It has a switch-case followed by other state-operating code.
The switch-case part reads numbers and watches for EOL and entry limit and sets state to run the others that may change the state the switch-case sees next, it only runs when serial is available.
So I got more than a straight switch-case-pedigree state machine when I crossed a non-blocking serial data entry with an index sort example. It reads and sorts 20 ints at 250000 baud. Index limit is 256 using 768 bytes of RAM... maybe use memmove() instead of for-loops to move 40+ indexes.
// 223 -55 87 -126 9999 21000 -863 7512 444 11 -1260 -5078 768 -15 -2555 5 4 3 2 1
const byte maxElements = 20;
byte elements;
char entryState; // 8 bit signed, -128 to 127
byte index[ maxElements ];
int data[ maxElements ];
int accumulate;
char sign;
char ch;
byte i, j, k, flag;
void usage()
Serial.println( F( "Serial input sort example using indexes." ));
Serial.println( F( "Enter up to 20 whitespace separated ints." ));
Serial.println( F( "Make sure that your monitor adds newline.\n" ));
void show_indexes( byte count )
Serial.print( F( "indexes so far: " ));
for ( byte x = 0; x <= count; x++ )
Serial.print( index[ x ] );
if ( x < count )
Serial.print( F( "," ));
Serial.println( F( "\n" ));
byte a, b;
int xx, xy;
float ff;
long way;
Serial.begin( 250000 );
usage();
elements = entryState = 0;
if ( Serial.available() )
ch = Serial.read();
// Serial.print( F( "state " ));
// Serial.println( entryState, DEC );
switch ( entryState )
case -1 :
if (( ch >= '0' ) && ( ch <= '9' ))
accumulate = ch - '0'; // initial value set
entryState = 1; // get the rest of the digits
entryState = 2; // garbage following '-', ignore line
case 0 :
sign = 1;
else if ( ch == '\n' )
entryState = 3; // all entries finished
else if ( ch == '-' )
sign = -1;
entryState = -1;
case 1 :
if ( accumulate < 3275 ) // max int is 32768
accumulate *= 10;
accumulate += ch - '0';
accumulate *= int( sign );
data[ elements ] = accumulate;
elements++;
if ( ch == '\n' )
entryState = 10; // last number, all entries finished
else if ( elements == maxElements )
entryState = 9; // data array filled, ignore entered chars until newline.
entryState = 5; // this entry finished
case 2 : // looking for newline
if ( ch == '\n' )
entryState = 0; // finished, start over
usage();
// Serial.print( F( "entryState = " ));
// Serial.print( entryState, DEC );
// Serial.print( F( " entered = " ));
// Serial.print( accumulate );
// Serial.print( F( " elements = " ));
// Serial.println( elements );
if ( entryState > 4 ) // sort the new entry
i = elements - 1;
if ( elements > 0 )
flag = 0;
for ( j = 0; j < elements; j++ )
if ( data[ i ] < data[ index[ j ]] ) // new number is less than indexed value
// this should be a memmove()
for ( k = i; k > j; k-- ) // move finished indexes up
index[ k ] = index[ k - 1 ];
index[ j ] = i;
j = elements;
flag = 1;
if ( flag == 0 )
index[ i ] = i;
Serial.print( F( " " ));
show_indexes( i ); // see how the indexes get sorted as each data is added
if ( entryState > 5 || entryState == 3 ) // report
Serial.println( F( "Data as entered." ));
for ( i = 0; i < elements; i++ )
Serial.print( data[ i ] );
if ( i < elements - 1 )
Serial.println( F( "\n\nData as sorted." ));
Serial.print( data[ index[ i ] ] );
Serial.println( F( "\n\n" ));
elements = 0;
for ( i = 0; i < maxElements; i++ )
data[ i ] = 0;
index[ i ] = 0;
if ( entryState == 3 || entryState == 5 || entryState == 10 )
if ( entryState == 10 || entryState == 3 )
usage();
entryState = 0;
else if ( entryState == 9 )
entryState = 2;
} // end if ( Serial.available() )
} // end loop()
entered: 223 -55 87 -126 9999 21000 -863 7512 444 11 -1260 -5078 768 -15 -2555 5 4 3 2 1
Make sure that your monitor adds newline.223 indexes so far: 0
-55 indexes so far: 1,0
87 indexes so far: 1,2,0
-126 indexes so far: 3,1,2,0
9999 indexes so far: 3,1,2,0,4
21000 indexes so far: 3,1,2,0,4,5
-863 indexes so far: 6,3,1,2,0,4,5
7512 indexes so far: 6,3,1,2,0,7,4,5
444 indexes so far: 6,3,1,2,0,8,7,4,5
11 indexes so far: 6,3,1,9,2,0,8,7,4,5
-1260 indexes so far: 10,6,3,1,9,2,0,8,7,4,5
-5078 indexes so far: 11,10,6,3,1,9,2,0,8,7,4,5
768 indexes so far: 11,10,6,3,1,9,2,0,8,12,7,4,5
-15 indexes so far: 11,10,6,3,1,13,9,2,0,8,12,7,4,5
-2555 indexes so far: 11,14,10,6,3,1,13,9,2,0,8,12,7,4,5
5 indexes so far: 11,14,10,6,3,1,13,15,9,2,0,8,12,7,4,5
4 indexes so far: 11,14,10,6,3,1,13,16,15,9,2,0,8,12,7,4,5
3 indexes so far: 11,14,10,6,3,1,13,17,16,15,9,2,0,8,12,7,4,5
2 indexes so far: 11,14,10,6,3,1,13,18,17,16,15,9,2,0,8,12,7,4,5
1 indexes so far: 11,14,10,6,3,1,13,19,18,17,16,15,9,2,0,8,12,7,4,5
Data as entered.
223,-55,87,-126,9999,21000,-863,7512,444,11,-1260,-5078,768,-15,-2555,5,4,3,2,1Data as sorted.
-5078,-2555,-1260,-863,-126,-55,-15,1,2,3,4,5,11,87,223,444,768,7512,9999,21000Serial input sort example using indexes.
