i want to make simple circuit when i press the push button relay output work for 5 min then turn off could any one help me
Hello davidrafek
Post your sketch, well formated, with well-tempered comments and in so called code tags "</>" and schematic to see how we can help.
Welcome to the forum
Is it the circuit or the sketch that you need help with ?
i want help with the sketch
What have you written so far? Post the code in code tags and let us know where you are stuck and we will try to help.
Which MCU are you using?
this is the code but it doesnt work propelly
const byte buttonPin = 2; // momentary button pin
const byte ledPin13=13; // LED (built-in on Uno)
unsigned long buttonPushedMillis; // when button was released
unsigned long ledTurnedOnAt; // when led was turned on
unsigned long turnOnDelay = 0; // wait to turn on LED (keep at 0 for this project)
unsigned long turnOffDelay = 5000; // Off-delay time (ms)
bool ledReady = false; // flag for when button is let go
bool ledState = false; // for LED is on or not.
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
long time = 0; // the last time the output pin was toggled
long debounce = 1; // the debounce time, increase if the output flickers
pinMode(buttonPin, INPUT);
pinMode(ledPin13, OUTPUT);
digitalWrite(ledPin13, LOW);
// get the time at the start of this loop()
reading = digitalRead(buttonPin);
// check the button
if (digitalRead(buttonPin) == HIGH) {
// update the time when button was pushed
buttonPushedMillis = currentMillis;
ledReady = true;
if (reading == HIGH && previous == LOW && millis() - time > debounce) {
if (state == HIGH)
state = LOW;
state = HIGH;
time = millis();
previous = reading;
// make sure this code isn't checked until after button has been let go
if (ledReady) {
//this is typical millis code here:
if ((unsigned long)(currentMillis - buttonPushedMillis) >= turnOnDelay) {
// okay, enough time has passed since the button was let go.
digitalWrite(ledPin13, HIGH);
// setup our next "state"
ledState = true;
// save when the LED turned on
ledTurnedOnAt = currentMillis;
// wait for next button press
ledReady = false;
// see if we are watching for the time to turn off LED
if (ledState) {
// okay, led on, check for now long
if ((unsigned long)(currentMillis - ledTurnedOnAt) >= turnOffDelay) {
ledState = false;
can be simpler
const byte PinButton = A1;
const byte PinLed = LED_BUILTIN;
unsigned long msecPeriod;
unsigned long msecLst;
byte butLst;
enum { Off = LOW, On = HIGH };
void
loop (void)
unsigned long msec = millis ();
if (msecPeriod && msec - msecLst >= msecPeriod) {
digitalWrite (PinLed, LOW);
msecPeriod = 0;
byte but = digitalRead (PinButton);
if (butLst != but) {
butLst = but;
delay (20);
digitalWrite (PinLed, HIGH);
msecPeriod = 3000;
void
setup (void)
Serial.begin (9600);
pinMode (PinLed, OUTPUT);
pinMode (PinButton, INPUT_PULLUP);
butLst = digitalRead (PinButton);
Needs to be pinMode(buttonPin, INPUT_PULLUP);
Needs to be if (digitalRead(buttonPin) == LOW)
Also connect your button to GND instead of +5V.
If you find this the solution, hit the solution box.
Just typing up my post when you did yours.
@theeccentricgenius , you do not know how the OP has wired te button; there might very well be a pull-down resistor in which case your statements don't solve the problem.
i want to skip any change any push button until time elapsed
based on my code, ignore button presses until msecPeriod becomes zero when the timer expires
code not working
what code doesn't work?
byte butLst;
void
loop (void)
msecPeriod = 0;
butLst = but;
delay (20);
msecPeriod = 3000;
void
setup (void)
did you try
if (butLst != but && ! msecPeriod) {
the problem that code works only for one time
msecLst wasn't being set along with msecPeriod
byte butLst;
void
loop (void)
Serial.println ("timer expired");
msecPeriod = 0;
butLst = but;
delay (20);
if (LOW == but && ! msecPeriod) {
Serial.println ("but press");
msecPeriod = 3000;
msecLst = msec;
void
setup (void)
i have code for lamp works for 10 sec after push button is released i want to ignore any change in the button until lamp is off
unsigned long turnOffDelay = 10000; // Off-delay time (ms)
// check the button
if (digitalRead(buttonPin) == LOW) {
ledReady = true;
if (state == HIGH)
state = LOW;
state = HIGH;
time = millis();
previous = reading;
if (ledReady) {
ledState = true;
ledReady = false;
if (ledState) {
ledState = false;
