Oled 1.3" I2C SSH1106 with ESP32 no display
Hi all Arduino geniuses!
I am using the code from original designer "Projects of Red" for the wire stripper.
The sketch was successful uploaded but I can't see display on OLED. However, it works with example code from Adafruit.
Please advise
#include <Stepper.h>
#include <Encoder.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
#define motorInterfaceType 1
#define i2c_Address 0x3c //OLED 1.3 Inch 128X64 IIC I2C SPI SSH1106 SSD1306
const int LINMOT_STEPPERS_STEP_PIN = 19;  // LINMOT: Linear motion
const int LINMOT_STEPPERS_DIR_PIN = 18;
const int EXTRUDER_STEPPER_STEP_PIN = 16;  // The stepper that moves the wire in the extruder.
const int EXTRUDER_STEPPER_DIR_PIN = 17;
const int ENCODER_DT_PIN = 0;
const int ENCODER_CLK_PIN = 23;
const int ENCODER_BTN_PIN = 4;
// For calibration only. The two buttons are used to move the top blade up and down manually.
// Once calibrated, you can remove the buttons from the circuit.
const int BTN1_PIN = 27;
const int BTN2_PIN = 26;
const int LINMOT_STEPPERS_STEPS = 1;  // Steppers step(s) movement at a time.
const int EXTRUDER_STEPPER_STEPS = 1;
const int LINMOT_STEPPERS_SPEED = 2000;
const int EXTRUDER_STEPPER_SPEED = 2000;
const int SCREEN_WIDTH = 128;  // OLED display width, in pixels
const int SCREEN_HEIGHT = 64;  // OLED display height, in pixels
const int TEXT_SIZE = 2;
const int TEXT_OFFSET = 3;
// Values for drawing the wire at the top of the OLED screen.
const int WIRE_STRAND_LENGTH = 30;
const int WIRE_STRAND_Y_POS = 7;
const int WIRE_INSULATION_WIDTH = SCREEN_WIDTH - (WIRE_STRAND_LENGTH * 2);
const int WIRE_INSULATION_HEIGHT = 14;
// These are just references to the corresponding component index in the comps array;
const int STRIPPING_LENGTH1_INDEX = 0;
const int WIRE_LENGTH_INDEX = 1;
const int STRIPPING_LENGTH2_INDEX = 2;
const int QUANTITY_INDEX = 3;
const int STRIPPING_DEPTH_INDEX = 4;
const int START_BTN_INDEX = 5;
const int CUTTING_STEPS = 17750;  // Steps to move blade to fully cut the wire.
const int STRIPPING_MULTIPLIER = 300;  // The chosen stripping depth value on the screen is multiplied by this value.
const int WIRE_MOVEMENT_MULTI = 414;  // How much to move wire per unit on OLED, turn on CALIBRATION_MODE to find this value.
const int DELAY_BETWEEN_CUTS = 100;  // Delay in ms between each cut in the quantity.
// To calibrate the wire movement distance. Use the first cell to enter the distance in mm to move the wire.
// Then adjust WIRE_MOVEMENT_MULTI to get the correct wire length.
const boolean CALIBRATION_MODE = true;
Stepper linMotSteppers(200, LINMOT_STEPPERS_DIR_PIN, LINMOT_STEPPERS_STEP_PIN);
Stepper extruderStepper(200, EXTRUDER_STEPPER_DIR_PIN, EXTRUDER_STEPPER_STEP_PIN);
Encoder encoder(ENCODER_DT_PIN, ENCODER_CLK_PIN);
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
int linMotSteppersCurrStep = 0;  // Current position/step of the stepper motor.
// A component is a cell with a value on the OLED display.
struct Component {
    int x, y;  // Position
    int w, h;  // Size
    int value;  // Current value of the cell.
    boolean highlighted;  // Whether the cell is the currently highlighted cell.
    boolean selected;  // Whether the cell is currently the selected one, where its value will be controlled by the encoder.
    boolean btn;  // If it is a button or not.
Component comps[] = {{0, 20, 40, 20, 0, 0, 0, 0},
                     {44, 20, 40, 20, 0, 0, 0, 0},
                     {88, 20, 40, 20, 0, 0, 0, 0},
                     {0, 44, 40, 20, 0, 0, 0, 0},
                     {44, 44, 40, 20, 0, 0, 0, 0},
                     {88, 44, 40, 20, 0, 0, 0, 1}};
int numOfComps = sizeof(comps) / sizeof(comps[0]);
int encoderPos;  // Current position/value of the encoder.
int encoderLastPos;  // For OLED drawing.
int encoderLastPosMain;  // For main loop.
boolean encBtnState = false;
boolean encBtnPrevState = false;  // For OLED drawing.
boolean encBtnPrevStateMain = false;  // For main loop.
    linMotSteppers.setSpeed(LINMOT_STEPPERS_SPEED);
    extruderStepper.setSpeed(EXTRUDER_STEPPER_SPEED);
    pinMode(ENCODER_BTN_PIN, INPUT_PULLUP);
    pinMode(BTN1_PIN, INPUT_PULLUP);
    pinMode(BTN2_PIN, INPUT_PULLUP);
    display.begin(i2c_Address, true);
    int encPos = getEncoderPos();
    boolean encBtnState = digitalRead(ENCODER_BTN_PIN);
    // Only update OLED screen if encoder is moved or pressed.
    if((encPos != encoderLastPosMain) || (encBtnState != encBtnPrevStateMain)) {
        handleOLEDDisplay();
    if(comps[START_BTN_INDEX].selected) {
        runAutoCuttingStripping();
    encoderLastPosMain = encPos;
    encBtnPrevStateMain = encBtnState;
    if(!digitalRead(BTN1_PIN)) {
        moveBlade(1);
    if(!digitalRead(BTN2_PIN)) {
        moveBlade(-1);
void handleOLEDDisplay() {
    display.clearDisplay();
    drawWire();
    boolean btnState = digitalRead(ENCODER_BTN_PIN);
    // Handling whether encoder is changing cell or value of the cell.
    if(!btnState && (btnState != encBtnPrevState)) {
        encBtnState = !encBtnState;
        if(encBtnState) {
            encoderLastPos = encoderPos;
            encoder.write(encoderLastPos * 4);
    encBtnPrevState = btnState;
    if (!encBtnState) {
        encoderPos = getEncoderPos();
    handleAllComponents();
    display.display();
void drawWire() {
    display.drawLine(0, WIRE_STRAND_Y_POS, WIRE_STRAND_LENGTH, WIRE_STRAND_Y_POS, SH110X_WHITE);
    display.fillRect(WIRE_STRAND_LENGTH, 0, WIRE_INSULATION_WIDTH, WIRE_INSULATION_HEIGHT, SH110X_WHITE);
    display.drawLine(WIRE_STRAND_LENGTH+WIRE_INSULATION_WIDTH, WIRE_STRAND_Y_POS, SCREEN_WIDTH, WIRE_STRAND_Y_POS, SH110X_WHITE);
void handleAllComponents() {
    for(int i = 0; i < numOfComps; i++) {
        Component &comp = comps[i];
        if(encoderPos == i) {
            comp.highlighted = true;
            if(encBtnState) {
                if(!comp.selected && !comp.btn) {
                    encoder.write(comp.value * 4);
                comp.selected = true;
                int newEncPos = getEncoderPos();
                comp.value = newEncPos;
                comp.selected = false;
            comp.highlighted = false;
        drawComponent(comp);
void drawComponent(Component comp) {
    if(comp.highlighted) {
        display.setTextColor(SH110X_BLACK, SH110X_WHITE);
        display.fillRect(comp.x, comp.y, comp.w, comp.h, SH110X_WHITE);
        if (comp.selected) {
            display.drawRect(comp.x-1, comp.y-1, comp.w+2, comp.h+2, SH110X_WHITE);
        display.setTextColor(SH110X_WHITE, SH110X_BLACK);
        display.drawRect(comp.x, comp.y, comp.w, comp.h, SH110X_WHITE);
    if(comp.btn) {
        display.setTextSize(1);
        drawText("Start", comp.x + TEXT_OFFSET, comp.y + TEXT_OFFSET);
        display.setTextSize(TEXT_SIZE);
        drawText(String(comp.value), comp.x + TEXT_OFFSET, comp.y + TEXT_OFFSET);
void drawText(String text, int x, int y) {
    display.setCursor(x, y);
    display.println(text);
void runAutoCuttingStripping() {
    if(CALIBRATION_MODE) {
        moveWire(comps[STRIPPING_LENGTH1_INDEX].value);
        cut();
        cut();
        delay(DELAY_BETWEEN_CUTS);
        for(int i = 0; i < comps[QUANTITY_INDEX].value; i++) {
            strip();
            moveWire(comps[WIRE_LENGTH_INDEX].value);
            strip();
            moveWire(comps[STRIPPING_LENGTH2_INDEX].value);
            cut();
    comps[START_BTN_INDEX].selected = false;
void cut() {
    moveBlade(-CUTTING_STEPS);
    moveBlade(CUTTING_STEPS);
void strip() {
    moveBlade(-(comps[STRIPPING_DEPTH_INDEX].value * STRIPPING_MULTIPLIER));
    moveBlade(comps[STRIPPING_DEPTH_INDEX].value * STRIPPING_MULTIPLIER);
void moveBlade(int steps) {
    linMotSteppers.step(steps);
    linMotSteppersCurrStep += steps;
void moveWire(int steps) {
    extruderStepper.step(steps * WIRE_MOVEMENT_MULTI);
int getEncoderPos() {
    int encPos = encoder.read() / 4;
    return encPos;
Check for conflicts with I/O pin usage.
The best approach is to start with the working display example, and add your other code in, section by section, testing as you go.
from the example code, I tried to combine both sketch but don't know where to start.
#include <SPI.h>
#include <Wire.h>
/* Uncomment the initialize the I2C address , uncomment only one, If you get a totally blank screen try the other*/
#define i2c_Address 0x3c //initialize with the I2C addr 0x3C Typically eBay OLED's
//#define i2c_Address 0x3d //initialize with the I2C addr 0x3D Typically Adafruit OLED's
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1   //   QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000
void setup()   {
  // Show image buffer on the display hardware.
  // Since the buffer is intialized with an Adafruit splashscreen
  // internally, this will display the splashscreen.
  delay(250); // wait for the OLED to power up
  display.begin(i2c_Address, true); // Address 0x3C default
 //display.setContrast (0); // dim display
  display.display();
  delay(2000);
  // Clear the buffer.
  // draw a single pixel
  display.drawPixel(10, 10, SH110X_WHITE);
  // Show the display buffer on the hardware.
  // NOTE: You _must_ call display after making any drawing commands
  // to make them visible on the display hardware!
  display.display();
  delay(2000);
  // draw many lines
  testdrawline();
  display.display();
  delay(2000);
  // draw rectangles
  testdrawrect();
  display.display();
  delay(2000);
  // draw multiple rectangles
  testfillrect();
  display.display();
  delay(2000);
  // draw mulitple circles
  testdrawcircle();
  display.display();
  delay(2000);
  // draw a SH110X_WHITE circle, 10 pixel radius
  display.fillCircle(display.width() / 2, display.height() / 2, 10, SH110X_WHITE);
  display.display();
  delay(2000);
  testdrawroundrect();
  delay(2000);
  testfillroundrect();
  delay(2000);
  testdrawtriangle();
  delay(2000);
  testfilltriangle();
  delay(2000);
  // draw the first ~12 characters in the font
  testdrawchar();
  display.display();
  delay(2000);
  // text display tests
  display.setTextColor(SH110X_WHITE);
  display.setCursor(0, 0);
  display.println("Failure is always an option");
  display.setTextColor(SH110X_BLACK, SH110X_WHITE); // 'inverted' text
  display.println(3.141592);
  display.setTextSize(2);
  display.print("0x"); display.println(0xDEADBEEF, HEX);
  display.display();
  delay(2000);
  // miniature bitmap display
  display.drawBitmap(30, 16,  logo16_glcd_bmp, 16, 16, 1);
  display.display();
  delay(1);
  // invert the display
  display.invertDisplay(true);
  display.invertDisplay(false);
  // draw a bitmap icon and 'animate' movement
  testdrawbitmap(logo16_glcd_bmp, LOGO16_GLCD_HEIGHT, LOGO16_GLCD_WIDTH);
void testdrawbitmap(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  uint8_t icons[NUMFLAKES][3];
  // initialize
  for (uint8_t f = 0; f < NUMFLAKES; f++) {
    icons[f][XPOS] = random(display.width());
    icons[f][YPOS] = 0;
    icons[f][DELTAY] = random(5) + 1;
    Serial.print("x: ");
    Serial.print(icons[f][XPOS], DEC);
    Serial.print(" y: ");
    Serial.print(icons[f][YPOS], DEC);
    Serial.print(" dy: ");
    Serial.println(icons[f][DELTAY], DEC);
  while (1) {
    // draw each icon
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, SH110X_WHITE);
    display.display();
    delay(200);
    // then erase it + move it
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, SH110X_BLACK);
      // move it
      icons[f][YPOS] += icons[f][DELTAY];
      // if its gone, reinit
      if (icons[f][YPOS] > display.height()) {
        icons[f][YPOS] = 0;
void testdrawchar(void) {
  for (uint8_t i = 0; i < 168; i++) {
    if (i == '\n') continue;
    display.write(i);
    if ((i > 0) && (i % 21 == 0))
      display.println();
  display.display();
  delay(1);
void testdrawcircle(void) {
  for (int16_t i = 0; i < display.height(); i += 2) {
    display.drawCircle(display.width() / 2, display.height() / 2, i, SH110X_WHITE);
    display.display();
    delay(1);
void testfillrect(void) {
  uint8_t color = 1;
  for (int16_t i = 0; i < display.height() / 2; i += 3) {
    // alternate colors
    display.fillRect(i, i, display.width() - i * 2, display.height() - i * 2, color % 2);
    display.display();
    delay(1);
    color++;
void testdrawtriangle(void) {
  for (int16_t i = 0; i < min(display.width(), display.height()) / 2; i += 5) {
    display.drawTriangle(display.width() / 2, display.height() / 2 - i,
                         display.width() / 2 - i, display.height() / 2 + i,
                         display.width() / 2 + i, display.height() / 2 + i, SH110X_WHITE);
    display.display();
    delay(1);
void testfilltriangle(void) {
  uint8_t color = SH110X_WHITE;
  for (int16_t i = min(display.width(), display.height()) / 2; i > 0; i -= 5) {
    display.fillTriangle(display.width() / 2, display.height() / 2 - i,
    if (color == SH110X_WHITE) color = SH110X_BLACK;
    else color = SH110X_WHITE;
    display.display();
    delay(1);
void testdrawroundrect(void) {
  for (int16_t i = 0; i < display.height() / 2 - 2; i += 2) {
    display.drawRoundRect(i, i, display.width() - 2 * i, display.height() - 2 * i, display.height() / 4, SH110X_WHITE);
    display.display();
    delay(1);
void testfillroundrect(void) {
    display.fillRoundRect(i, i, display.width() - 2 * i, display.height() - 2 * i, display.height() / 4, color);
    display.display();
    delay(1);
void testdrawrect(void) {
  for (int16_t i = 0; i < display.height() / 2; i += 2) {
    display.drawRect(i, i, display.width() - 2 * i, display.height() - 2 * i, SH110X_WHITE);
    display.display();
    delay(1);
void testdrawline() {
  for (int16_t i = 0; i < display.width(); i += 4) {
    display.drawLine(0, 0, i, display.height() - 1, SH110X_WHITE);
    display.display();
    delay(1);
  for (int16_t i = 0; i < display.height(); i += 4) {
    display.drawLine(0, 0, display.width() - 1, i, SH110X_WHITE);
    display.display();
    delay(1);
  delay(250);
    display.drawLine(0, display.height() - 1, i, 0, SH110X_WHITE);
    display.display();
    delay(1);
  for (int16_t i = display.height() - 1; i >= 0; i -= 4) {
    display.drawLine(0, display.height() - 1, display.width() - 1, i, SH110X_WHITE);
    display.display();
    delay(1);
  delay(250);
  for (int16_t i = display.width() - 1; i >= 0; i -= 4) {
    display.drawLine(display.width() - 1, display.height() - 1, i, 0, SH110X_WHITE);
    display.display();
    delay(1);
    display.drawLine(display.width() - 1, display.height() - 1, 0, i, SH110X_WHITE);
    display.display();
    delay(1);
  delay(250);
    display.drawLine(display.width() - 1, 0, 0, i, SH110X_WHITE);
    display.display();
    delay(1);
    display.drawLine(display.width() - 1, 0, i, display.height() - 1, SH110X_WHITE);
    display.display();
    delay(1);
  delay(250);
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project.
@sterretje Thank you
