I'm having a problem with a value showing up in an array every time index [0] comes up.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {0xDE, 0xAB, 0x64, 0xEF, 0xFA, 0xED };
IPAddress ip(192, 168, 1, 100);
IPAddress subnet(255,255,255,0);
unsigned int localPort = 8888; // local port to listen on
// CONSTANTS
const byte totalAxes = 3; // Count from zero
const byte deadband = 20; // Create a deadband in the center of each pot
// VARIABLES
byte activeAxis = 0; // set this to start at zero, or the first axis
int axisZero = A4;
int axisOne = A1;
int axisTwo = A2;
int axisThree = A3;
int test;
// ARRAYS
int axesArray[] = {axisZero,axisOne,axisTwo,axisThree}; // Array of analog pins, one for each axis
int axesNewArray[3]; // an array to hold analog values until they can be compared to existing value
int axesOldArray[3]; // an array to hold the final analog raw value
int axesFinalArray[3]; // an array to hold the filtered and centered value
// SETUP
void setup(){
//Ethernet.begin(mac,ip,subnet);
//Udp.begin(localPort);
int a;
for (a = 0; a <= 3; a = a + 1) {
axesOldArray[a] = 0;
axesNewArray[a] = 0;
axesFinalArray[a] = 0;
// MAIN PROGRAM
void loop(){
Serial.print(" ++");
Serial.print(activeAxis);
Serial.println("++ ");
axesNewArray[activeAxis] = analogRead(axesArray[activeAxis]); // ...read the active pin
for (test = 0; test <= 3; test = test + 1) {
Serial.println(axesFinalArray[test]); // <--- why does activeAxis = 0 cause value 511 to show up in axis 0???
if(axesNewArray[activeAxis] >= axesOldArray[activeAxis] +2 || axesNewArray[activeAxis] <= axesOldArray[activeAxis] -2)
axesOldArray[activeAxis] = axesNewArray[activeAxis]; // copy new value into old value
axesFinalArray[activeAxis] = axesOldArray[activeAxis]; // make final value the same
axesFinalArray[activeAxis] /= 2; // make the range 0-511
axesFinalArray[activeAxis] -= 255; // make the center of the pot zero
// set zero value if in deadband
if(axesFinalArray[activeAxis] > -deadband && axesFinalArray[activeAxis] < deadband) // check to see if value is in deadband
axesFinalArray[activeAxis] = 0; // make the result equal zero in the center if it is in deadband
// set axis to go from 0 at center to 255 at extreme
if(axesFinalArray[activeAxis] < 0)
axesFinalArray[activeAxis] = map(axesFinalArray[activeAxis], -deadband, -255, 0, 255);
// need direction flag set here
else if(axesFinalArray[activeAxis] > 0)
axesFinalArray[activeAxis] = map(axesFinalArray[activeAxis], deadband, 255, 0, 255);
axesFinalArray[activeAxis] = 0; // set value to zero if in deadband
// index the pointer down to the next axis
if(activeAxis < totalAxes) // check if the active axis is the last one or not
++activeAxis; // increment it otherwise
activeAxis = 0; // set it back to zero
delay(250);
// FUNCTIONS
The serial monitor shows the following:
++0++ <-- when var(activeAxis) = 0...
511 <-- 511 shows up in axesFinalArray[0] every time
202
0
0
++1++
0 <-- but not here and no other index is affected
202
0
0
++2++
0
202
0
0
++3++
0
202
0
0
What in the world am I missing? Please don't laugh too hard at my code as I'm just learning. Also, it has evolved heavily as I've been tracking this bug for several hours now.
Any help would be appreciated.
Thanks,
Spugnoid
