Old MK3870 MCU
Hi, I have founded an old MK3870 MCU and now I want connect to my Arduino 2009 to use 4 digital ports inside and simple ESA Code. Maybe the problem is connect CMOS TTL port 4 and STROBE pins at Arduino or maybe convert at I2C by DAC0808 if is possible....?! :fearful:
I ask help if is possible to connect so different technology :roll_eyes: Thanks! :.
The MK3870 is a Mostek version of the fairchild F8. It's program memory is ROM based, which means you can't erase or reprogram it at all. Development was done with a special version that took a "piggyback" EPROM and cost a small fortune: Unless your chip already contains code designed to make it acts as a peripheral to some other micro, you might as well use it for jewelry.
thanks for your reply! :slight_smile:
I wish use a Mostek MK3870 for use your 4 port 8 bits to connect any devices…
For example I would try connect him at an PIC 18F4620 or similar to make a DUMP code.
Also a CD4066 MUX switch can be util with a pair of LM317 to receive correct input Vin.
I’m searcing about but I can’t found none Arduino Project…maybe TTL/CMOS value are not compatible…I don’t know about these!
I don't understand what you're trying to do. The circuit you show (described more fully here: http://www.seanriddle.com/f8.html ) is for reading the ROM contents of the 3870 and dumping them to a serial port, so that they can be used in an emulator, or analyzed/reverse-engineered for the purpose of replacing the 3870 in various Arcade games and similar. It doesn't permit the 3870 to be reprogrammed, or become a peripheral for the PIC...
