I am trying to finish up my first project to control some off road lights on my truck. I have it doing most of what I want which is push the button once and 2 come on, push the button again and all come on. I would like to add push and hold to make the lights flash in various patterns. The problems I am having:
I can't figure out push and hold to do a separate function despite reading several tutorials. I just can't get my head around it and I want to make sure I know HOW it works so I can build on it.
I tried making the flashing light sequence and I ran into having to press the button several times to turn it off. From what I have read this is because of using delay. I read about flashing an LED without delay but again, I just can't figure it our for my setup which has 4 relays.
Lastly, I want to make sure I don't have to cycle through the flashing mode to turn everything back off. These are pretty high powered lights and I don't want to have them flash if I am in traffic or something, mainly that mode is for emergencies and learning some code.
Here is what I have so far, most of it derived from a ladyada tutorial:
/ * Off Road Lights, v 1.0 /
int switchPin = 3; // switch is connected to pin 3
int relay1Pin = 4; //relay one is on pin 4
int relay2Pin = 5; //relay two is on pin 5
int relay3Pin = 6; //relay three is on pin 6
int relay4Pin = 7; //relay four is on pin 7
int led1Pin = 8; //led indicator is pin 8
int val; // variable for reading the pin status
int val2; // variable for reading the delayed status
int buttonState; // variable to hold the button state
int lightMode = 0; // What mode is the light in?
pinMode(switchPin, INPUT); // Set the switch pin as input
pinMode(relay1Pin, OUTPUT);
pinMode(relay2Pin, OUTPUT);
pinMode(relay3Pin, OUTPUT);
pinMode(relay4Pin, OUTPUT);
pinMode(led1Pin, OUTPUT);
buttonState = digitalRead(switchPin); // read the initial state }
void loop(){ val = digitalRead(switchPin); // read input value and store it in val delay(10); // 10 milliseconds is a good amount of time val2 = digitalRead(switchPin); // read the input again to check for bounces if (val == val2) { // make sure consistent readings!
if (val != buttonState) { // the button state has changed
if (val == LOW) { // check if the button is pressed
if (lightMode == 0) { // if its off
lightMode = 1; // turn relay 1 and 4 on
if (lightMode == 1) { // if 1 and 4 are on
lightMode = 2; // turn 1, 2, 3 and 4 on
if (lightMode == 2) { // if all relays are on
lightMode = 3; // make it flash
if (lightMode == 3) { // if its flashing,
lightMode = 0; // turn light off!
buttonState = val; // save the new state in our variable
// Now do whatever the lightMode indicates if (lightMode == 0) { // all-off
digitalWrite(relay1Pin, LOW);
digitalWrite(relay2Pin, LOW);
digitalWrite(relay3Pin, LOW);
digitalWrite(relay4Pin, LOW);
digitalWrite(led1Pin, LOW);
if (lightMode == 1) { //Relay 1 and 4 on
digitalWrite(relay1Pin, HIGH);
digitalWrite(relay4Pin, HIGH);
digitalWrite(led1Pin, HIGH);
if (lightMode == 2) { // relay 1, 2, 3, and 4 on
digitalWrite(relay2Pin, HIGH);
digitalWrite(relay3Pin, HIGH);
} if (lightMode == 3) { // flash various patterns
delay(300);
delay(300);
delay(300);
delay(300);
Any help would be greatly appreciated. This is the first time I have touched any kind of code in my life and I want to have understanding before moving on. Thanks in advance.
