Hi all.
Recently I started a project.
Arduino Uno, DHT22 sensor, OLED display 128x32.
OLED display connected to 3.3v vcc
DHT22 3.3V vcc
Uno as test area, couse I want to use Pro Micro 3.3v later.
Searching examples I found couple and tried them. I saw the problem.
After disconnecting from USB and reconnect I need to push reset button to see something on display or open Serial Monitor, same with external power. In one experiment I just disconnect DHT22 sensor, and reconnect the power, right away the display shows initialized values.
As I understand this is sync problem .
My code below
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#include <Wire.h>
#include <DHT.h>;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET 4
#define DHTPIN 7
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//Adafruit_SSD1306 display(OLED_RESET);
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
int t = 99;
int h = 99;
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.display();
delay(2000);
display.clearDisplay ();
dht.begin();
delay(2000);
//Serial.begin(9600);
delay(2000);
getDHT();
oneLine();
//For debug
//Serial.print(F("Humidity: "));
//Serial.print(h);
//Serial.print(F("% Temperature: "));
//Serial.print(t);
//Serial.println(F("°C "));
//delay (1000);
void oneLine(){
display.clearDisplay (); // clear display
display.setCursor (0,7); // position the cursor (X - coordinate, Y - coordinate)
display.setTextSize (3); // medium size font
display.setTextColor (WHITE); // white is not default !
display.print(String(t)); //display temperature from sensor
display.drawCircle (38,10,3, WHITE);
display.setCursor (43,7);
display.print("C ");
display.setCursor (74,7); // position the cursor (X - coordinate, Y - coordinate)
display.print (String(h)+"%");
display.display ();
void getDHT()
h = dht.readHumidity();
// Read temperature as Celsius (the default)
t = dht.readTemperature();
*DHT22 sensor comes on board with resistor build in
Try to increase delay, no effect
Thanks for the help
I tried with regular LCD16x2, no problem found, disconnecting and reconnecting power LCD start working right away.
