Good morning all!
I’m new to the Arduino forums. I’m trying to use the Atmega328 chip off of the Uno board. I’ve uploaded my sketch and confirmed that it’s working while the chip is connected to the Uno board, but when I extract the chip and insert it into my project it’s no longer working. I’ve confirmed 5V at pins 7 & 20, and gnd tied to 8 & 22, so I know the power supply portion of the circuit is working. The only thing that I’m seeing as a possible issue is that I don’t have the 16.000MHz crystal on pins 9 and 10. I hadn’t thought about the crystal being required for such a basic circuit. Would this prevent the chip from functioning as intended?
Yes, that's the problem. You can run on the internal oscillator of the ATmega328P if you like but you need to have a clock source connected until you change the fuses to configure it to use the internal oscillator. The easiest way to do this is:
Put the ATmega328P back in the Uno so that it will have the resonator on the board as a clock source.
Connect an ISP programmer to the ICSP header on the Uno. If you don't have a dedicated programmer you can use an extra Arduino as an "Arduino as ISP".
