Not sure what else to call it. I have looked for an answer to this but not sure what to call it so I've decided to post here. I am running the Blink script on my ATMEGA328 board. Uploaded fine. The wierd thing is after about a minute - the rx light (recieve) light starts flashing and the board reboots.
I have the led in 13 and ground and the led is flashing - but stops flashing when the rx is flashing. It still seems to happen when the arduino and processing programmes are close... just incase you ask.
Hi also now on the button blink led script. I press the button a few times and the rx starts flashing...
Script below:
/* Blink LED when the button is pressed
int ledPin = 13; // choose the pin for the LED
int inPin = 7; // choose the input pin
// (for a pushbutton)
int val = 0; // variable for reading the pin status
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inPin, INPUT); // declare pushbutton as input
void loop(){
val = digitalRead(inPin); // read input value
// check if the input is HIGH (button released)
if (val == HIGH) {
digitalWrite(ledPin, LOW); // turn LED OFF
// blink the LED and go OFF
digitalWrite(ledPin, HIGH);
delay(200);
