Hi guys.
I'm basically a noob in programming and I made this program like 4-5 years ago and it worked flawlessly and thus I never updated the code until when I tried to update the IP for it today due to moving flats, but now my code suddenly stopped wont work/compile without errors and I do not know what to do to fix it, and wondering if anyone is able to help. Maybe the library it is based on is outdated?
Premise:
It's a simple Webserver arduino with a ethernet shield. It hosts a basic HTTP website with 3 clickable buttons, each clickable buttons are linked to a radio transmitter, so when they are clicked a radio transmitter linked up to the arduino gets broadcasted and controls some wireless plugs around the house.
Code:
#include <SPI.h>
#include <Ethernet.h>
#include <NewRemoteTransmitter.h>
const unsigned long TRANSMITTER_ADDRESS = 27612394; //My personal transmitter address
const int PIN_TRANSMITTER = 8;
// Create a transmitter on address TRANSMITTER_ADDRESS, using digital pin PIN_TRANSMITTER to transmit,
// with a period duration of 260ms (default), repeating the transmitted
// code 2^3=8 times.
NewRemoteTransmitter transmitter(TRANSMITTER_ADDRESS, PIN_TRANSMITTER, 260, 3);
// Ethernet configuration
uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // MAC Address
uint8_t ip[] = { 192,168,1,230 }; // IP Address
EthernetServer server(80); // Server Port 80
// RemoteTransmitter configuration
// Connect Transmitter to Pin 11 and receiver to pin 2 (all digital)
// FAN 1 ON/OFF:
// Addr 27612394 unit 0 on, period: 267us.
// Addr 27612394 unit 0 off, period: 267us.
// FAN 2 ON/OFF:
// Addr 27612394 unit 1 on, period: 266us.
// Addr 27612394 unit 2 off, period: 267us.
// FAN 3 ON/OFF:
// Addr 27612394 unit 2 on, period: 267us.
// Addr 27612394 unit 1 off, period: 266us.
// ALL POWER OFF:
// Addr 27612394 group off, period: 267us.
Ethernet.begin(mac, ip);
server.begin();
pinMode(PIN_TRANSMITTER, OUTPUT);
char* command = httpServer();
void processCommand(char* command) {
if (strcmp(command, "1-on") == 0) {
transmitter.sendGroup(true); //All fans on
} else if (strcmp(command, "1-off") == 0) {
transmitter.sendGroup(false); //All fans off
} else if (strcmp(command, "2-on") == 0) {
transmitter.sendUnit(0, true);
} else if (strcmp(command, "2-off") == 0) {
transmitter.sendUnit(0, false);
} else if (strcmp(command, "3-on") == 0) {
transmitter.sendUnit(1, true);
} else if (strcmp(command, "3-off") == 0) {
transmitter.sendUnit(1, false);
} else if (strcmp(command, "4-on") == 0) {
transmitter.sendUnit(2, true);
} else if (strcmp(command, "4-off") == 0) {
transmitter.sendUnit(2, false);
* HTTP Response with homepage
void httpResponseHome(EthernetClient c) {
c.println("HTTP/1.1 200 OK");
c.println("Content-Type: text/html");
c.println();
c.println("<html>");
c.println("<head>");
c.println( "<title>MPC NEXA Webserver</title>");
c.println( "<style>");
c.println( "body { font-family: Arial, sans-serif; font-size:12px; }");
c.println( "</style>");
c.println("</head>");
c.println("<body>");
c.println( "<h1>MPC NEXA Webserver</h1>");
c.println( "<ul>");
c.println( "<li><a href=\"./?1-on\">Turn on power</a></li>");
c.println( "<li><a href=\"./?1-off\">Turn off power</a></li>");
c.println( "</ul>");
c.println( "<ul>");
c.println( "<li><a href=\"./?2-on\">Turn on power 1</a></li>");
c.println( "<li><a href=\"./?2-off\">turn off power 1</a></li>");
c.println( "<ul>");
c.println( "<li><a href=\"./?3-on\">Turn on power 2</a></li>");
c.println( "<li><a href=\"./?3-off\">turn off power 2</a></li>");
c.println( "<ul>");
c.println( "<li><a href=\"./?4-on\">Turn on power 3</a></li>");
c.println( "<li><a href=\"./?4-off\">turn off power 3</a></li>");
c.println( "<hr>");
c.println("</body>");
c.println("</html>");
* HTTP Redirect to homepage
void httpResponseRedirect(EthernetClient c) {
c.println("HTTP/1.1 301 Found");
c.println("Location: /");
c.println();
* HTTP Response 414 error
* Command must not be longer than 30 characters
void httpResponse414(EthernetClient c) {
c.println("HTTP/1.1 414 Request URI too long");
c.println("Content-Type: text/plain");
c.println();
c.println("414 Request URI too long");
* Process HTTP requests, parse first request header line and
* call processCommand with GET query string (everything after
* the ? question mark in the URL).
char* httpServer() {
if (client) {
char sReturnCommand[32];
int nCommandPos=-1;
sReturnCommand[0] = '\0';
while (client.connected()) {
if (client.available()) {
char c = client.read();
if ((c == '\n') || (c == ' ' && nCommandPos>-1)) {
sReturnCommand[nCommandPos] = '\0';
if (strcmp(sReturnCommand, "\0") == 0) {
httpResponseHome(client);
processCommand(sReturnCommand);
httpResponseRedirect(client);
if (nCommandPos>-1) {
sReturnCommand[nCommandPos++] = c;
if (c == '?' && nCommandPos == -1) {
nCommandPos = 0;
if (nCommandPos > 30) {
httpResponse414(client);
if (nCommandPos!=-1) {
// give the web browser time to receive the data
delay(1);
client.stop();
Serial.print("Restarting Web Server");
return sReturnCommand;
return '\0';
Errors I get while compiling:
G:\Dropbox\Dropbox\Arduino\RemoteControllFans\RemoteControllFans.ino: In function 'char* httpServer()':
G:\Dropbox\Dropbox\Arduino\RemoteControllFans\RemoteControllFans.ino:132:10: warning: address of local variable 'sReturnCommand' returned [-Wreturn-local-addr]
G:\Dropbox\Dropbox\Arduino\RemoteControllFans\RemoteControllFans.ino:171:10: warning: invalid conversion from 'char' to 'char*' [-fpermissive]
return '\0';
In file included from C:\Program Files (x86)\Arduino\libraries\Ethernet\src\Dns.cpp:8:0:
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\Dns.cpp: In member function 'uint16_t DNSClient::BuildRequest(const char*)':
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility/w5100.h:457:25: warning: result of '(256 << 8)' requires 18 bits to represent, but 'int' only has 16 bits [-Wshift-overflow=]
#define htons(x) ( (((x)<<8)&0xFF00) | (((x)>>8)&0xFF) )
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\Dns.cpp:164:18: note: in expansion of macro 'htons'
twoByteBuffer = htons(QUERY_FLAG | OPCODE_STANDARD_QUERY | RECURSION_DESIRED_FLAG);
Sketch uses 14004 bytes (43%) of program storage space. Maximum is 32256 bytes.
Global variables use 1211 bytes (59%) of dynamic memory, leaving 837 bytes for local variables. Maximum is 2048 bytes.
