OK, do not understand this ?
I have no problem programming any AVR that I have but when I try to program ATmega328p
i get this
Arduino: 1.6.10 (Windows 10), Board: "ATmega328 on a breadboard (8 MHz internal clock)"
avrdude: error: program enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
Error while burning bootloader.
now does that make any sense ?//*********************************
I have seen comments that 1.6.10 has the dubious reputation of being the worst release. Check the instructions for upgrading including board files etc. Edit: added source https://forum.arduino.cc/index.php?topic=419274.0
If that is not the issue, it could be the fuses on the chip have been set to require a crystal already which may prevent you using it with your current configuration .
mmm not real sure what it could be the funny thing is i figured out how to get a program to upload but then
the program wont run… weird stuff !! well… they are chinese AVR’S that could be the problem
Are you trying to burn a bootloader? Or upload your code?
upload code I am very puzzled never had this problem the code seems to upload but nothing happens its the same on all my 328's
I get that sort of thing when I have a loose wire.
You haven't given very much information about what you are doing but I guess you have got a ATMEGA328P on a bread board and are using an Arduino as an ISP. Is that it ?
If whatever you have connected to the 386 to 'program' it is using its pins 11, 12 and 13 then it is likely you are loading a boot loader, or loading a sketch which replaces the boot loader. If however pins 0 and 1 are used, it is likely you are attempting to load a sketch via the bootloader.
well guys i figured that one out kinda it was a combo of things loose wire & boot loader weird things still
happening PB0 NOT responding ehhhh ill figure it out as always just a lot of pondering
GOT IT ,GOT IT ,GOT IT it was just an arduino problem code:
#include <avr/io.h>
#include <util/delay.h>
#define F_CPU 8000000
int main(void)
DDRB=0b01000001;
while(1)
PORTB=0b01000001;
_delay_ms(500);
PORTB=0b00000000;
_delay_ms(500);
Well, seeing as that's not "Arduino code" and you're running a non-standard clock then I'm not surprised you had problems.
