Why does pin D10 initialize "HIGH" on power up/reset?
I have a standalone ATMEG328 with an ENC28J60 connected to pin 13,12,11,8(CS) and a DS1307 to A4, A5 and and eight relays connected to the remaining pins. Everything works fine except for D10 which happen to have a relay on it driven by a pass transistor the same way as the other 7 relays. D10 initializes to HIGH on reset/power up! All the other pins stay low as expected. It will go low or high as instructed in the code without issue. It's on bootup that it is a problem. This isn't the result of my code, so I will try to explain in the next few test.
- I decide to explicitly set pin 10 low in setup but it still briefly blip high before going low as instructed in the code.
- I leave pin 10 out of the sketch all together, pin 10 still goes high on it's own
- Leaving ethercard out, I write a simple sketch to turn on and off all the relays one by one. Everything stays low on reset and work as expected. Hmmmm.
- Using the simple sketch in test 3 I added in ethercard library and initialize and assign a MAC and IP to the ENJ2860 and do nothing else with it. D10 goes high again. Looking like ethercard is the culprit
- I happened to have another project with the same setup but with two relays. One of the relays happens to be on D10 as well. Proceeded to apply test 1-4 from above with exact same result.
- Last and final straw. I cut the traces on the pcb and route pin D10 as the CS pin for the ENC28J60 and route pin D8 to the relay that use to be on D10. I specify pin D10 as CS "ether.begin(sizeof Ethernet::buffer, mymac, 10)" and everything works fine. Expecting that pin D8 or some other pin would go high now but nothing did. Happy to find a solution but puzzled.
Obviously I'm going to use pin 10 as CS from now on but I find this a bit odd since pin 8 is the default. From searching for an answer I know pin 10 use to be the CS pin for the ENC28J60 before ethercard came along so maybe something is buried in the code about pin 10. Anyone run into this issue before? or have a clue as to why?
