Ohm meter accuracy
I would like to build a circuit that measures resistance of a coil but I have a few questions.
First I am wondering how much resolution I will be able to achieve. I would like to get at least .1 resolution but .01 would be even better.
This project will also read the voltage as well. I currently have a voltage divider setup and i have it reading pretty accurately. I would like the resistance to refresh even as voltage is passing thru the coil so I assume the voltage divider is probably not going to work because anything else I tap into that circuit will change my resistance of the voltage divider. Could I somehow use a transistor maybe to oscillate the ground on and off of the voltage divider and store the value while the ground is now connected to other voltage divider?
Here is what I had in mind
+------4.7k---------4.7k---------GND
Analog 0 - Voltage
+------10k---------Coil------GND
Analog 1 - Resistance
Or maybe there is a better way to do this altogether
most coils are only a few ohms, so your 10k resistor is way too high.
Are you sure its resistance of the coil you want to measure and not its inductive reactance? ( which is like resistance to AC signals, which depends on frequency )
Boffin1:
Yes definitely resistance I need. The coil is made from nichrome wire and I need to read from 1 to 5ohms in .1 increments.
See the attached for the basis of low resistance measurement.
http://www.aeroelectric.com/articles/LowOhmsAdapter_3.pdf
Also google for ESR meters for hints.
jolphil
