OLED countdown not working with Piezo
After several hours of google searches with no luck I decided to make an account. I'm trying to make a 30 second timer that plays a pre written melody on the piezo while a number countdown is displayed on a 32spi OLED
If I remove the code for the piezo I can get the numbers to countdown, but when the code is added the numbers only countdown after the melody has fully played through.
Any help would greatly be appreciated!!
  display.setTextSize(5);
  display.setTextColor(WHITE);
  display.setCursor(textPos, 0);
  display.println(secondsValue);
  display.display();
  // Timer logic
  if (startTimer) {
    sing();
    if (currentMillis - timerCountDownMillis > countDownMillis) {
      display.clearDisplay();
      secondsValue = secondsValue.toInt() - 1;
      timerCountDownMillis = currentMillis;
      if (secondsValue.toInt() == 0) {
        secondsValue = "0";
      if (secondsValue.toInt() < "10") {
        textPos = sTextPos;
      if (secondsValue == "0") {
        startTimer = false;
// Piezo logic
void sing() {
  int size = sizeof(songMelody) / sizeof(int);
  if (startTimer) {
    for (int thisNote = 0; thisNote < size; thisNote++) {
      int songNoteDuration = 1000 / songNoteDurations[thisNote];
      tone(SND, songMelody[thisNote], songNoteDuration);
      // to distinguish the notes, set a minimum time between them.
      // the note's duration + 30% seems to work well:
      int pauseBetweenNotes = songNoteDuration * 1.30;
      delay(pauseBetweenNotes);
      //tunePlayed = true;
      // stop the tone playing:
      noTone(SND);
I'm very new to arduino and coding in general so i'm sorry if my code is cringe-worthy hahaha
Here is the entire problem:
This is freezing all the rest of your code. You need to use cooperative multitasking (doing more than one thing at a time), just follow the links in the sticky threads at the top of the forum to learn how to do that.
Thank you! I'll do that now
