12, OUTPUT); pinMode(13, OUTPUT);
int sensorValue = analogRead(A1);
if(sensorValue > 520)
digitalWrite(2, 1);
if(sensorValue > 540)
digitalWrite(3, 1);
if(sensorValue > 560)
digitalWrite(4, 1);
if(sensorValue > 580)
digitalWrite(5, 1);
if(sensorValue > 600)
digitalWrite(6, 1);
if(sensorValue > 620)
digitalWrite(7, 1);
if(sensorValue > 640)
digitalWrite(8, 1);
if(sensorValue > 660)
digitalWrite(9, 1);
if(sensorValue > 680)
digitalWrite(13, 1);
if(sensorValue > 700)
digitalWrite(12, 1);
if(sensorValue > 720)
digitalWrite(11, 1);
if(sensorValue > 740)
digitalWrite(10, 1);
delay(1);
//Serial.println(sensorValue);
allOff();
void allOff()
digitalWrite(2,0); digitalWrite(3,0); digitalWrite(4,0); digitalWrite(5,0);
digitalWrite(6,0); digitalWrite(7,0); digitalWrite(8,0); digitalWrite(9,0);
digitalWrite(10,0); digitalWrite(11,0); digitalWrite(12,0); digitalWrite(13,0);
//delay(10);
Unfortunately, I have all the negative leads of the LED's connected together with the intention of grounding them which is why I cannot put them individually at the collector. Can I do the following to the same effect as the common-emitter arrangement?
Also, I'm running everything through USB so I can only supply up to 5V to anything. If I have 5V going to the collector and base, it shouldn't be a problem, right?
Thank you for you help!
