OLED clearing screen areas
I am using a 1351 OLED and have a page switch routine that on button push moves to a new page.
In the fuel and water pages, as the numbers update from the sensor I am trying to find a function that will just clear the screen area that doesnt change.
For instance if the sensor shows 103 and then 50 I dont want the 3 (of the 103 ) to still display.
If I just fill the screen black at the start of each page it has the effect of making everything disappear and then rewrite and I only want the unused area to clear.
void changeDisplay()
  dispChngpinState = digitalRead(dispChngpin);
  // Serial.println (buttonPushCounter);
  if (dispChngpinState != lastdispChngState)
    if (dispChngpinState == LOW)
      buttonPushCounter++;
      delay(100);
  lastdispChngState = dispChngpinState;
  if (buttonPushCounter  == 1)
    RTCNow();
  if (buttonPushCounter  == 2)
    tft.fillScreen(BLACK);
    buttonPushCounter = 3;
  if (buttonPushCounter  == 3)
    tft.setCursor(30, 5);
    tft.setTextColor(WHITE);
    tft.setTextSize(2);
    tft.println("Suzuki");
    tft.setCursor(55, 40);
    tft.setTextSize(4);
    tft.println("7");
  if (buttonPushCounter  == 4)
    watertemp();
    tft.setTextColor(WHITE, BLACK);
    tft.setTextSize(2);
    tft.println("Temp");
    tft.setTextSize(4);
    tft.setCursor(30, 30 );
    tft.setTextColor(WHITE, BLACK); // refreshes text area
    tft.println(temperature,2);
  if (buttonPushCounter  == 5)
    fuelSender();
    tft.setCursor(30, 5 );
    tft.setTextSize(2);
    tft.println("Fuel");
    tft.setTextSize(4);
    tft.println(itoa(fuel, buf5, 10));
  if (buttonPushCounter  == 6)
    buttonPushCounter = 1;
The typical solution to this is to test the value you are displaying
if( val < 100 ) tft.print(" ");
if( val < 10 ) tft.print(" ");
tft.print(val);
or reverse the order of the statements if you want the value left justified.
You can also use sprintf() with a %3d specification to make it always take up 3 chars
It works well. Thankyou!
Just so that I totally understand.....
I can see that the (" ") is filling an area of the display with nothing but how does it know what area to fill?
It looks like a form of nested IF? so is it if less that 100 print a blank (else print the number) , if less than 10, print another blank, else print the number?.
Sorry bit new to managing Oleds....and programming
It doesn't, it just prints a space at the cursor position.
kpg:
Those if statements are not nested. They are independent of each other so
if val < 100, print a space else do nothing
if val < 10, print a space else do nothing
print the number.
You could turn them into a nested if() structure, but that would just over-complicate things.
