Here's my calibration code (my own below)
// UTouch_Calibration (C)2013-2014 Henning Karlsen
#include <UTFT.h>
#include <UTouch.h>
// Define the orientation of the touch screen. Further
// information can be found in the instructions.
#define TOUCH_ORIENTATION LANDSCAPE
UTFT myGLCD(CTE50,25,26,27,28);
UTouch myTouch( 6, 5, 4, 3, 2);
// Declare which fonts we will be using
extern uint8_t SmallFont[];
uint32_t cx, cy;
uint32_t rx[8], ry[8];
uint32_t clx, crx, cty, cby;
float px, py;
int dispx, dispy, text_y_center;
uint32_t calx, caly, cals;
char buf[13];
myGLCD.InitLCD();
myGLCD.clrScr();
myGLCD.setFont(SmallFont);
myTouch.InitTouch(TOUCH_ORIENTATION);
dispx=myGLCD.getDisplayXSize();
dispy=myGLCD.getDisplayYSize();
text_y_center=(dispy/2)-6;
void drawCrossHair(int x, int y)
myGLCD.drawRect(x-10, y-10, x+10, y+10);
myGLCD.drawLine(x-5, y, x+5, y);
myGLCD.drawLine(x, y-5, x, y+5);
void readCoordinates()
int iter = 5000;
int failcount = 0;
int cnt = 0;
uint32_t tx=0;
uint32_t ty=0;
boolean OK = false;
while (OK == false)
myGLCD.setColor(255, 255, 255);
myGLCD.print("* PRESS *", CENTER, text_y_center);
while (myTouch.dataAvailable() == false) {}
myGLCD.print("* HOLD! *", CENTER, text_y_center);
while ((myTouch.dataAvailable() == true) && (cnt<iter) && (failcount<10000))
myTouch.calibrateRead();
if (!((myTouch.TP_X==65535) || (myTouch.TP_Y==65535)))
tx += myTouch.TP_X;
ty += myTouch.TP_Y;
cnt++;
failcount++;
if (cnt>=iter)
OK = true;
tx = 0;
ty = 0;
cnt = 0;
if (failcount>=10000)
fail();
cx = tx / iter;
cy = ty / iter;
void calibrate(int x, int y, int i)
drawCrossHair(x,y);
myGLCD.setBackColor(255, 0, 0);
readCoordinates();
myGLCD.print("* RELEASE *", CENTER, text_y_center);
myGLCD.setColor(80, 80, 80);
drawCrossHair(x,y);
rx[i]=cx;
ry[i]=cy;
while (myTouch.dataAvailable() == true) {}
void waitForTouch()
void toHex(uint32_t num)
buf[0] = '0';
buf[1] = 'x';
buf[10] = 'U';
buf[11] = 'L';
buf[12] = 0;
for (int zz=9; zz>1; zz--)
if ((num & 0xF) > 9)
buf[zz] = (num & 0xF) + 55;
buf[zz] = (num & 0xF) + 48;
num=num>>4;
void startup()
myGLCD.setColor(255, 0, 0);
myGLCD.fillRect(0, 0, dispx-1, 13);
myGLCD.drawLine(0, 14, dispx-1, 14);
myGLCD.print("UTouch Calibration", CENTER, 1);
myGLCD.setBackColor(0, 0, 0);
if (dispx==220)
myGLCD.print("Use a stylus or something", LEFT, 30);
myGLCD.print("similar to touch as close", LEFT, 42);
myGLCD.print("to the center of the", LEFT, 54);
myGLCD.print("highlighted crosshair as", LEFT, 66);
myGLCD.print("possible. Keep as still as", LEFT, 78);
myGLCD.print("possible and keep holding", LEFT, 90);
myGLCD.print("until the highlight is", LEFT, 102);
myGLCD.print("removed. Repeat for all", LEFT, 114);
myGLCD.print("crosshairs in sequence.", LEFT, 126);
myGLCD.print("Touch screen to continue", CENTER, 162);
myGLCD.print("INSTRUCTIONS", CENTER, 30);
myGLCD.print("Use a stylus or something similar to", LEFT, 50);
myGLCD.print("touch as close to the center of the", LEFT, 62);
myGLCD.print("highlighted crosshair as possible. Keep", LEFT, 74);
myGLCD.print("as still as possible and keep holding", LEFT, 86);
myGLCD.print("until the highlight is removed. Repeat", LEFT, 98);
myGLCD.print("for all crosshairs in sequence.", LEFT, 110);
myGLCD.print("Further instructions will be displayed", LEFT, 134);
myGLCD.print("when the calibration is complete.", LEFT, 146);
myGLCD.print("Do NOT use your finger as a calibration", LEFT, 170);
myGLCD.print("stylus or the result WILL BE imprecise.", LEFT, 182);
myGLCD.print("Touch screen to continue", CENTER, 226);
waitForTouch();
myGLCD.clrScr();
void done()
myGLCD.clrScr();
if (dispx==220)
myGLCD.print("To use the new calibration", LEFT, 30);
myGLCD.print("settings you must edit the", LEFT, 42);
myGLCD.setColor(160, 160, 255);
myGLCD.print("UTouchCD.h", LEFT, 54);
myGLCD.print("file and change", 88, 54);
myGLCD.print("the following values. The", LEFT, 66);
myGLCD.print("values are located right", LEFT, 78);
myGLCD.print("below the opening comment.", LEFT, 90);
myGLCD.print("CAL_X", LEFT, 110);
myGLCD.print("CAL_Y", LEFT, 122);
myGLCD.print("CAL_S", LEFT, 134);
toHex(calx);
myGLCD.print(buf, 75, 110);
toHex(caly);
myGLCD.print(buf, 75, 122);
toHex(cals);
myGLCD.print(buf, 75, 134);
myGLCD.print("CALIBRATION COMPLETE", CENTER, 30);
myGLCD.print("To use the new calibration", LEFT, 50);
myGLCD.print("settings you must edit the", LEFT, 62);
myGLCD.print("UTouchCD.h", LEFT, 74);
myGLCD.print("file and change", 88, 74);
myGLCD.print("the following values.", LEFT, 86);
myGLCD.print("The values are located right", LEFT, 98);
myGLCD.print("below the opening comment in", LEFT, 110);
myGLCD.print("the file.", LEFT, 122);
myGLCD.print("CAL_X", LEFT, 150);
myGLCD.print("CAL_Y", LEFT, 162);
myGLCD.print("CAL_S", LEFT, 174);
toHex(calx);
myGLCD.print(buf, 75, 150);
toHex(caly);
myGLCD.print(buf, 75, 162);
toHex(cals);
myGLCD.print(buf, 75, 174);
void fail()
myGLCD.clrScr();
myGLCD.print("UTouch Calibration FAILED", CENTER, 1);
myGLCD.print("Unable to read the position", LEFT, 30);
myGLCD.print("of the press. This is a", LEFT, 42);
myGLCD.print("hardware issue and can", 88, 54);
myGLCD.print("not be corrected in", LEFT, 66);
myGLCD.print("software.", LEFT, 78);
while(true) {};
startup();
drawCrossHair(dispx-11, 10);
drawCrossHair(dispx/2, 10);
drawCrossHair(10, 10);
drawCrossHair(dispx-11, dispy/2);
drawCrossHair(10, dispy/2);
drawCrossHair(dispx-11, dispy-11);
drawCrossHair(dispx/2, dispy-11);
drawCrossHair(10, dispy-11);
myGLCD.print("***********", CENTER, text_y_center-12);
myGLCD.print("***********", CENTER, text_y_center+12);
calibrate(10, 10, 0);
calibrate(10, dispy/2, 1);
calibrate(10, dispy-11, 2);
calibrate(dispx/2, 10, 3);
calibrate(dispx/2, dispy-11, 4);
calibrate(dispx-11, 10, 5);
calibrate(dispx-11, dispy/2, 6);
calibrate(dispx-11, dispy-11, 7);
