Odd page when I open up the IDE?
Sometimes when I open up the IDE I get this
The top line is not there?
I can't drag the box around or resize it as putting the pointer on the green line and trying to drag does nothing. The only way I can close it is by highlighting the icon on the task bar and clicking on the cross on the top right.
If I leave it a few minutes and then try to reopen it some times it opens up correct and some times it does this again? Any ideas ?
I am using windows 10 and the IDE version is 2.3.6 .
It's a known problem. Unfortunately it's difficult to analyse because of its intermittent nature.
See A setting has changed; post #4 has an explanation.
It happens on my system as well; closing it using task manager and starting the IDE again solves the issue most of the time, sometimes I have to try two or three times.
Can you open a new window
CTRL+N
Will that inhibit the same behaviour?
I can open a new window but it shows the same error.
Reading the other entries with similar problems I found this
in a post called Strange IDE behavior
I have noticed that when I first load the IDE I have to wait a while for it to fully load and if, whilst waiting, I open up the blank IDE to a full page that is when it happens. The afore mentioned link more or less explains it.
Do you trust that 11 year old info apply to your case?
You should read what @sterretje has to say in #2, especially the thread he refer to.
Thanks @sterretje and @ptillisch
Do you get the title bar back when you resize the window as described in that topic?
Note that the link refers to IDE 1.5.7; I've never used that (my first IDE was 1.6.6) but my IDE 1.x installations never had the problem.
