oldArray[] = new Array[] question
Guys,
 for (int n = 0; n <= 3; n++)
    int c = OLDvalues1[n];
    int d = encoders1[n];
    values1[n] = c + d;
    OLDvalues1[n] = values1[n];
So Everything looks OK untill I do OLDvalues1[n] = values1[n].
Actually what I want to do at the end of the loop is making the array’s the same.
Should I do that inside the for loop or somewhere else? And how?
So how does one do that for arrays
FYI: In encoders1 are values +1 and -1 indicating that an encoder was turned CW or CCW.
values1 contains values between 0 and 127, same length as the encoders1 (4 pots)
Cheers,
ToAd
And, what does it look like afterwards? You really need to post ALL of your code, to provide context for that snippet.
On request :wink:
Well, this is the start of something bigger, first steps and so…
I do a shiftIn of a bunch of encoders.
Than (still in the void loop, the “for” statement, haven’t figured out how to make a function out of this) I’m deciding if the pot was turned up or down.
Than I calculate the value the pots represent.
Mind you that this code isn’t working. I only read one of the 4 shift in loops I intend to use, eventually.
The output on the screen is xxx -1 -1 yyy with x and y a random value. only the -1’s change, though not corresponding to the actual turning of the pot.
I need to get the read out on LCD working so I can check if the my calculations are of any good.
Any help apreciated!
So here the code (messy as this is actually my first real program)
//define where your pins are for shiftIn
int latchPin = 8;
int dataPin = 11;
int clockPin = 12;
//Define variables to hold the data
//for each shift register.
byte switchVar1;
byte OLDswitchVar1;
//Define varaibles to hold data
//for direction of rotary encoder (+1 or -1)
int encoders1[3];
int OLDencoders1[3];
//for values of rotary encoders
int values1[3];
int OLDvalues1[3];
// include the library code
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
////------------------------------------------------start setup
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello,");
  //define pin modes
  lcd.clear();
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, INPUT);
//------------------------------------------------end setup
////------------------------------------------------start main loop
  //but inputs of 74HC156 in buffer
  digitalWrite(latchPin, LOW);
  delayMicroseconds(5);
  digitalWrite(latchPin, HIGH);
  //read inputs from 74HC156
  switchVar1 = shiftIn(dataPin, clockPin);
  //calculate CW or CCW movement of rotary encoders
  //should be placed in a seperate function as I need to read 4 74HC156's
    for (int k = 0; k <= 3; k++)
      int j = (2*k)+1;
      int i = j-1;
      int a = bitRead(switchVar1, i);
      int b = bitRead(switchVar1, j);
      int OLDa = bitRead(OLDswitchVar1, i);
      int OLDb = bitRead(OLDswitchVar1, j);
      if ((a == 1) && (b == 1))
      if ((a == 0) && (b == 0) && (OLDa == 0) && (OLDb == 1))
       encoders1[k]=1;
       bitWrite(OLDswitchVar1, i, a);
       bitWrite(OLDswitchVar1, j, b);
      if ((a == 1) && (b == 0) && (OLDa == 0) && (OLDb == 0))
       encoders1[k]=1;
      if ((a == 0) && (b == 1) && (OLDa == 1) && (OLDb == 0))
       encoders1[k]=1;
      if ((a == 0) && (b == 0) && (OLDa == 1) && (OLDb == 0))
       encoders1[k]=-1;
      if ((a == 0) && (b == 1) && (OLDa == 0) && (OLDb == 0))
       encoders1[k]=-1;
      if ((a == 1) && (b == 0) && (OLDa == 0) && (OLDb == 1))
       encoders1[k]=-1;
        //if value changed and is not 11, than do as before
        encoders1[k]=OLDencoders1[k];
      OLDencoders1[k]=encoders1[k];
  //calculate rotary encoder values. If previous value was 80 and direction is +1 than new value is 81
    values1[n] = c + d;
  //display the values of the rotary encoders on the LCD
  lcd.setCursor(0, 0);
  lcd.print(values1[0]);
  lcd.setCursor(4, 0);
  lcd.print(values1[1]);
  lcd.setCursor(8, 0);
  lcd.print(values1[2]);
  lcd.setCursor(12, 0);
  lcd.print(values1[3]);
//------------------------------------------------end main loop
////// ----------------------------------------start shiftIn function 74LS156
byte shiftIn(int myDataPin, int myClockPin) {
  int i;
  int temp = 0;
  int pinState;
  byte myDataIn = 0;
  pinMode(myClockPin, OUTPUT);
  pinMode(myDataPin, INPUT);
  //read the byte
  for (i=7; i>=0; i--)
    digitalWrite(myClockPin, 0);
    //set clk pin low and read the input
    delayMicroseconds(2);
    temp = digitalRead(myDataPin);
    if (temp) {
      pinState = 1;
      myDataIn = myDataIn | (1 << i);
      //if pin is high write a 1 else a 0
    //set clk pin low to start reading the next bit
    digitalWrite(myClockPin, 1);
  return myDataIn;
//------------------------------------------------end shiftIn function
Cheers ToAd
edit: code with some comments
"I need to get the read out on LCD working so I can check if the my calculations are of any good." Or add Serial.begin(9600); and Serial.write(variable to be checked); and use the serial monitor.
Got anything against comments? Its a little tough to follow as is.
should rather read
for (int n = 0; n < 3; n++)
OLDvalues1[3] is a different variable and not part of your OLDvalues1 array
This was not visible in your first post :wink:
michael_x:
should rather read
Yes that for condition should be changed, to correct it for the size of the array. Your arrays are size 3 but including the equals sign will cause the loop to run 4 times.
michael_x:
What do you mean? OLDvalues1[3] doesnt exist, it’s out of the range of the array.
Wazzled:
should rather read
OK, I thought an array was zero indexed, so I was indeed reading it 4 times.
SO i should change
int encoders1[3];
into
int encoders1[4];
int OLDencoders1[4];
So I should do the same for the lcd code:
into
PS the lcd is working, I get to see the values, that’s when I got rid of the serial print…
Thanks!!
ToAd
EDIT:
OK. I tried it and it’s looking much better. Still not working as expected but that is due to the calculations being wrong.
Still wondering about the lcd code though… the lcd.print(values1[0] shows something.
Cheers,
ToAd
Arrays are 0 indexed, but when you define their size you are saying how many elements you want.
Your array size should be the number of encoders your using.
if you have
int numbers[3];
that array will store 3 numbers, with the first being at index 0, second at index 1, third at index 2.
thebigear: OK, I thought an array was zero indexed, so I was indeed reading it 4 times.
It is zero indexed. When you declare an array like this:
int myArray[4];
You have access to the values:
myArray[0] myArray[1]; myArray[2]; myArray[3];
Thanks Wazzled & Arrch, that's clear now. Cheers, ToAd
What do you mean? OLDvalues1[3] doesnt exist, it's out of the range of the array.
You can modify OLDvalues1[3] even if it's out of the range of the array, however this will modify a different variable, which is allocated at the place in memory just after OLDValues1[2]. Better don't care which variable is affected, but fix the problem code)
michael_x: You can modify OLDvalues1[3] even if it's out of the range of the array, however this will modify a different variable, which is allocated at the place in memory just after OLDValues1[2].
The joys of C# (wouldn't let you do that). :)
