CWMODE is set to 3
When I issue this AT Command
AT+CIPSTA_DEF="192.168.3.58","192.168.3.2","255.255.255.0"
The Response is
OK
But then if I immediately issue this command....
AT+CIPSTA?
This is the response.....
+CIPSTA:ip:"0.0.0.0"
+CIPSTA:gateway:"0.0.0.0"
+CIPSTA:netmask:"0.0.0.0"
Can anyone explain this ?
Thanks
Hold it...it "might" be because of the DHCP setting.......checking......
(I was fairly certain I had set it to "Static" earlier...)
When I issue this AT Command.....
AT+CWDHCP_CUR=0,2
I get this response.....
ERROR
So as of now, it's not letting me change the DHCP status to off or on
When I send this AT Command.....
AT+CWDHCP_CUR?
The Response is....
+CWDHCP_CUR:1
OK
So, it appears to be stuck in DHCP Mode ?
Juraj
5
quamikazee:
AT+CWDHCP_CUR=0,2
ERROR
2 is not a valid second parameter
first parameter is mode, second is enable/disable
