I have some old Lidl radio sockets which I would like to operate programmatically. I found a project on GitHub which looks like it should work ok for this exact model, but, I think due to age and dependencies, I can’t get it to compile. Ideally I would like to use it with an ESP8266, although I am testing with an Uno. I have a socket configured as sequence ‘D’ for testing.
I would appreciate any advice.
Here is the code:
* This code uses a 433MHz transmitter to control a wireless socket bought from LIDL.
* Currently I only include the transmitter sequences for turning on and off the socket that
* corresponds to button D of the remote.
* I have recorded the other sequences but haven't test them. If you want to test them, you have
* to convert them like DONseq and DOFFseq. Zeroes translate to 500, ones to 1000. You start with
* 7000 and end with 3000.
* To get the sequences from the remote, you can record them with gqrx, open them in audacity and
* decode manually. You only have to care for the duration of each level shift (low or high) and
* it is either 500us or 1ms. The sequence starts with a 7ms low and ends with a 3ms high.
* Another way to get them would be with a logic analyzer and a 433.92MHz receiver.
* The most cheap way would be an Arduino, a 433.92MHz receiver and some code.
* A. Marios, 2014
#include <avr/io.h>
#include <util/delay.h>
#define TRANSMITTER_PIN 2
// Sequences:
// A on : 1 0 0 1 1 0 1 0 - 1 0 1 0 1 0 0 1 - 1 0 0 1 1 0 1 0 - 1 0 0 1 0 1 1 0 - 0 1 1 0 0 1 1 0 - 1 0 1 0 0 1 0 1
// A off: 1 0 0 1 1 0 1 0 - 0 1 0 1 0 1 1 0 - 1 0 1 0 1 0 0 1 - 0 1 0 1 1 0 0 1 - 1 0 0 1 0 1 0 1 - 1 0 1 0 0 1 0 1
// B on : 1 0 0 1 1 0 1 0 - 0 1 1 0 1 0 0 1 - 0 1 0 1 1 0 0 1 - 0 1 0 1 0 1 1 0 - 1 0 1 0 1 0 0 1 - 0 1 1 0 0 1 1 0
// B off: 1 0 0 1 1 0 1 0 - 1 0 1 0 0 1 0 1 - 1 0 0 1 0 1 1 0 - 1 0 1 0 0 1 0 1 - 1 0 0 1 0 1 1 0 - 0 1 1 0 0 1 1 0
// C on : 1 0 0 1 1 0 1 0 - 1 0 1 0 1 0 1 0 - 1 0 1 0 1 0 1 0 - 0 1 1 0 1 0 0 1 - 0 1 0 1 1 0 0 1 - 1 0 1 0 1 0 0 1
// C off: 1 0 0 1 1 0 1 0 - 0 1 0 1 0 1 0 1 - 0 1 1 0 1 0 1 0 - 0 1 1 0 0 1 1 0 - 1 0 0 1 1 0 0 1 - 1 0 1 0 1 0 0 1
// D on : 1 0 0 1 1 0 1 0 - 1 0 1 0 0 1 0 1 - 1 0 0 1 0 1 1 0 - 1 0 1 0 0 1 0 1 - 1 0 0 1 0 1 1 0 - 0 1 1 0 1 0 1 0
// D off: 1 0 0 1 1 0 1 0 - 0 1 1 0 1 0 0 1 - 0 1 0 1 1 0 0 1 - 0 1 0 1 0 1 1 0 - 1 0 1 0 1 0 0 1 - 0 1 1 0 1 0 1 0
// * on : 1 0 0 1 1 0 1 0 - 0 1 1 0 1 0 1 0 - 1 0 1 0 0 1 0 1 - 0 1 0 1 0 1 0 1 - 0 1 1 0 1 0 1 0 - 0 1 0 1 1 0 0 1
// * off: 1 0 0 1 1 0 1 0 - 0 1 0 1 1 0 1 0 - 0 1 0 1 1 0 1 0 - 1 0 0 1 1 0 0 1 - 0 1 1 0 1 0 0 1 - 0 1 0 1 1 0 0 1
uint16_t DONseq[] = {7000, \
1000, 500, 500, 1000, 1000, 500, 1000, 500, \
1000, 500, 1000, 500, 500, 1000, 500, 1000, \
1000, 500, 500, 1000, 500, 1000, 1000, 500, \
500, 1000, 1000, 500, 1000, 500, 1000, 500, \
3000};
uint16_t DOFFseq[] = {7000, \
500, 1000, 1000, 500, 1000, 500, 500, 1000, \
500, 1000, 500, 1000, 1000, 500, 500, 1000, \
500, 1000, 500, 1000, 500, 1000, 1000, 500, \
1000, 500, 1000, 500, 1000, 500, 500, 1000, \
3000};
int seqLength = 50;
pinMode(TRANSMITTER_PIN, OUTPUT);
playSignal(DONseq);
delay(3000 );
playSignal(DOFFseq);
delay(3000);
void playSignal(uint16_t seq[])
int signal = 0;
for (int i = 0; i < 10; i++) { // repeat sequence 10 times to be sure
signal = 0;
for (int j = 0; j < seqLength; j++) {
digitalWrite(TRANSMITTER_PIN, signal);
signal = 1 - signal; // Swap signal level
_delay_us(seq[j]);
digitalWrite(TRANSMITTER_PIN, LOW);
