I've gone through the troubleshooting guide and am at the point where it says,
"If it still doesn't work, you can ask for help in the forum. Please include the following information:
_ * Your operating system._
Ubuntu Linux 10.04 (Lucid Lynx)
_ * What kind of board you have._
Arduino Deumilanove
_ * Whether or not you were ever able to upload to the board. If so, what were you doing with the board before / when it stopped working, and what software have you recently added or removed from your computer?_
The board has worked without problems since March of 2010. I was successfully running a binary counter and was simply modifying the sketch to slow down the main loop by changing a statement from "delay(500);" to "delay(1000)". There were no software changes or system updates between the last time the board worked properly and the time it failed...about five minutes later. When I attempt to upload the modified sketch, the LED on pin 13 blinks one time, the board resets and then continues to run the old sketch. The tx and rx indicators do not light
_ * The messages displayed when you try to upload with verbose output enabled._
Binary sketch size: 1058 bytes (of a 30720 byte maximum)
avrdude -v -v -v -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/build5382427960950924709.tmp/BA17_595BinaryCounter.cpp.hex:i
avrdude: Version 5.10, compiled on Mar 23 2010 at 15:03:00
_** Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/**_
** Copyright (c) 2007-2009 Joerg Wunsch**
** System wide configuration file is "/etc/avrdude.conf"**
** User configuration file is "/home/ctdahle/.avrduderc"**
** User configuration file does not exist or is not a regular file, skipping**
** Using Port : /dev/ttyUSB0**
** Using Programmer : arduino**
** Overriding Baud Rate : 57600**
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude done. Thank you.
I tried a serial loop-back test (jumper from RESET to GND and another jumper from Pin0(rx) to Pin1(tx). Data sent from the serial monitor window does not loop back at any speed.
I have tried connecting the board to each of the several computers I have previously used to program it and get similar results.
I would be grateful for any and all suggestions. My pace of learning was just starting to accelerate and now I feel like I've hit the wall.
