Old sketch not working anymore
I tried to upload a sketch I have used many times recently and it keeps giving me errors. I used it to create this. I used the following libraries and that seems to be where the errors are coming from. I get the following errors. I do not understand why it is giving me errors. It used to work. What has changed?
Here are my errors.
C:\Users\Hawkins\Documents\Arduino\libraries\BeatSync\fix_fft.cpp:50: error: expected initializer before 'Sinewave'
C:\Users\Hawkins\Documents\Arduino\libraries\BeatSync\fix_fft.cpp: In function 'int fix_fft(char*, char*, int, int)':
C:\Users\Hawkins\Documents\Arduino\libraries\BeatSync\fix_fft.cpp:199: error: 'Sinewave' was not declared in this scope
C:\Users\Hawkins\Documents\Arduino\libraries\BeatSync\fix_fft.cpp:209: error: 'Sinewave' was not declared in this scope
Post the code you're using that's generating those errors? (inside code tags, ofc)
//  Beat Sync
//  A music visualization device.
//  Created by
//  Carl Smith
//  penguinmagic@hotmail.com
#include <fix_fft.h>
int led[] = {5,6,7,8,9,10,11,12};
int x = 0;
char im[128], data[128];
char data_avgs[14];
int i=0,val;
#define AUDIOPIN 3
  for (int i = 0; i <8; i++)
    pinMode(led[i], OUTPUT);
  for (i=0; i < 128; i++){
    val = analogRead(AUDIOPIN);
    data[i] = val;
    im[i] = 0;
  fix_fft(data,im,7,0);
  for (i=0; i< 64;i++){
    data[i] = sqrt(data[i] * data[i] + im[i] * im[i]);  // this gets the absolute value of the values in the
    //array, so we're only dealing with positive numbers
  // average bars together
  for (i=0; i<14; i++) {
    data_avgs[i] = data[i*4] + data[i*4 + 1] + data[i*4 + 2] + data[i*4 + 3];   // average together
    data_avgs[i] = map(data_avgs[i], 0, 30, 0, 9);                              // remap values for LoL
  int value = data_avgs[0];//0 for bass
  ledArray(value);
void ledArray(int input)
  if (input > 8)
       digitalWrite(led[i], HIGH);
  else if (input > 7)
     for (int i = 0; i <7; i++)
     for (int i = 7; i <8; i++)
       digitalWrite(led[i], LOW);
  else if (input > 6)
     for (int i = 0; i <6; i++)
     for (int i = 6; i <8; i++)
  else if (input > 5)
     for (int i = 0; i <5; i++)
     for (int i = 5; i <8; i++)
  else if (input > 4)
     for (int i = 0; i <4; i++)
     for (int i = 4; i <8; i++)
  else if (input > 3)
     for (int i = 0; i <3; i++)
     for (int i = 3; i <8; i++)
  else if (input > 2)
     for (int i = 0; i <2; i++)
     for (int i = 2; i <8; i++)
  else if (input > 1)
     for (int i = 0; i <1; i++)
     for (int i = 1; i <8; i++)
What has changed?
You have to tell us. Did you change versions of the IDE? Where do you have the Sinewave library installed?
I tried changing versions of the IDE to no effect. I have the fix_fft.h library installed in the libraries folder. Is there a sinewave library?
PaulS:
Judging by the errors he posted above, I'd say it's a fair bet he has it in C:\Users\Hawkins\Documents\Arduino\libraries\BeatSync?
My guess is it would build on 1.0.6, but not 1.6.x - I suspect the problems all come from line 50:
const prog_int8_t Sinewave[N_WAVE-N_WAVE/4] PROGMEM = {
Try changing the type to int8_t. I think this is a sign of the progmem changes in recent compiler versions.
Thanks. That seemed to do something. I only get this error now. I am going to try locating the file and deleting it???
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-ar: unable to rename 'core.a'; reason: File exists
Also I am running 1.0.5.
Okay updated to 1.6.5 and made the changes suggested by DrAzzy. It uploaded now. Thanks!
