My recent IDE setup experience to share if useful...
I have recently started with Arduino while intending to a large automation engineering my new full green house, factually to optimize solar panels energy capturing and much more around.
So, I bought a simple basic Arduino UNO R3 /328p board from locals just for some first tests to control some power relays with various senzors and logical structures intending to buy a real one soon from its origin here!
By this occassion, even if lower expected (due to my old favourite OS Win7) but very happily... I have recently tested as very OK, the latest IDE 1.8.19 on my Windows 7 /64 bits for UNO R3 with CH340 chip to program scripts and then send and run them from my DELL laptop.
I simply plugged in USB port for both supply and control my new R3 CH340 !
ATTENTION! Original setup file for new 1.8.19 downloaded from arduino.cc does not properly install USB/COM serial drivers even if it claims it, for this notorious CH340 chipset board at least!
In fact I found no alike information concerning with which chipset type they use in the board they sale...???
So, webmaster should add this critical specification in order to avoid our loosing time to research how fix their unmatching setup files blindly downloaded from origin site!
Anyway, after a lot time lost research within various forums etc I have just succeeded to fix marvelously simply by found THIS LINK ! to get a real CH340 driver then to setup and all now works finelly !
Notice: after download and unzip, do not forget to change to compact successive folders you find and renamed it any you want but short lenght folder name in order to fix potentially driver setup error (because of that older times embedded installer that not find long strings folder names!)
Procedure above needs no uninstall, just run it even after driver failed normal IDE installation no matter its included other drivers!
New IDE 1.8.19 works like a charm now, fluency fast within new very well done compact and functional interface even if I will allways prefer older Windows 7 /64bits instead of all newer for a lot of critical things that experimented ITs already knows about...
Now, happy to donate and buy some more ! ![]()
