Hi there,
I have some load cells that I am using with a INA125P. Unfortunately, I didn't realize until later that in order to get a high enough gain for the precision of the load cells to be useful, I end up oversaturating the 5V analog input into the Arduino using the INA125p without any load.
I excite the load cells at 10V. I can of course excite them at a lower voltage or lower the gain, but then the load cells end up as junk essentially. What I want to know is, how can I take the output it provides (i.e. let's say at 0g load it outputs 5V and at max load of 2kg it outputs 10V) and offset the 0 load case to zero (such that it is 0V and 5V instead)?
If I do this, will I encounter nonlinearities introduced into the system? The cells are relatively linear, so I wouldn't want to make calibration harder. I know I could theoretically just buy a high bit ADC, but I can't seem to find one with quite the gain I want. I would rather use digi pots to fine tune it better.
Thanks guys!
