Odd behavior with Random
There are three problems at play…
  1. In general, using analogRead to initialize the random number generator is a bad idea…
    http://forum.arduino.cc/index.php?topic=66206.msg630884#msg630884
    This is a better choice…
    http://forum.arduino.cc/index.php?topic=66206.msg537783#msg537783
    In your case using analogRead is disastrous because of #3 below.
  2. Using modulus to reduce a Lehmer random number generator is a bad idea. But, the alternatives are annoying so a modulus is usually what is used. If you keep the most-significant-bits as the most-significant-bits instead of using modulus your problem will very likely disappear. However, if you insist on continuing to use analogRead a good hash function will work far better for what you are doing than a random number generator.
  3. Low seed values with some prime number divisors are poison with the Park-Miller generator. I’m too lazy to find the thread but there is a detailed discussion on this forum. Given your experience seven is very likely one of those prime number divisors.
Thanks. I've bookmarked those threads and will read through them when I get a chance. This isn't a mission-critical issue for me, just something I stumbled across while I was trying out various things in some test code.
Add one more item to the long (long) list of things to learn about. ;)
--Michael
Whandall: I did not locate the source code of srandom(long) and random() yet.
https://github.com/vancegroup-mirrors/avr-libc/blob/master/avr-libc/libc/stdlib/random.c
@mjward, you are welcome.
(reseedRandom updated with the new value. The remainder of this post is now trivia.)
Bear in mind you will need to use a much larger prime (the constant named HappyPrime in reseedRandom) It does not have to be a Happy Prime; just a prime number. Ideally you should use something slightly more than the "dead zone". I vaguely recall it being about 1.5 million. It's easy enough to write a little sketch to determine where it ends. The dead zone ends at 127,774...
  uint32_t seed;
  uint8_t choice;
  Serial.begin( 250000 );
  seed = 0;
  do
    ++seed;
    randomSeed( seed );
    choice = random( 7 );
    if ( (seed & 0x0000FFFF) == 0 )
      Serial.write( '.' );
  while ( choice == 0 );
  Serial.print( seed );
  Serial.print( F( " --> ") );
  Serial.print( choice );
If we stick with Happy Primes the nearest value greater than 127,774 is #1859 = 127807.
