Odd behavior with Random
Hi all,
Ran across this in a longer piece. The sketch below reproduces the behavior. I wanted to initialize a variable to a random value before entering loop(), so did the obvious thing and put it in setup(). However...
  • If I use the function without a specified min value, it always returns zero.
  • If I specify a min of 1, it seems to behave normally--though then of course it never returns 0.
  • If I explicitly use a min of 0, it goes back to always returning 0.
  • If I put it in loop(), it behaves almost as expected--except that the first value returned is always 0. (Given this, I guess it should be no surprise that I never get anything but 0 out of setup().)
Can anybody tell me what I'm not getting here?
#define SEED_PIN A0
const byte QUANT_CHOICE = 7;
byte choice;
  Serial.begin(57600);
  randomSeed(analogRead(SEED_PIN));
  choice = random(QUANT_CHOICE);
  Serial.println(choice);
--Michael
The random() function does not actually return a random value. Rather, it returns a series of semi random numbers but always in the same sequence unless you have used the randomSeed() function to seed the "random" number generator to produce a different sequence.
A common way to use the randomSeed() function is to read the value of a floating analogue pin and use that with randomSeed(). Something like
randomSeed(analogRead(0));
UKHeliBob: A common way to use the randomSeed() function is to read the value of a floating analogue pin and use that with randomSeed(). Something like
And it is used exactly like this in the code presented.
If you'll take a look at the code, you'll see I did use randomSeed. I also tried seeding with different analog pins with the same result.
--Michael
This behaves better:
#define SEED_PIN A0
byte choice;
  choice = random(1000) % QUANT_CHOICE;
If you do an analogRead() on A0 do you get a steady value or does it vary ? Have you got anything connected to A0 ?
With a floating A0 I get 0 more than 6 times in a row with the original code.
Nothing connected to A0. analogRead varies a little--values clustered around 314, tending to become more stable over time.
--Michael
Whandall, thanks for your tip. I'll remember that one.
--Michael
A different working solution (with minimal changes to the original)
#define SEED_PIN A0
byte choice;
  randomSeed(((long)analogRead(SEED_PIN))<<16);
Came up with a work-around myself:
#define SEED_PIN A0
byte choice;
  choice = random(1, QUANT_CHOICE);
  choice--;
I still would like to understand, though. This doesn't appear to be how the function is supposed to work.
--Michael
Oops, meant to write choice = random(1, QUANT_CHOICE + 1);
--Michael
PS. Huh. Looked like it was working for a while, but now returned 0 on more than 20 trials in a row.
I think for the special value 7 (which is used by a %) there should be more noise in the upper part of the long that steps through the sequence.
Some more data to add to what you say.
Works: choice = random(1, 7); choice--; Works: choice = random(6);
Returns 0: choice = random(1, 8); choice--; Returns 0: choice = random(7);
--Michael
That emoticon is supposed to be a numeral 8. --Michael
Whandall,
Your suggestion at #9 always returns 254 for me.
--Michael
edit: Sorry, had a leftover line in my test code. It always returns 0. Your earlier suggestion does appear to return random values.
both variants end in the same % 7 operation.
long random(long howbig)
  if (howbig == 0) {
    return 0;
  return random() % howbig;
long random(long howsmall, long howbig)
  if (howsmall >= howbig) {
    return howsmall;
  long diff = howbig - howsmall;
  return random(diff) + howsmall;
#define SEED_PIN A0
byte choice;
  long anaVal = analogRead(SEED_PIN);
  randomSeed(anaVal<<16);
  long lRandom = random();
  Serial.print(F("A0 0x"));
  Serial.print(anaVal, HEX);
  Serial.print(F(" seeded<<16 Random 0x"));
  Serial.print(lRandom, HEX);
  Serial.print(F(" -> "));
  choice = lRandom % (long) QUANT_CHOICE;
A0 0x158 seeded<<16 Random 0x386800B0 -> 6
A0 0x141 seeded<<16 Random 0x526700A4 -> 4
A0 0x12F seeded<<16 Random 0x34A9009B -> 6
A0 0x120 seeded<<16 Random 0x5BE00093 -> 0
A0 0x115 seeded<<16 Random 0x9B3008E -> 5
A0 0x10A seeded<<16 Random 0x37860088 -> 4
A0 0x102 seeded<<16 Random 0x2A4E0084 -> 1
A0 0xFB seeded<<16 Random 0x5EBD0080 -> 5
A0 0xF6 seeded<<16 Random 0x167A007E -> 0
A0 0xF0 seeded<<16 Random 0xC90007B -> 3
A0 0xEC seeded<<16 Random 0x5F40079 -> 5
A0 0xEA seeded<<16 Random 0x2A60078 -> 6
A0 0xE7 seeded<<16 Random 0x3DB10076 -> 1
A0 0xE5 seeded<<16 Random 0x3A630075 -> 2
A0 0xE3 seeded<<16 Random 0x37150074 -> 3
A0 0xE1 seeded<<16 Random 0x33C70073 -> 4
A0 0xE2 seeded<<16 Random 0x756E0073 -> 4
A0 0xE0 seeded<<16 Random 0x72200072 -> 5
A0 0xDF seeded<<16 Random 0x30790072 -> 5
I only partially understand. I'm going to have to put some work into digesting this. Let me ask an elementary question:
After calling randomSeed, you call random() without any arguments ("long lRandom = random();). How does that work? Does it assume that its max value is the maximum value of a long?
Thanks for your help understanding this.
--Michael
edit: there's the damn emoticon again. " long lRandom = random() ; "
Look at the second part of #16, there is the code of the random functions with parameters.
I did not locate the source code of srandom(long) and random() yet.
